merci pour le lien
je suis de Rouen en Seine Maritime et cela me donne plusieurs resultat
EPSG:4326 WGS84 1.01632 49.34336
EPSG:3857 WGS84 / Pseudo Mercator 113136.35649 6300869.61303
EPSG:3395 WGS 84 / World Mercator 113136.35649 6300890.41703
EPSG:32662 WGS 84 / Plate Carree 113136.35649 5492877.21373
EPSG:2154 RGF93 / Lambert-93 555825.25397 6917788.68340
EPSG:3942 Lambert Zone 1 (CC42) 1554637.98879 2020095.95842
EPSG:3943 Lambert Zone 2 (CC43) 1554958.82374 2908224.91869
EPSG:3944 Lambert Zone 3 (CC44) 1555230.21794 3796561.24169
EPSG:3945 Lambert Zone 4 (CC45) 1555453.08517 4685067.52793
EPSG:3946 Lambert Zone 5 (CC46) 1555628.32649 5573706.98173
EPSG:3947 Lambert Zone 6 (CC47) 1555756.83335 6462443.42030
EPSG:3948 Lambert Zone 7 (CC48) 1555839.49063 7351241.28628
EPSG:3949 Lambert Zone 8 (CC49) 1555877.17998 8240065.66377
EPSG:3950 Lambert Zone 9 (CC50) 1555870.78321 9128882.29836
EPSG:27561 Lambert Nord France 504081.69206 183429.63128
EPSG:27562 Lambert Centre France 503985.79936 483674.04496
EPSG:27563 Lambert Sud France 503666.62265 784418.31981
EPSG:27564 Lambert Corse -96478.12031 986569.98656
EPSG:27571 Lambert Zone I 504081.69206 1183429.63128
EPSG:27572 Lambert Zone II / Lambert 2 étendu 503985.79936 2483674.04496
EPSG:27573 Lambert Zone III 503666.62265 3784418.31981
EPSG:27574 Lambert Zone IV -96478.12031 4986569.98656
EPSG:23030 ED50 - UTM Zone 30 Nord 791712.34493 5473587.86818
EPSG:23031 ED50 - UTM Zone 31 Nord 355908.52492 5467718.14241
EPSG:23032 ED50 - UTM Zone 32 Nord -79652.89080 5496555.25562
EPSG:32630 WGS84 - UTM Zone 30 Nord 791703.29014 5473388.17491
EPSG:32631 WGS84 - UTM Zone 31 Nord 355912.99959 5467518.70281
EPSG:32632 WGS84 - UTM Zone 32 Nord -79634.93072 5496354.57110
IGNF: GEOPORTALFXX Geoportail - France metropolitaine 77877.92867 5492877.21373
lequel je prends dans autocad
1) NON
2) Idee 1 : passer le DWG a qq'un qui a un AutoCAD 2015 (ou LT 2015)
et qui avec TON DWG et tes Infos, va capturer l'Image Bingmaps en haute resolution
et ensuite tu recuperes le DWG ...
3) Capturer l'ecran AutoCAD 2014 en haute resolution, cela pourrait suffire pour du A4 (peut etre A3) ...
Bon WE, Bye, lecrabe
En ayant renseigné tes infos sur système de projection dans AutoCAD 14 MAP (tu peux t'aider du site "Mais quelle est cette projection" Ici pour le connaitre).
Tu peux faire apparaître la cartographie Bing en arrière plan avec la commande "GEOCARTE" si tu te connecte à AutoDesk 360 et seulement si tu as MAP.
Je pense aussi que dans ta zone, tu peux avoir du CC49 comme projection.
Après, tu peux toujours poster ton fichier, on se fera un plaisir de t'aider...
Denis...
Windows 11 / AutoCAD 2024
En effet, le Lambert 93 est recommandé.
On a le Lambert 93 qui comprend toute la france
et les coniques conformes qui sont plus précis si on imprime et mesure ces impressions car l'altération linéaire est faible. ( voir ici) et sont destinés au plans à très grande echelle (1/500 1/200 )
Tout dépend de l'étendu de ce projet, si tu es ammené à "sortir" du département, alors Lambert 93.
un doc explicatif en prime
NB pour denish : en seine maritime, le cc50 est recommandé
LrDb
write a book about what ??
Merci lrdb@home,
je ne voyais pas ce département si haut...
Denis...
Bonjour à toutes et tous,
A priori, c'est le donneur d'ordre qui te précises sur quel système tu dois te rattacher,...
Si il y à une Modification du parcellaire cadastrale, alors la projection obligatoire est le Lambert 9 zones, ...(Emprise supérieure à 500 ml ou 1 ha => Arrété interministériel de 2003)
Si c'est pour faire un projet linéaire sur plusieurs zones, préfère le Lambert 93 alors,..(Pour ne pas dire, obligatoire, car le passage d'une zone à une autre est délicat sur le système CC 9 zones,...).
Bien entendu, ces choix sont aussi directement liè à la précision recherchée sur le chantier,..
Une fois de plus, il n'y a pas de réponse à cette question, cela dépend des objectifs du dossier en question,...
Civil 3D 2025 - COVADIS_18.3d
bonjour a tous
en faite je dois juste faire des cercles de rayon 10,20,30,40,50,60 et 70 kilometres pour definir des zones de deplacements. Vraiment rien de compliquer en soi mais n'etant pas du tout dans le domaine des cartes.
je vais egalement faire un essai avec le CC49 ET CC50
mais je pense que je vais rester en Lambert93 car cela concerne plusieur departement, le 76,27,14,61 et le 50
en tout cas merci pour vos precieux renseignements
a+
