Ça devrait répondre à ta demande:
(defun c:TEST (/ countBy ssToList getLength makeTable ss inspt)
  (defun countBy (fun lst / f key sub acc)
    (setq f (eval fun))
    (foreach x lst
      (setq acc
	     (if (setq sub (assoc (setq key (f x)) acc))
	       (subst (cons key (1+ (cdr sub))) sub acc)
	       (cons (cons key 1) acc)
  (defun ssToList (ss / i lst)
    (repeat (setq i (sslength ss))
      (setq lst (cons (ssname ss (setq i (1- i))) lst))
  (defun getLength (arc / lg loop)
    (setq lg (getpropertyvalue arc "Length"))
    (defun loop	(lst)
      (cond
	((null lst) "> 12")
	((<= lg (car lst)) (car lst))
	(T (loop (cdr lst)))
    (loop '(1.2	  1.5	2.0   2.5   3.0	  3.5	4.0   4.5   5.0	  5.5
	    6.0	  6.5	7.0   7.5   8.0	  8.5	9.0   9.5   10.0  10.5
	    11.0  11.5	12.
  (defun makeTable (lst inspt / table count)
    (vl-load-com)
    (setq table	(vla-addtable
		  (vla-get-modelspace
		    (vla-get-activedocument (vlax-get-acad-object))
		  (vlax-3d-point inspt)
		  (+ (length lst) 2)
		  2
		  15
		  50
    (vla-put-TitleSuppressed table :vlax-false)
    (vla-setText table 0 0 "QUANTITATIF")
    (setq row 1)
    (vla-setText table row 0 "Longueur")
    (vla-setText table row 1 "Quantité")
    (foreach p lst
      (setq row (1+ row))
      (vla-settext table row 0 (car p))
      (vla-settext table row 1 (cdr p))
      (vla-setcellalignment table row 0 5)
      (vla-setcellalignment table row 1 5)
    (vla-TransformBy
      table
      (vlax-TMatrix
	(append
	  (mapcar
	    (function
	      (lambda (v o)
		(append (trans v 0 1 T) (list o))
	    '((1. 0. 0.) (0. 1. 0.) (0. 0. 1.))
	    (trans '(0. 0. 0.) 1 0)
	  '((0. 0. 0. 1.))
  (if
    (and
      (setq ss (ssget "_X" (list (cons 0 "ARC"))))
      (setq inspt (getpoint "\nPoint d'insertion: "))
     (makeTable (countBy 'getLength (ssToList ss)) inspt)
