Dilack33 Posté(e) le 31 mai 2024 Posté(e) le 31 mai 2024 bonjour à tous, est-il possible de faire un script pour initialisé une liste d’échelle qu'on désire? j'avais récupérer ce lisp mais il ne fonctionne pas sur AutoCAD 2024 ;;;permet de supprimer une tres grande liste d'echelles ;;;commande:SCALELISTDELALL ;;; ========================================================================== ;;; File: ScaleListDel.lsp ;;; Purpose: Scale list deletion and management for AutoCAD 2008 ;;; Author: Steve Johnson ;;; Date: 13 August 2007 ;;; Version: 0.7 ;;; Copyright: (c) 2007 cad nauseam (www.cadnauseam.com) ;;; May be distributed and used freely provided this header is retained in full ;;; -------------------------------------------------------------------------- ;;; Disclaimer: ;;; This code is supplied as-is and with no warranty whatsoever. ;;; Destruction of annotative objects WILL result from incorrect use. ;;; Use at own risk. No responsibility accepted. Read all notes before use. ;;; -------------------------------------------------------------------------- ;;; Commands: ;;; SCALELISTDEL ;;; Deletes unused scales except 1:1 using a user-provided wildcard. ;;; SCALELISTDELALL ;;; Deletes all unused scales except 1:1. ;;; SCALELISTDELINCH ;;; Deletes all unused scales that contain the inch " character. ;;; SCALELISTDELXREF ;;; Deletes all unused scales that contain the "_XREF" string. ;;; SCALELISTDEL_ ;;; Deletes all unused scales that contain the "_" character. ;;; SCALELISTDELINCHXREF ;;; Deletes all unused scales that contain either the inch " character or ;;; the "_XREF" string. ;;; SCALELISTDELINCH_ ;;; Deletes all unused scales that contain either the inch " or "_" ;;; characters. ;;; SCALELISTMETRIC ;;; Deletes all existing unused scales except 1:1 and sets up metric scales. ;;; SCALELISTMETRICTEMPLATE ;;; Deletes all existing scales and sets up metric scales. For use only in ;;; setting up scales in templates and pre-2008 drawings. ;;; WARNING: potentially destructive to annotative objects! ;;; SCALELISTINCH ;;; Deletes all existing unused scales except 1:1 and sets up inch-based ;;; scales. ;;; SCALELISTINCHTEMPLATE ;;; Deletes all existing scales and sets up inch-based scales. For use ;;; only in setting up scales in templates and pre-2008 drawings. ;;; WARNING: potentially destructive to annotative objects! ;;; -------------------------------------------------------------------------- ;;; Functions: ;;; (scaledel_all_unsafe) ;;; Deletes all scales in the current drawing, including 1:1 and scales in ;;; use. ;;; WARNING: potentially destructive to annotative objects! ;;; (scaledel_wcard_unsafe WCARD-OR-LIST) ;;; If WCARD-OR-LIST is a wildcard string, deletes scales that match that ;;; wildcard, excluding 1:1 but including scales in use. ;;; If WCARD-OR-LIST is a list of scale names, deletes those scales, ;;; including 1:1 (if listed) and scales in use. ;;; WARNING: potentially destructive to annotative objects! ;;; (scaledel_long_xref LONG-SCALE-LIST) ;;; Cleans up those scales that are too long to delete using the command-line ;;; (i.e. over 132 characters). These are usually only those created by the ;;; AutoCAD 2008 pre-SP1 bug that created _XREF_XREF_XREF scales, and this ;;; is checked before deletion. ;;; (scaledel_warning) ;;; Issues a warning and asks user to enter Yes before continuing. ;;; (scaledel_get_scalelist) ;;; Returns a list of scales in the drawing. ;;; (scaledel_all) ;;; Deletes all scales other than 1:1 and scales in use. ;;; (scaledel_reset) ;;; Performs a -SCALELIST Reset command. ;;; (scaledel_smart_reset) ;;; Performs a -SCALELIST Reset command if it is likely to reduce the number ;;; of scales in the list, prior to setting things up. ;;; (scaledel_wcard WCARD) ;;; Deletes scales that