DIMOVERLAP DE LEE MAC
hello
 lee mac a ecrit DIMOVERLAP
ca cherche les cotations superposées.
mais ca prend en compte direct TOUTES LES COTATIONS.
qui pourrait me dire ou changer le lisp pour sélectionner des cotations  par un ssget par exemple.
ca permetrait aussi qu'il ne bosse pas avec les cotations a l'interieur des blocks.
ou sur des cotes qui sont a 10 000 unites l une de l'autre
merci
Phil
;;-----------------------=={ Dimension Overlap }==----------------------;;
;;  This program will automatically detect overlapping dimensions in    ;;
;;  all layouts and all blocks in a drawing, and will move such         ;;
;;  dimensions to a separate layer specified in the code.               ;;
;;  Author:  Lee Mac, Copyright © 2015  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2015-12-12                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2015-12-31                                      ;;
;;  - dimoverlap:processblock function rewritten to detect dimensions   ;;
;;    which overlap on both sides.                                      ;;
;;  Version 1.2    -    2017-04-25                                      ;;
;;  - Added parameter to allow the user to alter the tolerance for      ;;
;;    dimension comparison.                                             ;;
;;  - Added list of layer properties to be applied to layer assigned    ;;
;;    to overlapping dimensions.                                        ;;
(defun c:dimoverlap_1_2 ( / *error* cn1 cn2 ent lay tol )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
    (setq
;;                          Program Parameters                          ;;
        ;; Tolerance within which dimensions are deemed to overlap
        tol 0.01
        ;; Layer properties for overlapping dimensions
        lay
            (002 . "H_COTE DIMOVERLAP") ;; Layer Name
            (062 .  5)           ;; Layer Colour (1-255)
            (006 . "Continuous") ;; Layer Linetype (Must be loaded in drawing)
            (370 . -3)           ;; Layer Lineweight (Default = -3, else lineweight*100 e.g. 2.11 = 211)
        cn1 0
        cn2 0
    (LM:startundo (LM:acdoc))
    (vlax-for blk (vla-get-blocks (LM:acdoc))
        (if (= :vlax-false (vla-get-isxref blk))
            (if (= :vlax-true (vla-get-islayout blk))
                (setq cn1 (+ cn1 (dimoverlap:processblock blk (cdr (assoc 2 lay)) tol)))
                (setq cn2 (+ cn2 (dimoverlap:processblock blk (cdr (assoc 2 lay)) tol)))
    (if (< 0 cn2)
        (vla-regen (LM:acdoc) acallviewports)
    (if (< 0 (+ cn1 cn2))
        (progn
            (if (setq ent (tblobjname "layer" (cdr (assoc 2 lay))))
                (entmod
                    (vl-list*
                        (cons -1 ent)
                       '(000 . "LAYER")
                       '(100 . "AcDbSymbolTableRecord")
                       '(100 . "AcDbLayerTableRecord")
                       '(070 . 0)
                        lay
            (princ
                (strcat
                    "\n"
                    (itoa (+ cn1 cn2))
                    " overlapping dimension"
                    (if (= 1 (+ cn1 cn2)) " was" "s were")
                    " found and moved to the \"" (cdr (assoc 2 lay)) "\" layer."
                    (if (< 0 cn2)
                        (strcat
                            "\n"
                            (itoa cn2)
                            (if (= 1 cn2) " was in a block." " were in blocks.")
        (princ "\nNo overlapping dimensions were found.")
(defun dimoverlap:processblock ( blk lay tol / cnt dm1 dm2 enx g10 g13 g14 int lst ocs tmp vec )
    (vlax-for obj blk
        (if (wcmatch  (vla-get-objectname obj) "AcDbRotatedDimension,AcDbAlignedDimension")
            (progn
                (setq enx (entget (vlax-vla-object->ename obj))
                      ocs (cdr (assoc 210 enx))
                      g10 (trans (cdr (assoc 10 enx)) 0 ocs)
                      g13 (trans (cdr (assoc 13 enx)) 0 ocs)
                      g14 (trans (cdr (assoc 14 enx)) 0 ocs)
                (if (not (equal g10 g14 1e-8))
                    (setq vec (mapcar '- g10 g14)
                          int (inters
                                  g10 (mapcar '+ g10 (list (- (cadr vec)) (car vec) 0.0))
                                  g13 (mapcar '+ g13 vec)
                                  nil
                          lst (cons (list g10 int enx) lst)
    (setq cnt 0)
    (while (setq dm1 (car lst))
        (setq lst (cdr lst)
              tmp lst
        (while
            (not
                (or (null (setq dm2 (car tmp)))
                    (vl-some
                       '(lambda ( a b c d )
                            (cond
                                (   (equal a c tol)
                                    (cond
                                        (   (dimoverlap:online-p b c d tol)
                                            (dimoverlap:flagdim (caddr dm2) lay)
                                            (setq cnt (1+ cnt))
                                        (   (dimoverlap:online-p d a b tol)
                                            (dimoverlap:flagdim (caddr dm1) lay)
                                            (setq cnt (1+ cnt))
                                (   (and (dimoverlap:online-p c a b tol)
                                         (dimoverlap:online-p a c d tol)
                                    (foreach dim (list dm1 dm2)
                                        (dimoverlap:flagdim (caddr dim) lay)
                                        (setq cnt (1+ cnt))
                        (list (car  dm1) (car  dm1) (cadr dm1) (cadr dm1))
                        (list (cadr dm1) (cadr dm1) (car  dm1) (car  dm1))
                        (list (car  dm2) (cadr dm2) (car  dm2) (cadr dm2))
                        (list (cadr dm2) (car  dm2) (cadr dm2) (car  dm2))
            (setq tmp (cdr tmp))
    cnt
(defun dimoverlap:online-p ( p a b f )
    (and (not (equal a p f))
         (not (equal b p f))
         (equal (distance a b) (+ (distance a p) (distance b p)) f)
(defun dimoverlap:flagdim ( x l )
    (entmod (subst (cons 8 l) (assoc 8 x) x))
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(if (null LM:startundo)
    (defun LM:startundo ( doc )
        (LM:endundo doc)
        (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(if (null LM:endundo)
    (defun LM:endundo ( doc )
        (while (= 8 (logand 8 (getvar 'undoctl)))
            (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(if (null LM:acdoc)
    (defun LM:acdoc nil
        (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
        (LM:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: DimensionOverlap.lsp | Version 1.2 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: Type \"dimoverlap_1_2\" to Invoke ::"
;;                             End of File                              ;;
FREELANCE
Autodesk Architecture 2025 sous windows 11 64
REVIT
24 pouces vertical + 30 pouces horizontal + 27 pouces horizontal
