Créer ses motifs de hachures
Invité Sylvainhinard
Je cherche à me creer des motifs de hachures personnalisés. Apparement ce n'est pas très simple sous Autocad (je ne veux pas utiliser la command superhatch de l'Express). J'ai trouvé un Lisp qui à l'air presque... fonctionnel. Les pres du LISP pourrait t-ils regarder de plus près?
;;;CADALYST 10/05 Tip 2065: HatchMaker.lsp Hatch Maker © 2005 Larry Schiele
;;;* ====== B E G I N C O D E N O W ======
;;;* HatchMaker.lsp written by Lanny Schiele at TMI Systems Design Corporation
;;;* Lanny.Schiele@tmisystems.com
;;;* Tested on AutoCAD 2002 & 2006. -- does include a 'VL' function -- should work on Acad2000 on up.
(defun C:DrawHatch (/)
(command "undo" "be")
(setq os (getvar "OSMODE"))
(setvar "OSMODE" 0)
(command "UCS" "w")
(command "PLINE" "0,0" "0,1" "1,1" "1,0" "c")
(command "zoom" "c" "0.5,0.5" 1.1)
(setvar "OSMODE" os)
(setvar "SNAPMODE" 1)
(setvar "SNAPUNIT" (list 0.01 0.01))
(command "undo" "e")
(alert
"Draw pattern within 1x1 box using LINE or POINT entities only..."
(defun C:SaveHatch (/ round dxf ListToFile
user SelSet SelSetSize ssNth
Ent EntInfo EntType pt1 pt2
Dist AngTo AngFrom XDir YDir
Gap DeltaX DeltaY AngZone Counter
Ratio Factor HatchName HatchDescr
FileLines FileLines FileName
Scaler ScaledX ScaledY RF x
y h _AB _BC _AC
_AD _DE _EF _EH _FH
DimZin
;;;* BEGIN NESTED FUNCTIONS
(defun round (num)
(if (>= (- num (fix num)) 0.5)
(fix (1+ num))
(fix num)
(defun dxf (code EnameOrElist / VarType)
(setq VarType (type EnameOrElist))
(if (= VarType (read "ENAME"))
(cdr (assoc code (entget EnameOrElist)))
(cdr (assoc code EnameOrElist))
(defun ListToFile (TextList FileName DoOpenWithNotepad
AsAppend / TextItem
File RetVal
(if (setq File (open FileName
(if AsAppend
"a"
"w"
(progn
(foreach TextItem TextList
(write-line TextItem File)
(setq File (close File))
(if DoOpenWithNotepad
(startapp "notepad" FileName)
(FindFile FileName)
;;;* END NESTED FUNCTIONS
(princ
(strcat
"\n."
"\n 0,1 ----------- 1,1"
"\n | | "
"\n | Lines and | "
"\n | points must | "
"\n | be snapped | "
"\n | to nearest | "
"\n | 0.01 | "
"\n | | "
"\n 0,0 ----------- 1,0"
"\n."
"\nNote: Lines must be drawn within 0,0 to 1,1 and lie on a 0.01 grid."
(textscr)
(getstring "\nHit [ENTER] to continue...")
(princ
"\nSelect 1x1 pattern of lines and/or points for new hatch pattern..."
(while (not (setq SelSet (ssget (list (cons 0 "LINE,POINT")))))
(setq ssNth 0
SelSetSize (sslength SelSet)
DimZin (getvar "DIMZIN")
(setvar "DIMZIN" 11)
(if (> SelSetSize 0)
(princ "\nAnalyaing entities...")
