dol Posté(e) le 26 novembre 2004 Posté(e) le 26 novembre 2004 salut a tousje suis sur autocad 2005ce lisp sert a transformer un dxf en dwg automatiquement qq1 peux m'aider sur ce lisp il ne marche pas. ; - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -(defun NOEXT(chaine); - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - (setq ct 1 len (strlen chaine))(while (and (/= "." (substr chaine ct 1)) (<= ct len) );fin and (setq ct (1+ ct)));fin while(substr chaine 1 (- ct 1)));fin defun ;****************************************************************************************;************** PERMET DE CHANGER DES FICHIERS *****************************;************* DXF EN DWG ****************************;************ ***************************;*********** *************************;**************************************************************************************** ;------------------------------------------------------------------------(defun C:chdxf();/ rep dos s f ligne lst nom ;------------------------------------------------------------------------(initget "Oui Non")(setq choix (getkword "\nVoulez-vous un repertoire specifique (Oui ou Non) : "))(if (= choix "Oui") (progn (setq rep (getstring T "\nRépertoire de recherche: ") ) );fin progn (progn (setq rep (getvar "dwgprefix") lg (strlen rep) rep (substr rep 1 (- lg 1)) ) );fin progn);fin de if (dos_command (strcat "dir " rep "\\*.dxf/b/on>" rep "\\listdxf") 8) (princ) (setq lst nil s (open (strcat rep "\\dxf.scr") "w") f (open (strcat rep "\\listdxf") "r") );fin setq (while (setq ligne (read-line f)) (setq lst (append lst (list ligne))) );fin while(foreach x lst (setq nom (NOEXT x)) (write-line "_NEW" s) (write-line (strcat nom "=") s) (write-line "_DXFIN" s) (write-line (strcat rep "\\" nom) s) (write-line "zoom et" s) (write-line "FILEDIA 1" s) (write-line "CMDDIA 1" s) (write-line "CMDECHO 1" s) (write-line "ATTREQ 1" s) (write-line "SAUVENOM 2000" s) ;(write-line "2000" s) (write-line (strcat rep "\\" nom) s));fin foreach(princ "\n") (close s) (close f) (setq ecr (strcat rep "\\dxf"))(command "script" ecr)(princ) );fin defun merci a vous [Edité le 27/11/2004 par dol]
Oli553 Posté(e) le 26 novembre 2004 Posté(e) le 26 novembre 2004 A quoi est il destiné?Merci L'urgent est fait, l'impossible est en cours. Pour les miracles, prévoir un délai. "Il vaut mieux mobiliser son intelligence sur des conneries, que sa connerie sur des choses intelligentes" - Devise Shadok. "ceux qui ne se souviennent pas du passé sont condamnés à le revivre" George Santayana Ma bibliothèque de blocs électrique :symbole elec.dwg
dol Posté(e) le 26 novembre 2004 Auteur Posté(e) le 26 novembre 2004 a transformer des dxf en dwg automtiquement
rebcao Posté(e) le 27 novembre 2004 Posté(e) le 27 novembre 2004 Bonjour Dol, j'ai un peu de mal à comprendre l'intérêt !!! :casstet: Tu peux ouvrir un DXF et l'enregistrer sous DWG sans faire de bidouille LISP :P Où il manque quelques explications... Merci de ta réponse Christian Formateur, Consultant Expert AutoCAD, REVIT MEP, INVENTOR, télécharger , des Outils AutoCAD...cad123 @ wanadoo.fr (enlever les espaces de part et d'autre de @)
BIM G CO Posté(e) le 3 décembre 2004 Posté(e) le 3 décembre 2004 en visualisant 5 sec j'ai cru comprendre qu'il cherche à lister les dxf d'un dossier qu'il créé un scrip qui les ouvre un à un et qu'il les sauve en dwg 2000. Perso "dos_command" je ne connais pas Dessinateur AutoCAD, Modeleur BIM, consultant informatique logiciels métier Lenovo ThinkStation i9 14800K 64Gb RAM 2x1To SSD GstarCAD, Fisa-CAD, Revit, FisaBIM CVC, Microsoft Office PlaquetteDeplianteMars2024.pdf
rebcao Posté(e) le 3 décembre 2004 Posté(e) le 3 décembre 2004 si c'est effectivement ça ! il y aurait moyen d'utiliser le générateur de SCRIPT de ce sujet... Il y a juste à aller dans le dossier concerné, un double clic sur un fichier et dans AutoCAD on lance le SCRIPT... à voir... Christian Formateur, Consultant Expert AutoCAD, REVIT MEP, INVENTOR, télécharger , des Outils AutoCAD...cad123 @ wanadoo.fr (enlever les espaces de part et d'autre de @)
