CadFrank Posté(e) le 11 septembre 2017 Posté(e) le 11 septembre 2017 Bonjour, J'essai de changer la valeur text d'un attribut qui contient un Field. Par contre, quand ma commande terminer j'obtien un field "####" public class Class { private const string BLOCKNAME = "SOL PL"; private const string TAG_COUNT = "LONG"; private const string TAG_SPACING = "ESPACEMENT"; private const string PREFIX = "%<\\AcObjProp Object(%<\\_ObjId "; private const string SUFFIX = ">%).Parameter(39).lookupString>%"; private string id; //private string textString; private int joistCount; private int spacing; enum DrawingUnit { Imperial, Metrique } [CommandMethod("CS", CommandFlags.UsePickSet)] public void CalculSolives() { Document document = Active.Document; Database database = Active.Database; Editor editor = Active.Editor; PromptSelectionResult psResults = editor.SelectImplied(); if (psResults.Status == PromptStatus.Error) { // Adds options to the Results. PromptSelectionOptions psOptions = new PromptSelectionOptions(); psOptions.MessageForAdding = "\nSélectionner les solives à calculer : "; // this captures the prompt values of the selected object psResults = editor.GetSelection(psOptions); } if (psResults.Status == PromptStatus.OK) { PromptDoubleResult pdResult = editor.GetDistance("Pour la distance utilisé par la/les solive(s). Choisir deux point. :"); double distance = pdResult.Value; using (var transaction = database.TransactionManager.StartTransaction()) { ObjectId[] objIDs = psResults.Value.GetObjectIds(); foreach (ObjectId objID in objIDs) { RXClass attClass = RXClass.GetClass(typeof(BlockReference)); if (objID.ObjectClass.IsDerivedFrom(attClass)) { BlockReference blockReference = transaction.GetObject(objID, OpenMode.ForRead) as BlockReference; AttributeCollection attCollection = blockReference.AttributeCollection; foreach (ObjectId attId in attCollection) { AttributeReference attReference = transaction.GetObject(attId, OpenMode.ForRead) as AttributeReference; if (attReference.Tag == TAG_SPACING) { spacing = getSpacing(attReference); } if (attReference.Tag == TAG_COUNT || attReference.HasFields == true) { ObjectId fieldId = attReference.GetField(); attReference.UpgradeOpen(); id = fieldId.ToString(); id = id.TrimStart('('); id = id.TrimEnd(')'); joistCount = CalculerSolives(spacing, distance); string newString = {:content:}quot;({joistCount}) P.ALU {PREFIX}{id}{SUFFIX}"; attReference.TextString = newString; } } } } transaction.Commit(); editor.Regen(); } } } private int getSpacing(AttributeReference attReference) { int spacing = 0; string textString = attReference.TextString; int index = textString.IndexOf('"'); textString = textString.Substring(2, index - 2); textString = @textString.Trim('"', 'c', '/'); try { spacing = Convert.ToInt32(textString); } catch (Exception) { Active.WriteMessage("Couldn't convert to int..."); } if (CheckDrawingUnit() == DrawingUnit.Metrique) { switch (spacing) { case 8: spacing = 200; break; case 10: spacing = 250; break; case 12: spacing = 300; break; case 16: spacing = 400; break; case 19: spacing = 490; break; } } return spacing; } private DrawingUnit CheckDrawingUnit() { if (Application.GetSystemVariable("DIMLUNIT").Equals(4)) { return DrawingUnit.Imperial; } else { return DrawingUnit.Metrique; } } public int CalculerSolives(int espacement, double distance) { double nombreSolives = distance / espacement; Math.Round(nombreSolives, 0, MidpointRounding.ToEven); return Convert.ToInt32(nombreSolives); } public Field getField(Transaction tr, AttributeReference attReference) { if (attReference.HasFields) { Field field = Active.Database.TransactionManager.GetObject(attReference.GetField(), OpenMode.ForRead) as Field; return field; } return null; } } public static class Active { /// <summary> /// Returns the active Editor object. /// </summary> public static Document Document => Application.DocumentManager.MdiActiveDocument; /// <summary> /// Returns the active Database object. /// </summary> public static Database Database => Document.Database; /// <summary> /// Returns the active Editor object. /// </summary> public static Editor Editor => Document.Editor; /// <summary> /// Sends a string to the command line in the active Editor /// </summary> /// <param name="message">The message to send.</param> public static void WriteMessage(string message) => Editor.WriteMessage(message); /// <summary> /// Sends a string to the command line in the active Editor using String.Format. /// </summary> /// <param name="message">The message containing format specifications.</param> /// <param name="parameter">The variables to substitute into the format string.</param> public static void WriteMessage(string message, params object[] parameter) => Editor.WriteMessage(message, parameter); }
CadFrank Posté(e) le 11 septembre 2017 Auteur Posté(e) le 11 septembre 2017 Je ne suis pas capable d'y ajouter mon block malheureusement.
x_all Posté(e) le 12 septembre 2017 Posté(e) le 12 septembre 2017 Je ne suis pas capable d'y ajouter mon block malheureusement. Il faut faire par wetransfert ou grosfichiers.com ... pour confirmer... un field, c'est un champ? quelques trucs sur autocad
CadFrank Posté(e) le 12 septembre 2017 Auteur Posté(e) le 12 septembre 2017 Il faut faire par wetransfert ou grosfichiers.com ... pour confirmer... un field, c'est un champ? Oui un Field est un champ, dsl mon AutoCAD est en anglais Mon block
CadFrank Posté(e) le 12 septembre 2017 Auteur Posté(e) le 12 septembre 2017 Finalement, j'avais pas a toucher au Field. AttReference.TextString = NewString + AttReference.TextString Sa marche sans défaire mon field... Merci quand meme.
