J'ai été séduis par l'idée de dessiner des fleches proportionnelles à la longueur, évoqué dans les exercices des débutants en lisp.
Pour ne pas pertuber les cours (laissons les évoluer à leur vitesse) ;)
Je poste une routine que j'ai essayé de sophistiquer.
La nouvauté? On peut faire des flèches arrondies. :cool:
 (defun c:fleche ( / key_mod lock_mod p_begin p_end pl_wid d_pts a_pts nb_or p_x l_fl m_osm tg_dir pt_dir)
(setvar "cmdecho" 0)
(if (or (eq (getvar "USERS1") "Fixed") (eq (getvar "USERS1") "Varie"))
	(setq key_mod (getvar "USERS1"))
	(setvar "USERS1" "Fixed")
(if (or (eq (getvar "USERS2") "Yes") (eq (getvar "USERS2") "No"))
	(setq lock_mod (getvar "USERS2"))
	(setvar "USERS2" "No")
(initget 9 "Largeur Type _Width Type")
(while (eq (type (setq p_begin (getpoint "\nCorp de la flèche - Point de départ/[Largeur/Type] : "))) 'STR)
	(cond
		((eq p_begin "Width")
			(initget 4)
			(setq pl_wid (getdist (strcat "\nNouvelle largeur <" (rtos (getvar "plinewid")) ">: ")))
			(if pl_wid (setvar "plinewid" pl_wid) (setq pl_wid (getvar "plinewid")))
		((eq p_begin "Type")
			(initget "Constant Variable _Fixed Varie")
			(setq key_mod (getkword (strcat "\nCorp de flèche [Constant/Variable]? <" (if (eq (getvar "USERS1") "Fixed") "Constant" "Variable") ">: ")))
			(if (not key_mod) (setq key_mod (getvar "USERS1")) (setvar "USERS1" key_mod))
			(initget "Oui Non _Yes No")
			(setq lock_mod (getkword (strcat "\nVoulez vous verrouiller le sens de gauche à droite [Oui/Non]? <" (if (eq (getvar "USERS2") "No") "Non" "Oui") ">: ")))
			(if (not lock_mod) (setq lock_mod (getvar "USERS2")) (setvar "USERS2" lock_mod))
		(T (setq key_mod (getvar "USERS1") lock_mod (getvar "USERS2")))
(if (not pl_wid) (setq pl_wid (getvar "plinewid")))
(initget 9)
(setq
	p_end (getpoint p_begin "\nPosition de la pointe de la flèche: ")
	d_pts (distance p_begin p_end)
	a_pts (angle p_begin p_end)
	nb_or (/ (1+ (sqrt 5)) 2)
	l_fl (+ (* (* 0.1 nb_or) d_pts) (getvar "plinewid"))
	m_osm (getvar "osmode")
(if (eq lock_mod "Yes")
	(cond
		((and (> a_pts (/ pi 2)) (< a_pts (/ (* pi 3) 2)))
			(setq
				a_pts p_end
				p_end p_begin
				p_begin a_pts
(initget "Arc Segment _Arc Vertex")
(cond
	((eq (getkword "\nDessinée avec [Arc/Segment droit]? : ") "Arc")
		(grdraw p_begin p_end -1)
		(initget 1)
		(setq tg_dir (getangle p_begin "\nTangente du corp de la flèche: ") pt_dir (polar p_begin tg_dir d_pts))
		(if (and (or (> (- a_pts tg_dir) 0) (< (- a_pts tg_dir) (- pi))) (< (- a_pts tg_dir) pi))
			(setq p_x (polar p_begin (+ tg_dir (* (1- nb_or) (rem (- (+ (* 2 pi) a_pts) tg_dir) pi))) (* (1- nb_or) d_pts)))
			(setq p_x (polar p_begin (- tg_dir (* (1- nb_or) (rem (- (+ (* 2 pi) tg_dir) a_pts) pi))) (* (1- nb_or) d_pts)))
		(setvar "osmode" (+ 16384 (rem (getvar "osmode") 16384)))
		(if (eq key_mod "Fixed")
			(command "_.pline" p_begin "_arc" "_direction" pt_dir p_x "_width" l_fl 0.0 p_end "")
			(command "_.pline" p_begin "_width" (getvar "plinewid") 0.0 "_arc" "_direction" pt_dir p_x "_width" l_fl 0.0 p_end "")
	(T
		(setq p_x (polar p_begin a_pts (* (1- nb_or) d_pts)))
			(command "_.pline" p_begin p_x "_width" l_fl 0.0 p_end "")
			(command "_.pline" p_begin "_width" (getvar "plinewid") 0.0 p_x "_width" l_fl 0.0 p_end "")
(setvar "osmode" m_osm)
(setvar "cmdecho" 1)
chapeau et très impressionné.
Je vais essayer de faire une fleche non proportionnelle mais a laquelle on peut demander la largeur de la fleche et saisir a la sourie la longueur de celle-ci (la fleche)
on peut se donner plein de challenge comme ça c'est cool non!
Cordialement
Très bien.
Bonuscad aime bien lisper, j'ai remarqué.
Je glisserais bien un paramètre qui aide à donner une pointe de flèche de longueur variable, car je vois bien que la largeur et la longueur de pointe sont est donnés en proportion de la longueur totale.
Enfin, il ya 1000 facons de faire mais voilà déjà un LISP à glisser dans son acaddoc.lsp (fichier que l'on peut personnaliser et qui est chargé à chaque dessin).
Bureau d'études dessin.
Spécialiste Escaliers
Développement - Formation
./__\.
Merci pour vos commentaires. :D
J'espère de ne pas avoir démotivé les futurs lispeurs du forum en ayant empiété sur leur exercice.
De tout façon cette routine a certainement des failles.
Celles que j'ai remarqués sont; le mode arc en mode ORTHO (tangante 0) et/ou le mode ACCROBJ (ext => point départ=point d'arrivée) qui font avorter la routine par un message *incorrect*.
Donc a vos claviers pour la corriger et l'améliorer.
Le DCL peut être envisagé si de nombreuses options sont ajoutées. Tel qu'elle est je trouve que c'est inutile car le menu contextuel (click droit) et largement suffisant (à mon avis), mais le challenge reste ouvert ;) .
Pas de probleme Bonuscad, au contraire c'est motivant, et comme le dit Patrick_35 sur le cour n°2, maintenant je comprends ta demarche ci qui n'etait pas le cas il y a un mois
CCAD la DAO au service de l'Energie - http://c.cad.free.fr