(while (< ssNth SelSetSize)
(setq Ent (ssname SelSet ssNth)
EntInfo (entget Ent)
EntType (dxf 0 EntInfo)
ssNth (+ ssNth 1)
(cond
((= EntType "POINT")
(setq pt1 (dxf 10 EntInfo)
FileLine (strcat "0,"
(rtos (car pt1) 2 6)
(rtos (cadr pt1) 2 6)
",0,1,0,-1"
(princ (strcat "\n" FileLine))
(setq FileLines (cons FileLine FileLines))
((= EntType "LINE")
pt2 (dxf 11 EntInfo)
Dist (distance pt1 pt2)
AngTo (angle pt1 pt2)
AngFrom (angle pt2 pt1)
IsValid nil
(if
(or (equal (car pt1) (car pt2) 0.0001)
(equal (cadr pt1) (cadr pt2) 0.0001)
(setq DeltaX 0
DeltaY 1
Gap (- Dist 1)
IsValid T
(progn
(setq Ang (if (< AngTo pi)
AngTo
AngFrom
AngZone (fix (/ Ang (/ pi 4)))
XDir (abs (- (car pt2) (car pt1)))
YDir (abs (- (cadr pt2) (cadr pt1)))
Factor 1
RF 1
(cond
((= AngZone 0)
(setq DeltaY (abs (sin Ang))
DeltaX (abs (- (abs (/ 1.0 (sin Ang))) (abs (cos Ang)))
((= AngZone 1)
(setq DeltaY (abs (cos Ang))
DeltaX (abs (sin Ang))
((= AngZone 2)
DeltaX (abs (- (abs (/ 1.0 (cos Ang))) (abs (sin Ang)))
((= AngZone 3)
DeltaX (abs (cos Ang))
(if (not (equal XDir YDir 0.001))
(progn
(setq Ratio (if (< XDir YDir)
(/ YDir XDir)
(/ XDir YDir)
RF (* Ratio Factor)
Scaler (/ 1
(if (< XDir YDir)
XDir
YDir
(if (not (equal Ratio (round Ratio) 0.001))
(progn
(while
(and
(<= Factor 100)
(not (equal RF (round RF) 0.001))
(setq Factor (+ Factor 1)
RF (* Ratio Factor)
(if (and (> Factor 1) (<= Factor 100))
(progn
(setq _AB (* XDir Scaler Factor)
_BC (* YDir Scaler Factor)
_AC (sqrt (+ (* _AB _AB) (* _BC _BC)))
_EF 1
x 1
(while (< x (- _AB 0.5))
(setq y (* x (/ YDir XDir))
h (if (< Ang (/ pi 2))
(- (+ 1 (fix y)) y)
(- y (fix y))
(if (< h _EF)
(setq _AD x
_DE y
_AE (sqrt (+ (* x x) (* y y)))
_EF h
(setq x (+ x 1))
(if (< _EF 1)
(setq _EH (/ (* _BC _EF) _AC)
_FH (/ (* _AB _EF) _AC)
DeltaX (+ _AE
(if (> Ang (/ pi 2))
(- _EH)
_EH
DeltaY (+ _FH)
Gap (- Dist _AC)
IsValid T
(if (= Factor 1)
(setq Gap (- Dist (abs (* Factor (/ 1 DeltaY))))
IsValid T
(if
IsValid
(progn
(setq FileLine
(strcat
(angtos AngTo 0 6)
(rtos (car pt1) 2 8)
(rtos (cadr pt1) 2 8)
(rtos DeltaX 2 8)
(rtos DeltaY 2 8)
(rtos Dist 2 8)
(rtos Gap 2 8)
(princ (strcat "\n * * * Line with invalid angle "
(angtos AngTo 0 6)
(chr 186)
" omitted. * * *"
((princ
(strcat "\n * * * Invalid entity " EntType " omitted.")
(setvar "DIMZIN" DimZin)
(if
(and
FileLines
(setq HatchDescr
(getstring T
"\nBriefly describe this hatch pattern: "
(setq FileName (getfiled "Hatch Pattern File"
"I:\\Acad\\Hatch\\"
"pat"
1
(progn
(if (= HatchDescr "")
(setq HatchDescr "Custom hatch pattern")
(setq HatchName (vl-filename-base FileName)
FileLines (cons (strcat "*" HatchName "," HatchDescr)
(reverse FileLines)
(princ
"\n============================================================"
(princ
(strcat "\nPlease wait while the hatch file is created...\n"
(ListToFile FileLines FileName nil nil)
(command "delay" 1500) ;delay required so file can be created and found (silly, but req.)
