Modification lisp
Bonjour.
Avec ce lisp, il est possible de créer un rectangle en 3 points, je voudrais savoir s'il est possible de le compléter avec des hachures quitte à avoir une liste de choix pour le type de hachures.
Au final, on fait le rectangle et en fonction des hachures choisies tout se fait en 4 clics....
(defun 3p-rec ( dyn / *error* gr1 gr2 lst msg ocs osf osm pt1 pt2 pt3 pt4 pt5 pt6 str tmp vec )
   (defun *error* ( msg )
       (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
           (princ (strcat "\nError: " msg))
       (redraw) (princ)
   (if
       (and
           (setq pt1 (getpoint "\nSpecify 1st point: "))
           (setq pt2 (getpoint "\nSpecify 2nd point: " pt1))
           (or   dyn (setq pt3 (getpoint "\nSpecify 3rd point: " pt1)))
           (setq vec (trans (mapcar '- pt2 pt1) 1 0 t)
                 ocs (trans '(0.0 0.0 1.0) 1 0 t)
                 pt4 (trans pt1 1 vec)
                 pt5 (trans pt2 1 vec)
           (if dyn
               (progn
                   (setq osf (LM:grsnap:snapfunction)
                         osm (getvar 'osmode)
                         msg "\nSpecify 3rd point: "
                         str ""
                   (princ msg)
                   (while
                       (progn
                           (setq gr1 (grread t 15 0)
                                 gr2 (cadr gr1)
                                 gr1 (car  gr1)
                           (cond
                               (   (or (= 5 gr1) (= 3 gr1))
                                   (redraw)
                                   (osf gr2 osm)
                                   (setq pt6 (trans gr2 1 vec))
                                   (mapcar '(lambda ( a b ) (grdraw a b 1 1))
                                       (setq lst
                                           (list pt1 pt2
                                               (trans (list (car pt6) (cadr pt6) (caddr pt5)) vec 1)
                                               (trans (list (car pt6) (cadr pt6) (caddr pt4)) vec 1)
                                       (cons (last lst) lst)
                                   (= 5 gr1)
                               (   (= 2 gr1)
                                   (cond
                                       (   (= 6 gr2)
                                           (if (zerop (logand 16384 (setq osm (setvar 'osmode (boole 6 16384 (getvar 'osmode))))))
                                               (princ "\n<Osnap on>")
                                               (princ "\n<Osnap off>")
                                           (princ msg)
                                       (   (= 8 gr2)
                                           (if (< 0 (strlen str))
                                               (progn
                                                   (princ "\010\040\010")
                                                   (setq str (substr str 1 (1- (strlen str))))
                                           t
                                       (   (< 32 gr2 127)
                                           (setq str (strcat str (princ (chr gr2))))
                                       (   (member gr2 '(13 32))
                                           (cond
                                               (   (= "" str) nil)
                                               (   (setq gr2 (LM:grsnap:parsepoint pt1 str))
                                                   (setq osm 16384)
                                                   nil
                                               (   (setq tmp (LM:grsnap:snapmode str))
                                                   (setq osm tmp
                                                         str ""
                                               (   (setq str "")
                                                   (princ (strcat "\n2D / 3D Point Required." msg))
                   (if (listp gr2)
                       (setq pt6 (trans (osf gr2 osm) 1 vec))
               (setq pt6 (trans pt3 1 vec))
       (entmake
           (list
              '(000 . "LWPOLYLINE")
              '(100 . "AcDbEntity")
              '(100 . "AcDbPolyline")
              '(090 . 4)
              '(070 . 1)
               (cons 010 (trans pt1 1 ocs))
               (cons 010 (trans pt2 1 ocs))
               (cons 010 (trans (list (car pt6) (cadr pt6) (caddr pt5)) vec ocs))
               (cons 010 (trans (list (car pt6) (cadr pt6) (caddr pt4)) vec ocs))
               (cons 210 ocs)
   (redraw) (princ)
;; Object Snap for grread: Snap Function  -  Lee Mac
;; Returns: [fun] A function requiring two arguments:
;; p - [lst] UCS Point to be snapped
;; o - [int] Object Snap bit code
;; The returned function returns either the snapped point (displaying an appropriate snap symbol)
;; or the supplied point if the snap failed for the given Object Snap bit code.
