becobec Posté(e) le 4 août 2011 Posté(e) le 4 août 2011 bonjour je cherche à faire fonctionner cette macro de wf2 sur la wf5 (creo/elements).elle bloque au moment de la selection, tres pratique pour créé des parametre sur une piece dans un ass. mercie d'avance javascript:insertAtCaret(':D','') new_parameter_ui yesmapkey bb @MAPKEY_LABELCREER BALLOON DEG;\mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_pref`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Select `preferences` `AssyTree`1 `node0:new_parameter_ui : yes : 1`;\mapkey(continued) ~ Open `preferences` `EditPanel`;~ Close `preferences` `EditPanel`;\mapkey(continued) ~ Select `preferences` `EditPanel`1 `no`;~ Activate `preferences` `AddOpt`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;~ Activate `preferences` `ApplySave`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;~ Activate `preferences` `Close`;\mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_params`;#COMPONENT;\mapkey(continued) @MANUAL_PAUSECHOISISSEZ LE COMPOSANT;\mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree`1 `node241`;#CREATE;#STRING;\mapkey(continued) REP_DEG;;#STRING;DEG;;#DESIGNATE;#PARAMETERS;#REP_DEG;\mapkey(continued) #DEG;#DONE SEL;#MODIFY;#REP_DEG;#MODIFY;#DEG;#DONE/RETURN;#DONE/RETURN;\mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_pref`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Select `preferences` `AssyTree`1 `node0:new_parameter_ui : no : 1`;\mapkey(continued) ~ Open `preferences` `EditPanel`;~ Close `preferences` `EditPanel`;\mapkey(continued) ~ Select `preferences` `EditPanel`1 `yes *`;\mapkey(continued) ~ Activate `preferences` `AddOpt`;~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Activate `preferences` `ApplySave`;~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Activate `preferences` `Close`;
hoppla Posté(e) le 4 août 2011 Posté(e) le 4 août 2011 Ce sujet a été posté 2x par erreur.Merci d'utiliser le post original pour vos réponses http://www.cadxp.com/modules.php?op=modload&name=XForum&file=viewthread&tid=33912
