Déterminer la version d\'Excel
Voici un lisp qui détermine le fichier pour faire une liaison avec excel et qui donne sa version
Un (car (Liaison_Excel)) retourne le Fichier pour faire la liaison
un (cadr (Liaison_Excel)) retourne la version d'excel
(defun Liaison_Excel(/ Chemin_Excel Environ Version_Excel)
   (if (setq Chemin_Excel (vl-registry-read "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\Excel.EXE" "Path"))
     (progn
       (foreach Environ (list "SYSTEMROOT" "WINDIR" "WINBOOTDIR" "SYSTEMDRIVE" "USERNAME" "COMPUTERNAME" "HOMEDRIVE" "HOMEPATH" "PROGRAMFILES")
         (if (vl-string-search (strcat "%" Environ "%") Chemin_Excel)
           (setq Chemin_Excel (vl-string-subst (strcase (getenv Environ)) (strcat "%" Environ "%") Chemin_Excel))
       (if (= (vl-string-elt Chemin_Excel (1- (strlen Chemin_Excel))) 92)
         (setq Chemin_Excel (strcat Chemin_Excel "Excel.exe"))
         (setq Chemin_Excel (strcat Chemin_Excel "\\Excel.exe"))
       (cond
         ((findfile (vl-string-subst "Excel8.olb" "Excel.exe" Chemin_Excel))
           (setq Chemin_Excel (vl-string-subst "Excel8.olb" "Excel.exe" Chemin_Excel))
         ((findfile (vl-string-subst "Excel9.olb" "Excel.exe" Chemin_Excel))
           (setq Chemin_Excel (vl-string-subst "Excel9.olb" "Excel.exe" Chemin_Excel))
         ((findfile (vl-string-subst "Excel10.olb" "Excel.exe" Chemin_Excel))
           (setq Chemin_Excel (vl-string-subst "Excel10.olb" "Excel.exe" Chemin_Excel))
       (cond
         ((= (strcase (vl-filename-base (vl-filename-directory Chemin_Excel))) "OFFICE11")
           (setq Version_Excel "2003")
         ((= (strcase (vl-filename-base (vl-filename-directory Chemin_Excel))) "OFFICE10")
           (setq Version_Excel "XP")
         ((= (strcase (vl-filename-base Chemin_Excel)) "EXCEL8")
           (setq Version_Excel "97")
         ((= (strcase (vl-filename-base Chemin_Excel)) "EXCEL9")
           (setq Version_Excel "2000")
       (if (not Version_Excel)
         (setq Chemin_Excel nil)
   (list Chemin_Excel Version_Excel)
(ps : Merci à Maximilien pour son aide)
Les Lisps de Patrick
Joseph Joubert, 1754-1824
j'ai seulement répété ce que [surligneur] Serge[/surligneur] t'avait dit pour Office XP!
mais je trouve génial(je n'y avais pas pensé) de retourner une liste plutôt que le chemin concaténé au fichier pas besoin de vl-string-subst-base..... ;)
dans Forum 4272 : Autocad et Excel :
Patrick_35,
C'est bon. Tout ce qui manque et un cond ou un if où tu pourras choisir la version d'Excel. Mentionnons qu'avec Excel10, le type [surligneur] library[/surligneur] est dans le fichier exe.
Serge
donc sur Office10 (Office Xp) le fichier Excel10.olb n'existe pas c'est le fichier Excel.exe qu'il faut chercher!
Oui, et c'est bien pour ça qu'a l'origine je pars sur Excel.exe. Par contre, l'excel10.olb est sur le lisp dont je me suis inspiré (et qui m’a bien indiqué les différentes versions) pour faire celui-ci et dans les tests, Oli553 est sur une version 2003, donc dans le doute, j'ai préféré le laisser
