lecrabe Posté(e) le 8 novembre 2017 Posté(e) le 8 novembre 2017 Objet: ATTENTION: Probl ADSK et Cartes NVidia ! Hello 1) GRRR, il y a des plantages aleatoires "officiels" avec AutoCAD et les drivers NVidia ! RAPPEL: Parfois certains problemes etaient resolus en DESactivant le FXAA NVidia ...( qui d'ailleurs etait en principe DESactive en Standard ) 2) L'annonce officiel Autodesk du Mardi 07 Novembre 2017https://forums.autodesk.com/t5/autocad-forum/random-startup-crash-on-systems-with-nvidia-quadro-graphics/td-p/7524020 3) Deux autres articles a ce sujet :https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-products-will-have-a-random-application-startup-crash-on-systems-using-an-NVidia-Quadro-graphics-card.htmlhttps://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-error-at-every-startup.htmlLe probleme avait deja ete evoque en Mai 2017 ... 4) ==== En resume pour contourner/resoudre : ==== 41) DE-Installer l'Outil "NVidia View" (Solution temporaire !?) ou42) Installer le driver NVidia R384 U5 (385.90) du 06 Novembre 2017 :http://www.nvidia.com/download/driverResults.aspx/126788 5) Liste des cartes NVidia supportees par ce NOUVEAU driver R384 U5 (385.90) : ---- Quadro Series: ---- Quadro GP100, Quadro P6000, Quadro P5000, Quadro P4000, Quadro P2000, Quadro P1000, Quadro P600, Quadro P400, Quadro M6000 24GB, Quadro M6000, Quadro M5000, Quadro M4000, Quadro M2000, Quadro K6000, Quadro K5200, Quadro K5000, Quadro K4000, Quadro K4200, Quadro K2200, Quadro K2000, Quadro K2000D, Quadro K1200, Quadro K620, Quadro K600, Quadro K420, Quadro 410 ---- Quadro Series (Notebooks): ---- Quadro P5000, Quadro P4000, Quadro P3000, Quadro M2200, Quadro M1200, Quadro M620, Quadro M520, Quadro M5500, Quadro M5000M, Quadro M4000M, Quadro M3000M, Quadro M2000M, Quadro M1000M, Quadro M600M, Quadro M500M, Quadro K5100M, Quadro K5000M, Quadro K4100M, Quadro K4000M, Quadro K3100M, Quadro K2200M, Quadro K2100M, Quadro K3000M, Quadro K2000M, Quadro K1100M, Quadro K1000M, Quadro K620M, Quadro K610M, Quadro K510M, Quadro K500M, Quadro 5000M, Quadro 2000M ---- Quadro Blade/Embedded Series : ---- Quadro P5000, Quadro P3000, Quadro M5000 SE, Quadro M3000 SE, Quadro K3100M ---- Quadro NVS Series: ----NVS 810, NVS 510, NVS 315, NVS 310 ---- Quadro NVS Series (Notebooks): ---- NVS 5400M, NVS 5200M, NVS 4200M ---- NVS Series: ---- NVS 810, NVS 510, NVS 315, NVS 310 ---- NVS Series (Notebooks): ---- NVS 5400M, NVS 5200M, NVS 4200M DONC si votre carte NVidia n'est pas dans la liste ... DOMMAGE ! Bye, lecrabe PS: si vous etes sous Windows Seven / 8.x alors il faudra utiliser CE driver :http://www.nvidia.fr/download/driverResults.aspx/126820/fr Autodesk Expert Elite Team
Invité Martial56 Posté(e) le 8 novembre 2017 Posté(e) le 8 novembre 2017 Merci de l'info mais le driver n'est pas non compatible avec windows 7 64x martial
lecrabe Posté(e) le 8 novembre 2017 Auteur Posté(e) le 8 novembre 2017 Hello 1) YES ! 2) Voir cela ... PS: si vous etes sous Windows Seven / 8.x alors il faudra utiliser CE driver :http://www.nvidia.fr/download/driverResults.aspx/126820/fr Bye, lecrabe Autodesk Expert Elite Team
