J'utilise ce code pour effectuer mon tracé en PDF.
// (C) Copyright 2013 by
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.PlottingServices;
using System.IO;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(TestPlot.MyCommands))]
namespace TestPlot
   // This class is instantiated by AutoCAD for each document when
   // a command is called by the user the first time in the context
   // of a given document. In other words, non static data in this class
   // is implicitly per-document!
   public class MyCommands
       [CommandMethod("PlotEx")]
       public void PlotEx()
           Application.SetSystemVariable("BACKGROUNDPLOT", 0);
           using (Transaction tr = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction())
               try
                   LayoutManager layMgr = LayoutManager.Current;
                   ObjectId loObjId = layMgr.GetLayoutId(layMgr.CurrentLayout);
                   Layout lo = (Layout)tr.GetObject(loObjId, OpenMode.ForRead);
                   PlotSettings ps = new PlotSettings(lo.ModelType);
                   ps.CopyFrom(lo);
                   PlotInfo pi = new PlotInfo();
                   pi.Layout = loObjId;
                   PlotSettingsValidator psv = Autodesk.AutoCAD.DatabaseServices.PlotSettingsValidator.Current;
                   psv.SetPlotConfigurationName(ps, "DWG To PDF.pc3", "ANSI_B_(11.00_x_17.00_Inches)");
                   psv.RefreshLists(ps);
                   psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                   psv.SetUseStandardScale(ps, true);
                   psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                   pi.OverrideSettings = ps;
                   PlotEngine pe = PlotFactory.CreatePublishEngine();
                   try
                       pe.BeginPlot(null, null);
                       PlotInfoValidator validator = new PlotInfoValidator();
                       validator.MediaMatchingPolicy = Autodesk.AutoCAD.PlottingServices.MatchingPolicy.MatchEnabled;
                       validator.Validate(pi);
                       string plotFile = Path.GetFullPath(Application.DocumentManager.MdiActiveDocument.Database.Filename);
                       plotFile = plotFile.Remove(plotFile.Length - 4);
                       pe.BeginDocument(pi, Application.DocumentManager.MdiActiveDocument.Database.Filename, null, 1, true, plotFile + ".pdf");
                       PlotPageInfo pageInfo = new PlotPageInfo();
                       pe.BeginPage(pageInfo, pi, true, null);
                       pe.BeginGenerateGraphics(null);
                       pe.EndGenerateGraphics(null);
                       pe.EndPage(null);
                       pe.EndDocument(null);
                       pe.EndPlot(null);
                   catch (System.Exception ex)
                       System.Windows.Forms.MessageBox.Show(ex.Message);
                   pe.Destroy();
                   tr.Commit();
Tel quel il fontionne correctement.
Le problème survient quand je veux utiliser un format de papier personalisé.
J'obtient un message d'erreur m'indiquant que j'ai fournis une valeur invalide.
Quelqu'un à t'il déja rencontré ce problème ?
Merci d'avance.
http://www.carpetdiem.net
Plugins pour AutoCAD
Tu trouveras sur TheSwamp un exemple qui utilise un fichier DSD temporaire (équivalent à la commande publier) et prend en compte le format de papier spécifié dans le gestionnaire du tracé de la (ou des) présentation(s).
Cet exemple permet de créer un fichier PDF multi-feuilles, mais peut très bien ne tracer qu'une seule présentation.