match WCARD, excluding 1:1 and scales in use. ;;; (scaledel_create_scales SCALES) ;;; Creates a set of scales defined in list SCALES. ;;; (scaledel_create_metric) ;;; Creates a set of metric scales: see *** in code to adjust list. ;;; (scaledel_create_inch) ;;; Creates a set of inch scales: see *** in code to adjust list. ;;; -------------------------------------------------------------------------- ;;; Notes: ;;; Other than the SCALELIST*TEMPLATE commands, the commands will not delete ;;; the 1:1 scale, even if it is not in use. This is because if the scale list ;;; is completely cleared, AutoCAD 2008 will automatically recreate it using ;;; its hardwired list when the user picks the "Custom..." item that ;;; remains in the list. Leaving in the 1:1 scale prevents this from happening. ;;; The (scaledel_*_unsafe) functions can be used to delete all scales, ;;; including 1:1 and those in use, if you really need to do so. ;;; -------------------------------------------------------------------------- ;;; Later AutoCAD releases: ;;; As AutoCAD 2008's annotative scaling feature needs work, it is quite likely ;;; that future releases of AutoCAD will do things differently. This may result ;;; in this software failing to work correctly, or working with unintended ;;; results. Check carefully before using this software in 2009 and later. ;;; -------------------------------------------------------------------------- ;;; WARNING: ;;; Any function that uses the (scaledel_*_unsafe) functions may be DESTRUCTIVE ;;; to any annotative objects in the drawing, because they allow the deletion ;;; of scales that are in use. ;;; ========================================================================== (if (>= (atof (substr (getvar "ACADVER") 1 4)) 17.1) (progn ; Only define these functions if they will work (ie. 2008 or later) (prompt "\nLoading ScaleListDel.lsp Version 0.7... ") ;;; -------------------------------------------------------------------------- ;;; Commands (defun C:SCALELISTDEL (/ wcard) (setq wcard (getstring "\nEnter scale name(s) to delete: ")) (if (/= wcard "") (scaledel_long_xref (scaledel_wcard wcard)) ) (princ) ) ; End C:SCALELISTDEL (defun C:SCALELISTDELALL () (scaledel_all) (princ) ) ; End C:SCALELISTDELXREF (defun C:SCALELISTDELXREF () (scaledel_long_xref (scaledel_wcard "*_XREF")) (princ) ) ; End C:SCALELISTDELXREF (defun C:SCALELISTDEL_ () (scaledel_long_xref (scaledel_wcard "*_*")) (princ) ) ; End C:SCALELISTDEL_ (defun C:SCALELISTDELINCH () (scaledel_long_xref (scaledel_wcard "*\"*")) (princ) ) ; End C:SCALELISTDELINCH (defun C:SCALELISTDELINCHXREF () (scaledel_long_xref (scaledel_wcard "*\"*,*_XREF")) (princ) ) ; End C:SCALELISTDELINCHXREF (defun C:SCALELISTDELINCH_ () (scaledel_long_xref (scaledel_wcard "*\"*,*_*")) (princ) ) ; End C:SCALELISTDELINCHXREF (defun C:SCALELISTMETRIC () (scaledel_smart_reset) (prompt "\nDeleting existing unused scales...") (scaledel_long_xref (scaledel_wcard "*")) (prompt "\nCreating metric scales...") (scaledel_create_metric) (princ) ) ; End C:SCALELISTMETRIC (defun C:SCALELISTMETRICTEMPLATE () (if (= (scaledel_warning) "Yes") (progn (scaledel_smart_reset) (prompt "\nDeleting all existing scales...") (scaledel_all_unsafe) (prompt "\nCreating metric scales...") (scaledel_create_metric) ) ) (princ) ) ; End C:SCALELISTMETRICTEMPLATE (defun C:SCALELISTINCH () (scaledel_smart_reset) (prompt "\nDeleting existing unused scales...") (scaledel_wcard "*") (prompt "\nCreating inch scales...") (scaledel_create_inch) (princ) ) ; End C:SCALELISTINCH (defun C:SCALELISTINCHTEMPLATE () (if (= (scaledel_warning) "Yes") (progn (scaledel_smart_reset) (prompt "\nDeleting all existing scales...") (scaledel_all_unsafe) (prompt "\nCreating inch scales...") (scaledel_create_inch) ) ) (princ) ) ; End