Un petit bouquet pour finir l'année.
Charger le LISP dans un dessin vierge et taper bqt...
(defun c:bqt (/ star echo n r d pls)
 (defun star (cen br dist col / ind ang n lst1 lst2)
   (setq ind (fix (/ (- br 0.5) 2))
  ang (* (rng) pi)
  n   (* 2 br)
   (repeat br
     (setq
lst1
 (cons
   (polar cen (+ ang (/ (* (setq n (- n 2)) pi) br)) dist)
   lst1
   (repeat br
     (setq lst2
     (cons (inters (nth n lst1)
		   (nth (rem (+ n br (- ind)) br) lst1)
		   (nth (rem (+ n (1- ind)) br) lst1)
		   (nth (setq n (rem (+ n (1- br)) br)) lst1)
	   lst2
   (entmake
     (append
(list '(0 . "LWPOLYLINE")
      '(100 . "AcDbEntity")
      (cons 62 col)
      '(100 . "AcDbPolyline")
      (cons 90 (* 2 br))
      '(70 . 1)
(mapcar
  '(lambda (pt)
     (cons 10 pt)
  (apply 'append
	 (apply 'mapcar (cons 'list (list lst1 lst2)))
 (setq echo (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (command "_zoom" "_w" '(0 0) '(1600 1200))
 (setq	pls nil
d   50
 (repeat 5
   (setq n 0
  r 1
   (repeat 81
     (star (polar '(800 600)
	   (* n (/ pi 8))
	   (* n (/ 110 16))
    (fix (+ 7 (* 8 (rng))))
    (* r (+ 4 (* (rng) 10)))
    (fix (+ 1 (* 6 (rng))))
     (setq r	(* r 1.02)
    n	(1+ n)
    pls	(cons (entlast) pls)
     (redraw)
     (command "_.delay" d)
   (setq d (- d 5))
 (mapcar 'entdel pls)
 (command "_.delay" 500)
 (redraw)
 (repeat 5
   (setq n (fix (+ 1 (* 404 (rng)))))
   (entdel (nth n pls))
   (redraw)
   (command "_.delay" 200)
   (redraw)
   (command "_.delay" 50)
 (setq pls (split-list pls 81))
 (repeat 10
   (setq n (fix (+ 1 (* 80 (rng)))))
   (mapcar '(lambda (l) (entdel (nth n l))) pls)
   (redraw)
   (command "_.delay" 300)
   (redraw)
 (setq	n 80
d 100
 (repeat 81
   (redraw)
   (setq n (1- n)
  d (1- d)
 (setq n 0)
 (repeat 4
   (mapcar 'entdel (nth n pls))
   (redraw)
   (setq n (1+ n))
   (mapcar '(lambda (l) (mapcar 'entdel l)) pls)
   (redraw)
   (redraw)
 (redraw)
 (redraw)
 (setq	n 0
d 100
 (repeat 3
   (repeat 5
     (redraw)
     (command "_.delay" 100)
     (setq n (1+ n))
   (repeat 5
     (setq n (1- n))
     (redraw)
 (setq	n 0
d 100
 (repeat 81
   (redraw)
   (setq n (1+ n)
  d (1- d)
 (setq	n 0
d 500
 (repeat 5
   (redraw)
   (setq n (1+ n)
  d (- d 100)
 (setvar "cmdecho" echo)
;;; SUBLIST Retourne une sous-liste
;;; Arguments
;;; lst : une liste
;;; start : l'index de départ de la sous liste (premier élément = 0)
;;; leng : la longueur (nombre d'éléments) de la sous-liste (ou nil)
;;; Exemples :
;;; (sublist '(1 2 3 4 5 6) 2 2) -> (3 4)
;;; (sublist '(1 2 3 4 5 6) 2 nil) -> (3 4 5 6)
(defun sublist (lst start leng / n r)
 (if (or (not leng) (    (setq leng (- (length lst) start))
 (setq n (+ start leng))
 (repeat leng
   (setq r (cons (nth (setq n (1- n)) lst) r))
;; SPLIT-LIST Retourne une liste de sous-listes
;; Arguments
;; - lst : la liste à fractionner
;; - num : un entier, le nombre d'éléments des sous listes
;; Exemples :
;; (split-list '(1 2 3 4 5 6 7 8) 2) -> ((1 2) (3 4) (5 6) (7 8))
;; (split-list '(1 2 3 4 5 6 7 8) 3) -> ((1 2 3) (4 5 6) (7 8))
(defun split-list (lst n)
 (if lst
   (cons (sublist lst 0 n)
  (split-list (sublist lst n nil) n)
;;; Retourne un nombre "pseudo-aléatoire" entre 0 et 1
(defun rng (/ modulus multiplier increment random)
 (or *seed* (setq *seed* (getvar "DATE")))
 (setq	modulus	   4294967296.0
multiplier 1664525
increment  1
*seed*	   (rem (+ (* multiplier *seed*) increment) modulus)
random	   (/ *seed* modulus)
[Edité le 25/12/2007 par (gile)]
[Edité le 26/12/2007 par (gile)]
Cet homme est un fou :D
Merci gile...
EDIT : je dirai même plus...
posté le 26/12/2007 à 00:57
[Edité le 26/12/2007 par Matt666]
coucou
loin de moi l'idée de me sentir aussi "étoilé"
que l'ami (Gile),
mais je me suis permis de remettre en téléchargement
la blagounette que j'avais fait pour 2003,
je sais bien que c'est du réchauffé, mais
de tous ceux qui animent le site aujourd'hui,
peu étaient là fin 2002.
je l'ai déposé dans :
les ressources > Telechargements membres > AutoCad > VBA.
pour les néophites,
copier le fichier sur le disque
lancer AutoCad
Menu : Outils > Macros VBA > Charger Projet
chercher le fichier téléchargé
ensuite : Ctrl+F8, surligner le fichier et Exécuter.
très amicalement
Éternel débutant…
Re,
didier, je suis allez faire un tour et je n'ai vu que 2 articles, mais pas le tien ?!
Ou bien me suis-je trompé d'adresse ?
En fait, je viens de le trouver dans le dossier "gratuiciel", je regarde ça de suite alors !
[Edité le 26/12/2007 par lili2006]
Civil 3D 2025 - COVADIS_18.3d
coucou
Effectivement, j'ai tapé par erreur Ctrl+F8
il faut bien sûr utiliser la combinaison[surligneur] Alt+F8 [/surligneur]
tu l'as testé ?
ça fonctionne ?
c'est une vue de l'esprit, on est d'accord ?
par contre je veux bien mettre un lien vers le téléchargement,
mais je ne l'ai pas trouvé sur le site...
je l'ai déposé à l'endroit cité dans le message précédent
ensuite, c'est Patrick qui décide...
amicalement
Éternel débutant…
coucou
Il eût fallu que je soit équipé d'une WebCam
pour que vous aperçussiez :
un : que je suis mal rasé
deux : que je suis rouge de confusion
en effet j'ai retourné vite fait le prog pour le mettre à jour pour 2008
et voilà que j'oublie les cases de dialogue...
le pôv garçon,
il a vraiment le cerveau pourri par ses clopes sans filtre
et son Jack Daniel's quotidien.
c'est bien vrai que ça fait pas pipi loin (hihihihi)
je vous présente mes excuses
amicalement
Éternel débutant…
coucou
le pôv garçon,
amicalement
Éternel débutant…
