dr.loveless Posté(e) le 8 décembre 2005 Posté(e) le 8 décembre 2005 Salut, Comment puis-je faire pour changer l'imprimante par defaut en VB ? à l'aide de son nom. Merci d'avance Le DOC
winfield Posté(e) le 8 décembre 2005 Posté(e) le 8 décembre 2005 Bonsoir Doc, Tiré de l'aide : Sub Example_ConfigName() ' This example will add a new plot configuration to the current drawing. ' It will then list the plotter configuration file name for each Layout ' in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3" ' and re-display the configuration information for the drawing. ' ' * Note: File names may differ on your system, so be prepared to change ' the configuration file name used in the example to a file that exists ' on your system. Dim Layouts As AcadLayouts, Layout As ACADLayout Dim msg As String Dim ACADPref As AcadPreferencesFiles Dim originalValue As Variant ' Get the files preferences object Set ACADPref = ThisDrawing.Application.preferences.Files ' Read and display the original value originalValue = ACADPref.PrinterConfigPath ' Get layouts collection from document object Set Layouts = ThisDrawing.Layouts ' Display current plotter configuration information GoSub DISPLAY_CONFIG ' Change plotter configuration file for "Layout1" [surligneur] Layouts("Layout1").ConfigName = "DWF Classic.pc3" [/surligneur] ' Display new plotter configuration information GoSub DISPLAY_CONFIG Exit Sub DISPLAY_CONFIG: msg = vbCrLf & vbCrLf ' Start with a space ' Format and display current directory for configuration files msg = msg & vbTab & "Directories that will be scanned for the plotter configuration files are: " _ & vbCrLf & vbTab & vbTab & originalValue & vbCrLf & vbCrLf ' Get the plotter configuration name of every layout in this drawing For Each Layout In Layouts ' Format for display msg = msg & vbTab & Layout.name & " is using configuration: " & Layout.ConfigName & vbCrLf Next ' Display paper units information MsgBox "The plotter configuration information used in the current drawing is listed below." & msg Return End Sub Bonne soirée Nous n’ héritons pas de la terre de nos ancêtres.Nous l’empruntons à nos enfants.
