ACAD 2012 et le DOTNET v4.5 : Probleme Install
Pour ceux qui tentent d'installer de l'AutoCAD 2012 (ou version Metier basee sur AutoCAD 2012)
sur un PC ayant le DOTNET v4.5 installe ...
lecrabe
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22110233&linkID=9240617
Published date: 2013-Aug-06 - ID: TS22110233 - Applies to: AutoCAD 2012
------ AutoCAD 2012 installation fails on machine with NET 4.5 ------
You want to install AutoCAD 2012 on a machine that has NET 4.5
Solution :
AutoCAD 2012 tries to install NET 4.0 but fails because NET 4.5 is already installed
--- To resolve this problem, you can
Remove NET 4.5 and let the program install NET 4.0. (This is not always an option.)
Remove the NET requisites from the Setup.ini file.
Note: Adjusting the Setup.ini file from an existing deployment will NOT work.
--- To remove NET requisites from Setup.ini:
1 - Back up the original Setup.ini file from within the extracted installation folder
2 - Locate the line:
PREREQUISITE=IE;SSE2;DOTNET20;DOTNET4;DOTNET4LANG;etc ...
3 - Delete DOTNET20;DOTNET4;DOTNET4LANG and save the file
4 - Install or build a new deployment with the removed NET requisites
This prevents 2012 from installing NET 4.0 and allows installation on a machine with NET 4.5
Note: If you have problems later, remember that AutoCAD 2012 was built for 4.0, not 4.5
You may need to install NET 4.0