(if (findfile FileName)
(progn
(setvar "HPNAME" HatchName)
(princ (strcat "\nHatch pattern '"
HatchName
"' is ready to use!"
(progn
(princ "\nUnable to create hatch pattern file:")
(princ (strcat "\n " FileName))
(princ
(if FileLines
"\nCancelled."
"\nUnable to create hatch pattern from selected entities."
(princ "\n ************************************************************** ")
(princ "\n** **")
(princ "\n* HatchMaker.lsp written by Lanny Schiele -- enjoy! *")
(princ "\n* *")
(princ "\n* Type in DRAWHATCH to have the environment created to draw. *")
(princ "\n* Type in SAVEHATCH to save the pattern you created. *")
(princ "\n** **")
C'est encore une fois un problème de traduction (anglais -> international)
Il suffit de remplacer :
  Citation
(setvar "OSMODE" 0)
(command "UCS" "w")
(alert
par :
(defun c:drawHatch (/)
(command "_undo" "_begin")
(setvar "OSMODE" 0)
(command "_ucs" "_w")
(command "_pline" "0,0" "0,1" "1,1" "1,0" "cc")
(command "_zoom" "_c" "0.5,0.5" 1.1)
(command "_undo" "_end")
(alert
Ansi que :
  Citation
par :
 (command "_delay" 1500) ;delay required so file can be created and found (silly, but req.)
C'est dommage, ça aurait pu être le [surligneur] Lisp de l'année [/surligneur] :thumbup:
Mais il semble être limité : il ne prend pas toutes les lignes
Pourquoi ?? Mystère, moi j'ai pas trouvé :casstet:
Voici une version avec les commandes internationalisées et les invites francisées :
EDIT: suppression des bbcodes obsolètes : [surligneur] [/surligneur]
;;;CADALYST 10/05 Tip 2065: HatchMaker.lsp Hatch Maker (c) 2005 Larry Schiele
;;; Traduction littérale et approximative des invites en français : Gile
(defun c:drawHatch (/ os)
 (setvar "OSMODE" 0)
 (command "_pline" "0,0" "0,1" "1,1" "1,0" "_c")
 (alert
   "Dessiner le modèle dans un carré de 1x1 \nen utilisant uniquement des POINTS et des LIGNES..."
	    y	     h	      _AB      _BC	_AC
	    _AD	     _DE      _EF      _EH	_FH
	    DimZin
 (defun round (num)
     (fix (1+ num))
     (fix num)
	     AsAppend	   /		 TextItem
	     File	   RetVal
		 (if AsAppend
		   "a"
		   "w"
     (progn
   (FindFile FileName)
 (princ
   (strcat
     "\n."
     "\n |                | "
     "\n | Lignes et      | "
     "\n | points doivent | "
     "\n | être accrochés | "
     "\n | au plus proche | "
     "\n | 0.01           | "
     "\n |                | "
     "\n."
     "\nNota: Les lignes doivent être dessinées entre 0,0 et 1,1 et sur une grille de 0.01."
 (textscr)
 (getstring "\nTaper [ENTER] pour continuer...")
 (princ
   "\nSelectionnez un modèle de 1x1 constitué de lignes et/ou de points pour un  nouveau motif de hachures..."
