becobec Posté(e) le 4 août 2011 Posté(e) le 4 août 2011 bonjour je cherche à faire fonctionner cette macro de wf2 sur la wf5 (creo/elements).elle bloque au moment de la selection, tres pratique pour créé des parametre sur une piece dans un ass. mercie d'avance javascript:insertAtCaret(':D','') new_parameter_ui yesmapkey bb @MAPKEY_LABELCREER BALLOON DEG;\mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_pref`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Select `preferences` `AssyTree`1 `node0:new_parameter_ui : yes : 1`;\mapkey(continued) ~ Open `preferences` `EditPanel`;~ Close `preferences` `EditPanel`;\mapkey(continued) ~ Select `preferences` `EditPanel`1 `no`;~ Activate `preferences` `AddOpt`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;~ Activate `preferences` `ApplySave`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;~ Activate `preferences` `Close`;\mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_params`;#COMPONENT;\mapkey(continued) @MANUAL_PAUSECHOISISSEZ LE COMPOSANT;\mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree`1 `node241`;#CREATE;#STRING;\mapkey(continued) REP_DEG;;#STRING;DEG;;#DESIGNATE;#PARAMETERS;#REP_DEG;\mapkey(continued) #DEG;#DONE SEL;#MODIFY;#REP_DEG;#MODIFY;#DEG;#DONE/RETURN;#DONE/RETURN;\mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_pref`;\mapkey(continued) ~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Select `preferences` `AssyTree`1 `node0:new_parameter_ui : no : 1`;\mapkey(continued) ~ Open `preferences` `EditPanel`;~ Close `preferences` `EditPanel`;\mapkey(continued) ~ Select `preferences` `EditPanel`1 `yes *`;\mapkey(continued) ~ Activate `preferences` `AddOpt`;~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Activate `preferences` `ApplySave`;~ FocusOut `preferences` `InputOpt`;\mapkey(continued) ~ Activate `preferences` `Close`;
hoppla Posté(e) le 4 août 2011 Posté(e) le 4 août 2011 Lorsqu'une macro ne passe plus après un changement de version, le plus simple est généralement de la refaire plutôt que de chercher à la corriger... Ceci dit, si le besoin est de créer automatiquement des paramètres sur les composants d'un assemblage il y a 2 méthodes très intéressantes: 1) Afficher les paramètres dans l'arbre du modèle: il suffit ensuite de cliquer dans les cases non documentées pour créer automatiquement les paramètres dans les bons composants. 2) Lancer ModelCheck pour créer (et éventuellement désigner) automatiquement autant de paramètres que souhaité dans chacune des pièces de l'assemblage.
becobec Posté(e) le 8 août 2011 Auteur Posté(e) le 8 août 2011 Salut koppla le probleme je n'arrive pas à afficher les parametre composant dans l'arbre du model. y-a-t-il ne manipulation spécial.
