inventor 2024 recherche et remplace texte
Voici une ilogic pour faire le taf
Sub main
 oDoc = ThisDoc.Document
 Dim oSheets As Sheets
 Dim oSheet As Sheet
 Dim oGeneralNotes As GeneralNotes
 Dim oGeneralNote As GeneralNote
 Dim oSymbol As SketchedSymbol
 Dim oSymbols As SketchedSymbols
 Dim oTitleBlock As TitleBlock
 Dim oTextBox As TextBox
 Dim ooTXT2Find As String
 Dim oNewTXT As String
 'get user input
 oTXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
 'look for blank value
 If oTXT2Find = "" Then
  Return 'exit rule
 End If
 oNewTXT = InputBox("Enter Text To Replace '" & oTXT2Find _
 & "' with.", "iLogic", "ZZZ")
 If oNewTXT = "" Then
  Return 'exit rule
 End If
 oSheets = oDoc.Sheets
 For Each oSheet In oSheets
  'handle errors
  On Error Resume Next
  'look at General Notes
  oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
  For Each oGeneralNote In oGeneralNotes
   oText = oGeneralNote.FormattedText
   oText = ReplaceText(oText, oTXT2Find, oNewTXT)
   oGeneralNote.FormattedText = oText
  Next
  'look at leader notes
  oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
  For Each oLeaderNote In oLeaderNotes
   oText = oLeaderNote.FormattedText
   oLeaderNote.FormattedText = oText
  Next
  'look at title blocks
  oTitleBlock = oSheet.TitleBlock
  For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
   oText = oTitleBlock.GetResultText(oTextBox)
   oTitleBlock.SetPromptResultText(oTextBox, oText)
  Next
  'look at sketched symbols
  oSymbols = oSheet.SketchedSymbols
  For Each oSymbol In oSymbols
   For Each oTextBox In oSymbol.Definition.Sketch.TextBoxes
    oText = oSymbol.GetResultText(oTextBox)
    oSymbol.SetPromptResultText(oTextBox, oText)
   Next
  Next
 Next
End Sub
Function ReplaceText(oText As String, oTXT2Find As String, oNewTXT As String)
 If oText = oTXT2Find Or oText.Contains(oTXT2Find) Then
  oText = Replace(oText, oTXT2Find, oNewTXT)
 End If
 Return oText
End Function
