lecrabe Posté(e) le 27 septembre 2018 Posté(e) le 27 septembre 2018 .Objet: Tech MAP 2019 : Update MAP 2019.0.1 Hello https://forums.autodesk.com/t5/autocad-map-3d-forum/autocad-map-3d-2019-0-1-update/td-p/8294827 Bye, lecrabe ---- This Update Applies to the Following Releases ---- Autodesk AutoCAD Map 3D 2019 Autodesk Infrastructure Administrator 2019 After applying this patch, the Product Version in the About box will be listed as 22.0.022.16 Autodesk AutoCAD Map 3D 2019.0.1 Update.Primary Issues Resolved in This Update The following issues have been resolved in AutoCAD Map 3D 2019.0.1 Update. Industry Models Map 3D 2019 crashed when re-generating graphic with the setting 'Close current drawing'. Relative Orientation for Utility Point label did not work well for SQLite based industry models FDO WFS Map 3D could not get data from some WFS URL. Symbolization The input values like line thickness, rotation would change when users change the symbol. MAPTOACAD The command MAPTOACAD took quite a long time for some specific data. After exported to DWG, the circle symbols got stretched or compressed depending on zoom level. Others This update fixed some customer error reports. Enhancements in This Update Industry Models This update adds some Autodesk.Map.IM namespaces to the Form Controls: Formula Box and Script-Programmable-Control. Paperspace This update adds a new command MAPNORTHARROWDEFAULTNORTH and allows user to specify whether the North Arrow points to the default north (i.e the angle of Pi/2) or the north defined in the current coordinate system. When this command sets to 0, the North Arrow would point to the north defined in the coordinat system. When this command sets to 1, the North Arrow would point to the default north. Others This update extends the FDO MySQL support to MySQL 8.0 Autodesk Expert Elite Team
lili2006 Posté(e) le 28 septembre 2018 Posté(e) le 28 septembre 2018 Bonjour à toutes et tous,Merci Patrice !!Décidément, on passe son temps à la patcher cette version, pfuuu!! Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
lili2006 Posté(e) le 28 septembre 2018 Posté(e) le 28 septembre 2018 Re,Est ce que je suis à jour sur cette version ?https://lili2006.kroqi.fr/shared/#/file/13f275543cc60a0ccfc7742ee3ba1d0aJe vais ensuite clôner les 50 Pcs que l'on utilise au lycée, je ne voudrais pas me planter,...Merci d'avance, Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
lecrabe Posté(e) le 28 septembre 2018 Auteur Posté(e) le 28 septembre 2018 Hello Lilian Tu es OK ! Donc Biere et Champagne !! Bye, lecrabe Autodesk Expert Elite Team
lili2006 Posté(e) le 28 septembre 2018 Posté(e) le 28 septembre 2018 Cool et c’est grâce à ton suivi !!Merci encore Patrice ! Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