(defun LM:grsnap:snapfunction ( )
   (eval
       (list 'lambda '( p o / q )
           (list 'if '(zerop (logand 16384 o))
               (list 'if
                  '(setq q
                       (cdar
                           (vl-sort
                               (vl-remove-if 'null
                                   (mapcar
                                       (function
                                           (lambda ( a / b )
                                               (if (and (= (car a) (logand (car a) o)) (setq b (osnap p (cdr a))))
                                                   (list (distance p B) b (car a))
                                           (0001 . "_end")
                                           (0002 . "_mid")
                                           (0004 . "_cen")
                                           (0008 . "_nod")
                                           (0016 . "_qua")
                                           (0032 . "_int")
                                           (0064 . "_ins")
                                           (0128 . "_per")
                                           (0256 . "_tan")
                                           (0512 . "_nea")
                                           (2048 . "_app")
                                           (8192 . "_par")
                              '(lambda ( a b ) (< (car a) (car B)))
                   (list 'LM:grsnap:displaysnap '(car q)
                       (list 'cdr
                           (list 'assoc '(cadr q)
                               (list 'quote
                                   (LM:grsnap:snapsymbols
                                       (atoi (cond ((getenv "AutoSnapSize")) ("5")))
                       (LM:OLE->ACI
                           (if (= 1 (getvar 'cvport))
                               (atoi (cond ((getenv "Layout AutoSnap Color")) ("117761")))
                               (atoi (cond ((getenv  "Model AutoSnap Color")) ("104193")))
          '(cond ((car q)) (p))
;; Object Snap for grread: Display Snap  -  Lee Mac
;; pnt - [lst] UCS point at which to display the symbol
;; lst - [lst] grvecs vector list
;; col - [int] ACI colour for displayed symbol
;; Returns nil
(defun LM:grsnap:displaysnap ( pnt lst col / scl )
   (setq scl (/ (getvar 'viewsize) (cadr (getvar 'screensize)))
         pnt (trans pnt 1 2)
   (grvecs (cons col lst)
       (list
           (list scl 0.0 0.0 (car  pnt))
           (list 0.0 scl 0.0 (cadr pnt))
           (list 0.0 0.0 scl 0.0)
          '(0.0 0.0 0.0 1.0)
;; Object Snap for grread: Snap Symbols  -  Lee Mac
;; p - [int] Size of snap symbol in pixels
;; Returns: [lst] List of vector lists describing each Object Snap symbol
(defun LM:grsnap:snapsymbols ( p / -p -q -r a c i l q r )
   (setq -p (- p) q (1+  p)
         -q (- q) r (+ 2 p)
         -r (- r) i (/ pi 6.0)
          a 0.0
   (repeat 12
       (setq l (cons (list (* r (cos a)) (* r (sin a))) l)
             a (- a i)
   (setq c (apply 'append (mapcar 'list (cons (last l) l) l)))
   (list
       (list 1
           (list -p -p) (list p -p) (list p -p) (list p p) (list p p) (list -p p) (list -p p) (list -p -p)
           (list -q -q) (list q -q) (list q -q) (list q q) (list q q) (list -q q) (list -q q) (list -q -q)
       (list 2
           (list -r -q) (list 0  r) (list 0  r) (list r -q)
           (list -p -p) (list p -p) (list p -p) (list 0  p) (list 0  p) (list -p -p)
           (list -q -q) (list q -q) (list q -q) (list 0  q) (list 0  q) (list -q -q)
       (cons 4 c)
       (vl-list* 8 (list -r -r) (list r r) (list r -r) (list -r r) c)
       (list 16
           (list p 0) (list 0 p) (list 0 p) (list -p 0) (list -p 0) (list 0 -p) (list 0 -p) (list p 0)
           (list q 0) (list 0 q) (list 0 q) (list -q 0) (list -q 0) (list 0 -q) (list 0 -q) (list q 0)
           (list r 0) (list 0 r) (list 0 r) (list -r 0) (list -r 0) (list 0 -r) (list 0 -r) (list r 0)
       (list 32
           (list  r r) (list -r -r) (list  r q) (list -q -r) (list  q r) (list -r -q)
           (list -r r) (list  r -r) (list -q r) (list  r -q) (list -r q) (list  q -r)
