Invité Patrick Posté(e) le 27 août 2003 Posté(e) le 27 août 2003 En avant première, voici le fichier readme du Service Pack 1 pour AutoCAD 2004 et AutoCAD LT2004 qui peut être téléchargé ici (AutoCAD 2004, 2 mega, version tous langages et software lock) Readme for the AutoCAD 2004 and AutoCAD LT 2004 Service Pack 1 -------------------------------------------------------------------------------- AutoCAD® 2004 and AutoCAD LT® 2004 Service Pack 1The AutoCAD 2004 and AutoCAD LT 2004 Service Pack 1 includes updates that resolve several issues discovered after the products were released. This Readme contains the latest information regarding the installation and use of this service pack. It is strongly recommended that you read this entire file before you apply the service pack to your product. For your reference, you should save this Readme to your hard drive or print a copy. NOTE: If you plan to use the Autodesk Network Installation wizard to deploy AutoCAD 2004 Service Pack 1, you must first download and run the Autodesk Network Installation Wizard patch. For more information about the patch, see the associated Readme file. Who Should Install the Service Pack?Service Pack 1 is for the following Autodesk products, locked and unlocked, and running on all supported operating systems and languages: AutoCAD 2004 AutoCAD LT 2004 This service pack is required for any AutoCAD 2004 extensions. Locked and Unlocked Service Packs If you download the service pack using the Live Update feature in Communication Center, the service pack version that you need is automatically identified. If you have the same product in multiple languages, all applicable versions will be patched. Separate patches are needed for locked and unlocked versions. If you decide to download the service pack manually, use the following guidelines to determine which service pack to download: Download and install the locked version of the service pack if you are using one of the following: Educational or trial version of AutoCAD 2004 or AutoCAD LT 2004 International English version of AutoCAD 2004 Download and install the unlocked version of the service pack in all other instances. General Information It is recommended that you create a backup of all custom MNU, MNS, MNR, MNL, and MNC files before installing the service pack. Also, any toolbar or menu customizations that were part of your former user profile could be lost. During the installation of this update, you will be prompted for the original installation CD or network image. Once this service pack is applied, you cannot run an automatic uninstall to remove the service pack. Summary of the Primary Issues Resolved by the Service Pack Fixes the causes of several intermittently encountered failures, including ones in 3D Orbit, the Customize dialog box, and when dragging objects between drawings. Corrects a problem with draw order when using the Bind option of the XREF command. Fixes several problems with hyperlinks in DWF files. To take advantage of the fixes when viewing DWF files, download the latest version of the Autodesk Express Viewer from the Autodesk website. Corrects the problem of the command line disappearing under some circumstances. Fixes a problem so that a space or semicolon now acts correctly as an ENTER with the SETENV macro in the system registry. Fixes several problems with REVDATE blocks in AutoCAD LT 2004. Corrects other miscellaneous issues. Files Patched by this Service PackDepending on the product and the type of installation, this service pack updates the following files for AutoCAD 2004 and AutoCAD LT 2004. AutoCAD Files Patched AutoCAD LT Files Patched acad.exe aclt.exe acbr16.dbx acbr16.dbx accvps.arx accvps.arx acdb16.dll acdb16.dll acdim.arx acdim.arx acgs.dll acgs.dll acismui.arx acismui.arx aclacadr.dll aclacltr.dll acmted.arx acmted.arx acpexctl.arx acpexctl.arx acpi.arx acpi.arx aceplotx.arx aceplotx.arx acrender.arx acltutil.arx acpublish.arx acpublish.arx acetransmitui.arx acetransmitui.arx adlmdll.dll adlmdll.dll adui16.dll adui16.dll ase.arx color.dll color.dll dlint8.dll dlint8.dll dwfplot8.hdi dwfplot8.hdi gdiplot8.hdi gdiplot8.hdi heidi8.dll heidi8.dll ie80.dll ie80.dll mtl8.dll mtl8.dll szb8.hdi szb8.hdi userdata.dll userdata.dll wscommcntrui1.dll wscommcntrui1.dll xesgdi8.hdi xesgdi8.hdi New Windows Command Line SwitchesThree new Windows command line switches are built into this service pack. The switches are as follows: /e - Extracts the MSP file from the service pack executable. /p - Extracts a patch list from the service pack executable. /q - Suppresses the completion message after the service pack is applied. This is useful if you use a script or batch file to apply the service pack to multiple computers. Instructions about how to use the /e and /p command line switches are included in the procedures that follow. Apply this Service Pack Through Your Local Network Using a Patch ListUse this procedure if you want to use Communication Center to apply this service pack through your local network. To apply this service pack through Communication Center using local patch list functionality Insert the AutoCAD 2004 CD into your local computer's CD-ROM drive. From the Autodesk Product Support website, download .exe and .htm to a local server. NOTE: Make sure that all users who need to apply the service pack have access to this server. On the Start menu (Windows), click Run. Enter the following information, and then click OK: \\\\ /p \ For example: c:\V086_V122_ACAD_UNL.exe /p c:\patchlist.txt The contents of the patch list file are similar to the following: ***** ProductCode={5783F2D7-0201-0409-0000-0060B0CE6BBA} ProductVersionCandidate=16.0.0.086 PatchTitle=AutoCAD ® 2004 Service Pack 1 PatchGUID={DB131225-C756-4632-80F7-6AA4B7D68981} PatchFileLocation=\\\\your_server_name\\your_share_name\\subfolders\\patch_name.exe or ftp://your_server_name/your_share_name/your_path/patch_name.exe PatchSize=2426880 PatchDesc=The AutoCAD ® 2004 Service Pack 1 PatchDescLocation=\\\\your_server_name\\your_share_name\\subfolders\\readme_name.html or ftp://your_server_name/your_share_name/your_path/readme_name.html NOTE: If a patch list file already exists in this location, the new patch list information is added to the end of that file. The original