[ACAD MAP/CIVIL 20XX] Bug avec certains SHP, DBF, SHX !
Objet: [ACAD MAP/CIVIL 20XX] Bug avec certains SHP, DBF, SHX !
https://forums.autodesk.com/t5/autocad-map-3d-forum/bug-with-mapimport-on-some-shape-files/m-p/9762761/highlight/false#M57923
So the solution is : remove or rename the .SHX file !
which is "not correct" for MAPIMPORT AND for the FDO SHP Driver !
The .SHX will recreated automatically by MAP and after MAP can use the SHP, DBF, etc ...
LA SANTE, Bye, lecrabe ... Retraite J19 ...