       (list 64
           '( 0  1) (list  0  p) (list  0  p) (list -p  p) (list -p  p) (list -p -1) (list -p -1) '( 0 -1)
           '( 0 -1) (list  0 -p) (list  0 -p) (list  p -p) (list  p -p) (list  p  1) (list  p  1) '( 0  1)
           '( 1  2) (list  1  q) (list  1  q) (list -q  q) (list -q  q) (list -q -2) (list -q -2) '(-1 -2)
           '(-1 -2) (list -1 -q) (list -1 -q) (list  q -q) (list  q -q) (list  q  2) (list  q  2) '( 1  2)
       (list 128
           (list (1+ -p) 0) '(0 0) '(0 0) (list 0 (1+ -p))
           (list (1+ -p) 1) '(1 1) '(1 1) (list 1 (1+ -p))
           (list -p q) (list -p -p) (list -p -p) (list q -p)
           (list -q q) (list -q -q) (list -q -q) (list q -q)
       (vl-list* 256 (list -r r)  (list r r) (list -r (1+ r)) (list r (1+ r)) c)
       (list 512
           (list -p -p) (list  p -p) (list -p  p) (list p p) (list -q -q) (list  q -q)
           (list  q -q) (list -q  q) (list -q  q) (list q q) (list  q  q) (list -q -q)
       (list 2048
           (list   -p     -p) (list    p      p) (list   -p      p) (list    p     -p)
           (list (+ p 05) -p) (list (+ p 06) -p) (list (+ p 05) -q) (list (+ p 06) -q)
           (list (+ p 09) -p) (list (+ p 10) -p) (list (+ p 09) -q) (list (+ p 10) -q)
           (list (+ p 13) -p) (list (+ p 14) -p) (list (+ p 13) -q) (list (+ p 14) -q)
       (list 8192 (list r 1) (list -r -q) (list r 0) (list -r -r) (list r q) (list -r -1) (list r r) (list -r 0))
;; Object Snap for grread: Parse Point  -  Lee Mac
;; bpt - [lst] Basepoint for relative point input, e.g. @5,5
;; str - [str] String representing point input
;; Returns: [lst] Point represented by the given string, else nil
(defun LM:grsnap:parsepoint ( bpt str / str->lst lst )
   (defun str->lst ( str / pos )
       (if (setq pos (vl-string-position 44 str))
           (cons (substr str 1 pos) (str->lst (substr str (+ pos 2))))
           (list str)
   (if (wcmatch str "`@*")
       (setq str (substr str 2))
       (setq bpt '(0.0 0.0 0.0))
   (if
       (and
           (setq lst (mapcar 'distof (str->lst str)))
           (vl-every 'numberp lst)
           (< 1 (length lst) 4)
       (mapcar '+ bpt lst)
;; Object Snap for grread: Snap Mode  -  Lee Mac
;; str - [str] Object Snap modifier
;; Returns: [int] Object Snap bit code for the given modifier, else nil
(defun LM:grsnap:snapmode ( str )
   (vl-some
       (function
           (lambda ( x )
               (if (wcmatch (car x) (strcat (strcase str t) "*"))
                   (progn
                       (princ (cadr x)) (caddr x)
           ("endpoint"      " of " 00001)
           ("midpoint"      " of " 00002)
           ("center"        " of " 00004)
           ("node"          " of " 00008)
           ("quadrant"      " of " 00016)
           ("intersection"  " of " 00032)
           ("insert"        " of " 00064)
           ("perpendicular" " to " 00128)
           ("tangent"       " to " 00256)
           ("nearest"       " to " 00512)
           ("appint"        " of " 02048)
           ("parallel"      " to " 08192)
           ("none"          ""     16384)
;; OLE -> ACI  -  Lee Mac
;; Args: c - [int] OLE Colour
(defun LM:OLE->ACI ( c )
   (apply 'LM:RGB->ACI (LM:OLE->RGB c))
;; OLE -> RGB  -  Lee Mac
(defun LM:OLE->RGB ( c )
   (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(24 16 8))
;; RGB -> ACI  -  Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->ACI ( r g b / c o )
   (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
       (progn
           (setq c (vl-catch-all-apply '(lambda ( ) (vla-setrgb o r g B) (vla-get-colorindex o))))
           (vlax-release-object o)
           (if (vl-catch-all-error-p c)
               (prompt (strcat "\nError: " (vl-catch-all-error-message c)))
               c
;; Application Object  -  Lee Mac
;; Returns the VLA Application Object
(defun LM:acapp nil
   (eval (list 'defun 'LM:acapp 'nil (vlax-get-acad-object)))
   (LM:acapp)
(vl-load-com)
(princ
   (strcat
       "\n:: 3P-Rec.lsp | Version 1.0 | \\U+00A9 Lee Mac "
       (menucmd "m=$(edtime,0,yyyy)")
       " www.lee-mac.com ::"
       "\n:: \"3PR\" - Standard | \"3PRD\" - Dynamic ::"
