EmarceL Posté(e) le 17 septembre 2015 Posté(e) le 17 septembre 2015 Bonjour, je fais des petites routines lisp depuis quelques temps deja, mais "à l'ancienne" et je vois bien que je vais pas tarder à etre déborder car je ne comprends pas grand chose au (VL truc.Est ce que quelqu'un pourrait me transcrire ce petit lisp ci-dessous afin que je commence à mettre les mains dedans.D'avance merci. ;; ========================= ISO: creer une vue iso d'un plan =================================;; ;; Iso (Eric MARCEL @ TECKNING) ;; Création d'une vue iso à partir des éléments sélectionnés. (defun c:ISO (/ angi nombloc);;entites pdb ang angi nombloc pdi ) (princ "\n VUE EN PLAN ----> VUE ISO") (setvar "cmdecho" 0) (if a (setq a a) (setq a 0)) (if b (setq b B) (setq b 0)) (if c (setq c c) (setq c 0)) (if d (setq d d) (setq d 0)) (command "-purger" "b" "DVN" "N") (setq entites (ssget)) (setq pdb (getpoint "\nPoint d'insertion: ")) (setq pdi(strcat(rtos(car pdb)) "," (rtos(cadr pdb)))) (setq ang (getstring "\nPoint de vue iso [sO] [NO] [NE] [sE]: ")) (cond ((= ang "SO") (setq angi 45.0 a (1+ a) i a)) ((= ang "so") (setq angi 45.0 a (1+ a) i a)) ((= ang "NO") (setq angi 135.0 b (1+ B) i B)) ((= ang "no") (setq angi 135.0 b (1+ B) i B)) ((= ang "NE") (setq angi 225.0 c (1+ c) i c)) ((= ang "ne") (setq angi 225.0 c (1+ c) i c)) ((= ang "SE") (setq angi 315.0 d (1+ d) i d)) ((= ang "se") (setq angi 315.0 d (1+ d) i d)) ) (princ) (if ( = ang "") (setq ang "SE" d (1+ d) i d angi 315.0 ) ) (command "_copy" entites "" pdi "@") (command "-bloc" "DVN" pdi entites "") (command "-inserer" "DVN" pdi "1" "1" angi) (command "decompos" "D" ) (command "-purger" "b" "DVN" "N") (command "-bloc" "DVN" pdi "p" "") (command "-inserer" "DVN" pause "1" "0.5774" "0") (setq nombloc (strcat "Iso_"(strcat (strcase ang )"-"(itoa i)))) (while (tblsearch "BLOCK" nombloc ) (progn (setq i (1+ i)) (setq nombloc (strcat "Iso_"(strcat (strcase ang )"-"(itoa i)))) ) () ) (command "-renommer" "b" "DVN" nombloc) (prompt (strcat "bloc " nombloc " créé ! © TECKNING")) (princ) ) ;; =====================================================================================