file is not overwritten. Open the patch list file. If there is more than one patch list, the lists are separated by asterisks (*****). Change the fifth line in step 3, PatchFileLocation, from: PatchFileLocation=\\\\\\\\\\.exe or ftp://///.exe to one of the following: If you want to make the service pack available from a file server, enter: PatchFileLocation=\\\\\\\\\\.exe If you want to make the service pack available from an FTP server, enter: ftp://///.exe Change the last line in step 3, PatchDescLocation, from: PatchDescLocation=\\\\\\\\\\.html or ftp://///.html to one of the following: If you want to make the Readme available from a file server, enter: PatchDescLocation=\\\\\\\\ \\.html If you want to make the Readme available from an FTP server, enter: ftp://///.html Save and close the patch list file. On the Start menu (Windows), click Run. Enter the following: \CDROM:\BIN\ACADFeui\Support\CADManagerControl Double-click CMControl.exe. In the CAD Manager utility, in the product list, select AutoCAD 2004, and then click OK. In the CAD Manager utility, on the Communication Center tab, do the following: In the Live Update Configuration list, select Enable Using Local Patch List. In the Local Patch List Location box, enter the same local patch list location that you entered in step 2. Click Apply to save these settings to your own system. At the bottom of the CAD Manager utility, in the drop-down list, select Create .reg Registry File. Then click OK. In the Save As dialog box, save the file to your system. Make note of this location. The registry file is now ready to be made available to users. Distribute and execute the file to users by implementing the method of your choice. NOTE: You must execute the service pack on each workstation that is running AutoCAD 2004. Apply this Service Pack to an AutoCAD 2004 Network Administrative ImageThe following two methods of distributing AutoCAD 2004 Service Pack 1 apply only to administrative images created with the AutoCAD 2004 Network Installation wizard. After you complete these procedures, any new deployments of AutoCAD 2004 will have the service pack applied to them automatically. NOTE: In both of the following procedures, the patch (service pack) file that you download contains an MSP (Microsoft Patch) file. You must extract that file from the executable file. To extract the MSP file from the executable, use the /e ("extract") switch. To add AutoCAD 2004 Service Pack 1 to a new AutoCAD 2004 administrative image From the Autodesk Product Support website, download .exe to your local computer. On the Start menu (Windows), click Run. Enter the following information, and then click OK: \\ /e \ On the computer where you installed the Network Installation wizard, on the Start menu (Windows), click Autodesk > Network Installation Wizard. In the Network Installation wizard, on the Welcome page, select Create an Administrative Image, and then click Next. On the Create Administrative Image page, in the Select Autodesk Installer (MSI) File box, enter the path to AutoCAD.msi, the MSI file you use as the basis for your administrative image. This file is found on your product CD-ROM, in CDROM:\BIN\ACADFeui. In the Administrative Image Location box, enter an existing shared network location where you want to create an administrative image, or click Browse to navigate to a location. Users install AutoCAD from this location. Select the Apply a Patch (Service Pack) to This Image option. In the Select Patch box, enter the path to the patch location (the location you entered in step 2, including the extension .msp). You can also Browse to locate the MSP file. Click Next, and follow the instructions in the Network Installation wizard to complete the deployment of this service pack. To apply AutoCAD 2004 Service Pack 1 to an existing AutoCAD 2004 administrative image From the Autodesk Product Support website, download .exe to your local computer. On the Start menu (Windows), click Run. Enter the following information, and then click OK. \\ /e \.msp On the computer where you installed the Network Installation wizard, on the Start menu (Windows), click Autodesk > Network Installation Wizard. In the Network Installation wizard, on the Welcome page, select Modify an Administrative Image, and then click Next. On the Modify Administrative Image page, in the Select an MSI File box, select an existing Autodesk installer file (MSI) from an existing shared network location that contains the administrative image you want to modify. Users install AutoCAD from this location. Select the Apply a Patch (Service Pack) to This Image option. In the Select Patch box, enter the path to the patch location (the location you entered in step 2, including the extension .msp). You can also Browse to locate the MSP file. Click Next, and follow the instructions in the Network Installation wizard to complete the deployment of this service pack. [Edité le 27/8/2003 par Patrick]
Invité Patrick Posté(e) le 27 août 2003 Posté(e) le 27 août 2003 Les problèmes réglés par le patch: Problèmes d'erreurs intermittentes, incluant certaines dans la commande 3D orbit, la boite de dialogue Personnalisation, et lorsqu'on glisse des objets entre dessins. Correction d'un problème avec l'ordre d'affichage en utilisant l'option "Lier" de la commande Xref. Correction de plusieurs problèmes de liens hypertexte dans les DWF. Téléchargez la dernière version de Autodesk Express Viewer pour en voir les effets. Correction de la disparition de la ligne de commande dans certaines circonstances. Correction du problème de l'espace ou du point virgule qui agit maintenant correctement comme ENTREE avec la macro SETENV dans le registre système. Correction de plusieurs problèmes avec REVDATE dans AutoCAD LT2004. Correction de divers autres problèmes.
zebulon_ Posté(e) le 28 août 2003 Posté(e) le 28 août 2003 Ce patch est-il également valable pour des versions Autodesk Architectural Desktop, Mechanical, LandDesktop etc ... ??Ou faut-il attendre des patchs spécifiques ? C'est au pied du mur que l'on reconnaît le maçon ! (Anonyme) C’est en restant au pied du mur qu’on ne voit que le mur (Anonyme aussi)
Invité Patrick Posté(e) le 28 août 2003 Posté(e) le 28 août 2003 Uniquement pour AutoCAD 2004 et AutoCAD LT2004
