lecrabe Posté(e) le 15 août 2022 Posté(e) le 15 août 2022 Hello Voir Titre ... SVP est ce que cette routine TRIANGULATE tourne sur ZWCad ? Elle utilise des Points 3D XYZ pour creer un MNT en 3DFaces ... Merci de vos retours ... La Sante, Bye, lecrabe ;; triangulate.lsp ;; http://elpanov.com/index.php?id=6 (defun c:triangulate (/ I L S) (princ (strcat "\n select points")) (if (setq i 0 s (ssget '((0 . "POINT"))) ) ;_ setq (progn (repeat (sslength s) (setq l (cons (cdr (assoc 10 (entget (ssname s i)))) l) i (1+ i) ) ;_ setq ) ;_ repeat (eea-delone-triangulate i l) ) ;_ progn ) ;_ if ) ;_ defun (defun eea-delone-triangulate (i1 L / A A1 A2 A3 I I2 L1 L2 L3 LP MA MI P S TI TR X1 X2 Y1 Y2 ) ;;********************************************************* ;; ;; Written by ElpanovEvgeniy ;; 17.10.2008 ;; Program triangulate an irregular set of 3d points. ;; ;;********************************************************* (if l (progn (setq ti (car (_VL-TIMES)) i 1 i1 (/ i1 100.) i2 0 l (vl-sort (mapcar (function (lambda (p) (list (/ (fix (* (car p) 1000)) 1000.) (/ (fix (* (cadr p) 1000)) 1000.) (caddr p) ) ;_ list ) ;_ lambda ) ;_ function l ) ;_ mapcar (function (lambda (a b) (>= (car a) (car b)))) ) ;_ vl-sort x2 (caar l) y1 (cadar l) y2 y1 ) ;_ setq (while l (setq a (fix (caar l)) a1 (list (car l)) l (cdr l) ) ;_ setq (while (and l (= (fix (caar l)) a)) (setq a2 (car l)) (if (<= (cadr a2) y1) (setq y1 (cadr a2)) (if (> (cadr a2) y2) (setq y2 (cadr a2)) ) ;_ if ) ;_ if (setq a1 (cons (car l) (vl-remove a2 a1)) l (cdr l) ) ;_ setq ) ;_ while (foreach a a1 (setq lp (cons a lp))) ) ;_ while (setq x1 (caar lp) a (list (/ (+ x1 x2) 2) (/ (+ y1 y2) 2)) a1 (distance a (list x1 y1)) ma (+ (car a) a1 a1) mi (- (car a) a1) s (list (list ma (cadr a) 0) (list mi (+ (cadr a) a1 a1) 0) (list (- (car a) a1) (- (cadr a) a1 a1) 0) ) ;_ list l (list (cons x2 (cons a (cons (+ a1 a1) s)))) ma (1- ma) mi (1+ mi) ) ;_ setq (while lp (setq p (car lp) lp (cdr lp) l1 nil ) ;_ setq (while l (setq tr (car l) l (cdr l) ) ;_ setq (cond ((< (car tr) (car p)) (setq l2 (cons (cdddr tr) l2))) ((< (distance p (cadr tr)) (caddr tr)) (setq tr (cdddr tr) a1 (car tr) a2 (cadr tr) a3 (caddr tr) l1 (cons (list (+ (car a1) (car a2)) (+ (cadr a1) (cadr a2)) a1 a2 ) ;_ list (cons (list (+ (car a2) (car a3)) (+ (cadr a2) (cadr a3)) a2 a3 ) ;_ list (cons (list (+ (car a3) (car a1)) (+ (cadr a3) (cadr a1)) a3 a1 ) ;_ list l1 ) ;_ cons ) ;_ cons ) ;_ cons ) ;_ setq ) (t (setq l3 (cons tr l3))) ) ;_ cond ) ;_ while (setq l l3 l3 nil l1 (vl-sort l1 (function (lambda (a b) (if (= (car a) (car b)) (<= (cadr a) (cadr b)) (< (car a) (car b)) ) ;_ if ) ;_ lambda ) ;_ function ) ;_ vl-sort ) ;_ setq (while l1 (if (and (= (caar l1) (caadr l1)) (= (cadar l1) (cadadr l1)) ) ;_ and (setq l1 (cddr l1)) (setq l (cons (eea-data-triangle p (cddar l1)) l) l1 (cdr l1) ) ;_ setq ) ;_ if ) ;_ while (if (and (< (setq i (1- i)) 1) (< i2 100)) (progn (setvar "MODEMACRO" (strcat " " (itoa (setq i2 (1+ i2))) " % " (substr (strcat "||||||||||||||||||||||||||||||||||||||||||||||||||" "||||||||||||||||||||||||||||||||||||||||||||||||||" ) ;_ strcat 1 i2 ) ;_ substr (substr "..." 1 (- 100 i2) ) ;_ substr ) ;_ strcat ) ;_ setvar (setq i i1) ) ;_ progn ) ;_ if ) ;_ while (foreach a l (setq l2 (cons (cdddr a) l2))) (setq l2 (vl-remove-if-not (function (lambda (a) (and (< mi (caadr a) ma) (< mi (caaddr a) ma)) ) ;_ lambda ) ;_ function l2 ) ;_ vl-remove-if ) ;_ setq (foreach a l2 (entmake (list (cons 0 "3DFACE") (cons 10 (car a)) (cons 11 (car a)) (cons 12 (cadr a)) (cons 13 (caddr a)) ) ;_ list ) ;_ entmake ) ;_ foreach ) ;_ progn ) ;_ if (setvar "MODEMACRO" "") (princ (strcat "\n " (rtos (/ (- (car (_VL-TIMES)) ti) 1000.) 2 4) " secs." ) ;_ strcat ) ;_ princ (princ) ) ;_ defun (defun eea-data-triangle (P1 l / A A1 P2 P3 P4 S) ;;********************************************************* ;; ;; Written by ElpanovEvgeniy ;; 17.10.2008 ;; Calculation of the centre of a circle and circle radius ;; for program triangulate ;; ;; (eea-data-triangle (getpoint)(list(getpoint)(getpoint))) ;;********************************************************* (setq p2 (car l) p3 (cadr l) p4 (list (car p3) (cadr p3)) ) ;_ setq (if (not (zerop (setq s (sin (setq a (- (angle p2 p4) (angle p2 p1))))) ) ;_ zerop ) ;_ not (progn (setq a (polar p4 (+ -1.570796326794896 (angle p4 p1) a) (setq a1 (/ (distance p1 p4) s 2.)) ) ;_ polar a1 (abs a1) ) ;_ setq (list (+ (car a) a1) a a1 p1 p2 p3) ) ;_ progn ) ;_ if ) ;_ defun ;|«Visual LISP© Format Options» (80 1 2 2 T " " 80 60 0 0 0 nil nil nil T) ;*** DO NOT add text below the comment! ***|; Autodesk Expert Elite Team
Eric Posté(e) le 15 août 2022 Posté(e) le 15 août 2022 Salut Patrice. J'ai fait un petit test, ça semble fonctionner. Eric est formateur, revendeur sur AutoCAD LT, DraftSight, ZWCAD, SketchUp et PDF2CAD
lili2006 Posté(e) le 15 août 2022 Posté(e) le 15 août 2022 Bonjour à toutes et tous, Salut @Eric, Peux tu montrer le résultat STP ? D'avance, merci. Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
Eric Posté(e) le 15 août 2022 Posté(e) le 15 août 2022 Salut Lilian, Comme ça ? Eric est formateur, revendeur sur AutoCAD LT, DraftSight, ZWCAD, SketchUp et PDF2CAD
