HTML
;;;--- CPYXREF - Copy any entity from an XREF or a block.
;;;--- Legalities:
;;; Copyright 2002-2004 by JefferyPSanders.com
;;; All rights reserved.
;;;; You may use this program for free. You may not obtain profit without consent
;;; from Jeffery P Sanders. You may make copies of this program and distribute as
;;; long as the legalities remain in tact.
;;; End of Legalities
;;;--- Created on 7/18/02
;;;--- Main application
(defun C:CXF()
;;;--- Turn the command echo off
(setvar "cmdecho" 0)
;;;--- Save some system variables
(setq origCmddia(getvar "cmddia"))
(setq origFiledia(getvar "filedia"))
;;;--- Set some system variables
(setvar "cmddia" 0)
(setvar "filedia" 0)
;;;--- Select an entity
(if (setq entselected(entsel "\n Select XRef or Block: "))
(progn
;;;--- Save the entity name
(setq en(car entselected))
;;;--- Save the point selected
(setq selectedPt(cadr entselected))
;;;--- Get entity's DXF group codes
(setq enlist(entget en))
;;;--- If it is a block
(if(= "INSERT" (cdr(assoc 0 enlist)))
(progn
;;;--- Get the dxf group codes for the first sub-entity
(setq enlist2(tblNext "block" en))
;;;--- Save the file name of the block
(setq shortFileName(cdr(assoc 2 enlist))) ;thanks to Günther Bittner for fix
;;;--- Set a mark for the undo command
(command "_undo" "_mark")
;;;--- Make the XREF part of the drawing temporarily
(command "-xref" "_bind" shortFileName)
;;;--- Explode the block temporarily
(command "_explode" en)
;;;--- Get the entity at the point selected originally if it exist
(if (setq eset(ssget selectedPt))
(progn
;;;--- Get the name of the entity selected
(setq en(ssname eset 0))
;;;--- Get the DXF group codes of the entity
;;;--- Make a wblock named "X2"
(if(findfile "x2.dwg")
(command "_wblock" "x2" "_y" "" selectedPt en "")
(command "_wblock" "x2" "" selectedPt en "")
;;;--- Undo everything back to the marked position
(command "_undo" "_Back")
;;;--- Insert the X2 block
(setq pt1(getpoint selectedPt "\n Insertion Point: "))
(command "_insert" "*x2" pt1 "" "")
(alert "*Error* - Select a sub-entity.")
(alert "*Error* - Select a block or an XREF.")
(alert "*Error* - Select a block or an XREF please.")
;;;--- Reset system variables
(setvar "cmddia" origCmddia)
(setvar "filedia" origFiledia)
;;;--- Turn command echo back on
(setvar "cmdecho" 1)
;;;--- Inform the user
(princ "\n ...CPYXREF.lsp Complete. ")
(princ "\n By: Jeffery P. Sanders 7/19/02 Copyright 2002-2004 by JefferyPSanders.com")
;;;--- Suppress last echo for a clean exit
[Edité le 13/12/2005 par Tramber]
Bureau d'études dessin.
Spécialiste Escaliers
Développement - Formation
./__\.