 (setq	ssNth	   0
   (princ "\nAnalyse des entités...")
  ssNth	  (+ ssNth 1)
   (cond
		      ",0,1,0,-1"
     ((= EntType "LINE")
     IsValid nil
      (if
  (setq	DeltaX	0
	DeltaY	1
	Gap	(- Dist 1)
	IsValid	T
  (progn
		    AngTo
		    AngFrom
	  Factor  1
	  RF	  1
    (cond
      ((= AngZone 0)
      ((= AngZone 1)
      ((= AngZone 2)
      ((= AngZone 3)
      (progn
		       (/ YDir XDir)
		       (/ XDir YDir)
	      RF     (* Ratio Factor)
	      Scaler (/	1
			(if (< XDir YDir)
			  XDir
			  YDir
	  (progn
	    (while
	      (and
		(<= Factor 100)
		     RF	    (* Ratio Factor)
	      (progn
		      _EF 1
		      x	  1
			    (- (+ 1 (fix y)) y)
			    (- y (fix y))
		  (if (< h _EF)
		    (setq _AD x
			  _DE y
			  _EF h
		  (setq x (+ x 1))
		(if (< _EF 1)
			DeltaX	(+ _AE
				     (- _EH)
				     _EH
			DeltaY	(+ _FH)
			Gap	(- Dist _AC)
			IsValid	T
    (if	(= Factor 1)
	    IsValid T
      (if
 IsValid
  (progn
    (setq FileLine
	   (strcat
	     (angtos AngTo 0 6)
	     (rtos DeltaX 2 8)
	     (rtos DeltaY 2 8)
	     (rtos Dist 2 8)
	     (rtos Gap 2 8)
  (princ (strcat "\n * * * Ligne avec angle non valide "
		 (angtos AngTo 0 6)
		 (chr 186)
		 " proscrit. * * *"
     ((princ
 (strcat "\n * * * Entite non valide " EntType " proscrit(e).")
 (if
   (and
     FileLines
     (setq HatchDescr
     (getstring	T
		"\nDécrivez brièvement ce motif de hachures: "
     (setq FileName (getfiled "Fichier de hachures"
		      "I:\\Acad\\Hatch\\" ; Chemin du dossier des hachures personnalisées
		       "pat"
		       1
    (progn
 (setq HatchDescr "Modèle de hachures personnalisé")
		     (reverse FileLines)
      (princ
      (princ
 (strcat "\nAttendez que le fichier de hachures soit créé SVP...\n"
      (command "_delay" 1500)		; Délai requis pour que le fichier soit créé et trouvé (stupide, mais requis)
 (progn
   (princ (strcat "\nLe motif de hachures '"
		  HatchName
		  "' est prêt pour l'utilisation !"
 (progn
   (princ "\nImpossible de créer le fichier de hachures:")
    (princ
      (if FileLines
 "\nAbandon."
 "\nImpossible de créer le motif de hachures avec les entités sélectionnées."
(princ
(princ "\n** **")
(princ
(princ "\n* *")
(princ
 "\n* Taper DRAWHATCH pour avoir l'environment de dessin. *"
(princ
 "\n* Taper SAVEHATCH pour enregistrer le motif créé. *"
(princ "\n** **")
(princ
Nota : On peut remplacer " I:\\Acad\\Hatch\\" par le chemin de son choix (le dossier doit être dans un chemin de recherche des fichiers de support) ou par "" (le dossier par défaut est celui contenu dans la variable DWGPREFIX).
[Edité le 30/10/2005 par (gile)]
  • 17 ans après...
Hello Gilles,
Je te remercie pour ce source Internationalisé...
Par contre, je viens de tester sur un motif très simple (quelques LIGNES) et le programme termine par :
      ; erreur: nombre d'arguments trop important
c'est grave Docteur ? QUID ? le DWG en pièce jointe...
Je te remercie
Christian
TEST_motif_hachure.dwgRecherche des informations…
Salut Christian,
Il y avait dans le code des balises bbcode [surligneur] ... [/surligneur] datant de l'ancien CADxp qui ne sont plus reconnues comme balises dans le nouveau CADxp et apparaissaient don "en dur". J'ai corrigé le code ci-dessus, tu peux le re-copier.
Ce genre d'erreur est facile à localiser avec l'éditeur Visual LISP en cochant "Arrêt sur erreur" dans le menu "Débogage",  puis en relançant le code pour générer l'erreur, enfin cliquer sur "Source de la dernière interruption" dans le menu "Débogage" pour sélectionner dans le code l'expression responsable de l'erreur. voir ce screencast.