C:SCALELISTINCHTEMPLATE ;;; -------------------------------------------------------------------------- ;;; Functions (defun scaledel_all_unsafe (/ scale-en-list) (foreach item (dictsearch (namedobjdict) "ACAD_SCALELIST") (if (= 350 (car item)) (setq scale-en-list (cons (cdr item) scale-en-list)) ) ) (foreach item scale-en-list (entdel item) ) ) ; End scaledel_all_unsafe (defun scaledel_wcard_unsafe (WCARD-OR-LIST / scale-list scale) (foreach item (dictsearch (namedobjdict) "ACAD_SCALELIST") (if (= 350 (car item)) (setq scale-list (cons (cons (strcase (cdr (assoc 300 (entget (cdr item))))) (cdr item)) scale-list ) ) ) ) (if (= (type WCARD-OR-LIST) 'STR) (foreach item scale-list (if (and (wcmatch (car item) (strcase WCARD)) (/= (car item) "1:1") ) (entdel (cdr item)) ) ) (foreach item WCARD-OR-LIST (if (setq scale (assoc (strcase item) scale-list)) (entdel (cdr scale)) ) ) ) ) ; End scaledel_wcard_unsafe (defun scaledel_long_xref (LONG-SCALE-LIST / scale-list) (foreach scale LONG-SCALE-LIST (if (wcmatch (strcase scale) "*_XREF_XREF_XREF*") (setq scale-list (cons scale scale-list)) ) ) (if scale-list (progn (prompt "\nDeleting the following long _XREF scale(s):") (foreach scale scale-list (prompt (strcat "\n " scale)) ) (scaledel_wcard_unsafe scale-list) ) ) ) ; End scaledel_long_xref (defun scaledel_warning () (initget "Yes No") (getkword (strcat "\nThis command will first destroy all existing scales including those in use." "\nAre you sure you want to do this? [Yes/No] : " ) ) ) ; End scaledel_warning (defun scaledel_get_scalelist (/ scale-list) (foreach item (dictsearch (namedobjdict) "ACAD_SCALELIST") (if (= 350 (car item)) (setq scale-list (cons (strcase (cdr (assoc 300 (entget (cdr item))))) scale-list) ) ) ) scale-list ) ; End scaledel_get_scalelist (defun scaledel_all () (scaledel_smart_reset) (scaledel_long_xref (scaledel_wcard "*")) ) ; End scaledel_all (defun scaledel_reset (/ cmdecho) (setq cmdecho (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "_.-SCALELISTEDIT" "_R" "_Y" "_E") (setvar "CMDECHO" cmdecho) ) ; End scaledel_reset (defun scaledel_smart_reset () (if (> (length (scaledel_get_scalelist)) 40) (scaledel_reset) ) ) ; End scaledel_smart_reset (defun scaledel_wcard (WCARD / scale-list cmdecho long-scale-list) (foreach scale (scaledel_get_scalelist) (if (and (wcmatch (strcase scale) (strcase WCARD)) (/= scale "1:1") ) (setq scale-list (cons scale scale-list)) ) ) (if scale-list (progn (setq cmdecho (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "_.-SCALELISTEDIT") (foreach item scale-list (if ((command "_D" item) ; Attempt to delete scale (setq long-scale-list (cons item long-scale-list)) ) ) (command "_E") (setvar "CMDECHO" cmdecho) ) ) long-scale-list ; Returns list of scales too long to delete ) ; End scaledel_wcard (defun scaledel_create_scales (SCALES / scale-list-all cmdecho) (setq scale-list-all (scaledel_get_scalelist) cmdecho (getvar "CMDECHO") ) (setvar "CMDECHO" 0) (command "_.-SCALELISTEDIT") (foreach scale SCALES (if (not (member (strcase (car scale)) scale-list-all)) (command "_A" (car scale) (cadr scale)) ) ) (command "_E") (setvar "CMDECHO" cmdecho) ) ; End scaledel_create_scales ;;; -------------------------------------------------------------------------- ;; *** Note: several uncommon scales have been commented out. ;; Delete the leading semi-colon to make a scale active. ;; You can comment out an unwanted scale by placing a semi-colon at ;; the start of its line. (defun scaledel_create_metric () (scaledel_create_scales '( ; ("10:1" "10:1") ; ("5:1" "5:1") ; ("2:1" "2:1") ("1:1" "1:1") ("1:2" "1:2") ; ("1:2.5" "1:2.5") ("1:5" "1:5") ("1:10" "1:10") ("1:20" "1:20") ; ("1:25" "1:25") ("1:50" "1:50") ("1:100" "1:100") ("1:200" "1:200") ; ("1:250" "1:250") ("1:500" "1:500") ("1:1000" "1:1000") ("1:2000" "1:2000") ; ("1:2500" "1:2500") ("1:5000" "1:5000") ; ("1:10000" "1:10000") ; ("1:20000" "1:20000") ; ("1:25000" "1:25000") ; ("1:50000" "1:50000") ; ("1:100000" "1:100000") ; ("1:200000" "1:200000") ; ("1:250000" "1:250000") ; ("1:500000" "1:500000") ("1:1 m" "1000:1") ("1:2 m" "1000:2") ; ("1:2.5 m" "1000:2.5") ("1:5 m" "1000:5") ("1:10 m" "1000:10") ("1:20 m" "1000:20") ; ("1:25 m" "1000:25") ("1:50 m" "1000:50") ("1:100 m" "1000:100") ("1:200 m" "1000:200") ; ("1:250 m" "1000:250") ("1:500 m" "1000:500") ("1:1000 m" "1000:1000") ("1:2000 m" "1000:2000") ; ("1:2500 m" "1000:2500") ("1:5000 m" "1000:5000") ("1:10000 m" "1000:10000") ("1:20000 m" "1000:20000") ; ("1:25000 m" "1000:25000") ("1:50000 m" "1000:50000") ; ("1:100000 m" "1000:100000") ; ("1:200000 m" "1000:200000") ; ("1:250000 m" "1000:250000") ; ("1:500000 m" "1000:500000") ) ) ) ; End scaledel_create_metric ;;; -------------------------------------------------------------------------- ;; *** Note: several uncommon scales have been commented out. ;; Delete the leading semi-colon to make a scale active. ;; You can comment out an unwanted scale by placing a semi-colon at ;; the start of its line. (defun scaledel_create_inch () (scaledel_create_scales '( ; ("8:1" "8:1") ; ("4:1" "4:1") ; ("2:1" "2:1") ("1:1" "1:1") ("1/32\" = 1'-0\"" "0.03125:12") ("1/16\" = 1'-0\"" "0.0625:12") ("3/32\" = 1'-0\"" "0.09375:12") ("1/8\" = 1'-0\"" "0.125:12") ("3/16\" = 1'-0\"" "0.1875:12") ("1/4\" = 1'-0\"" "0.25:12") ("3/8\" = 1'-0\"" "0.375:12") ("1/2\" = 1'-0\"" "0.5:12") ("3/4\" = 1'-0\"" "0.75:12") ("1\" = 1'-0\"" "1:12") ("1-1/2\" = 1'-0\"" "1.5:12") ("3\" = 1'-0\"" "3:12") ("6\" = 1'-0\"" "6:12") ("1\" = 10'-0\"" "1:120") ("1\" = 20'-0\"" "1:240") ("1\" = 30'-0\"" "1:360") ("1\" = 40'-0\"" "1:480") ("1\" = 50'-0\"" "1:600") ("1\" = 60'-0\"" "1:720") ("1\" = 100'-0\"" "1:1200") ; ("1\" = 250'-0\"" "1:3000") ; ("1\" = 500'-0\"" "1:6000") ; ("1\" = 1000'-0\"" "1:12000") ; ("1\" = 5280'-0\"" "1:63360") ; ("1\" = 12000'-0\"" "1:144000") ; ("1\" = 24000'-0\"" "1:288000") ; ("1\" = 48000'-0\"" "1:576000") ; ("1\" = 50000'-0\"" "1:600000") ; ("1\" = 52800'-0\"" "1:633600") ) ) ) ; End scaledel_create_inch (prompt (strcat "SCALELISTDEL SCALELISTDELALL SCALELISTDELINCH SCALELISTDELXREF " "SCALELISTDEL_ SCALELISTDELINCHXREF SCALELISTDELINCH_ SCALELISTMETRIC " "SCALELISTMETRICTEMPLATE SCALELISTINCH SCALELISTINCHTEMPLATE " "commands loaded.\n" ) ) ) ; End progn to test for AutoCAD release (prompt "\nRequires AutoCAD 2008 or above.") ) (princ) ;;; ========================================================================== ;;; End of file ScaleListDel.lsp ;;; ========================================================================== merci d'avance pour vos réponse Citer
Eric Posté(e) le 31 mai 2024 Posté(e) le 31 mai 2024 Bonjour, A mon avis, c'est faisable avec la commande _-SCALELISTEDIT Citer Eric est formateur, revendeur sur AutoCAD LT, DraftSight, ZWCAD, SketchUp et PDF2CAD
Eric Posté(e) le 1 juin 2024 Posté(e) le 1 juin 2024 Ca donnerait quelque chose comme ça : Expert 5 _-scalelistedit _d * _a 1:100 1:100 _a 1:200 1:200 _a 1:500 1:500 _e Si on ne veut pas supprimer la liste existante, il faut enlever la ligne 4. (_d *) 1 Citer Eric est formateur, revendeur sur AutoCAD LT, DraftSight, ZWCAD, SketchUp et PDF2CAD
rebcao Posté(e) le 3 juin 2024 Posté(e) le 3 juin 2024 Bonjour, J'utilise 3 SCRIPTS qui me permettent de recréer une liste d'échelle complète en fonction de l'unité : M, CM, MM Christian init_new_LSTech_cm_ANNOTATIF.scr init_new_LSTech_mm_ANNOTATIF.scr init_new_LSTech_m_ANNOTATIF.scr 1 Citer Formateur, Consultant Expert AutoCAD, REVIT MEP, INVENTOR, télécharger , des Outils AutoCAD...cad123 @ wanadoo.fr (enlever les espaces de part et d'autre de @)
