La fonction Brust sans les express tool
Bonjour
Je cherche a extraire de bloc le texte
j'ai vu sur le Forum qu'il existe la fonction Brust
Mais je n'ai pas les express tool d'installer
alors , existe t'il un autre moyen ou un lisp pour faire la meme chose
Merci d'avance
Ps pour info, il m'est impossible de faire installer les express tool
Le lsp en question:
;;;    BURST.LSP
;;;    Copyright © 1999-2006 by Autodesk, Inc.
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
(Defun C:BURST (/ item bitset bump att-text lastent burst-one burst
                 BCNT BLAYER BCOLOR ELAST BLTYPE ETYPE PSFLAG ENAME )
  ; Item from association list
  (Defun ITEM (N E) (CDR (Assoc N E)))
  ; Error Handler
 (acet-error-init
   (list
     (list "cmdecho" 0
           "highlight" 1
     T     ;flag. True means use undo for error clean up.
   );list
 );acet-error-init
  ; BIT SET
  (Defun BITSET (A B) (= (Boole 1 A B) B))
  ; BUMP
  (Setq bcnt 0)
  (Defun bump (prmpt)
     (Princ
        (Nth bcnt '("\r-" "\r\\" "\r|" "\r/"))
     (Setq bcnt (Rem (1+ bcnt) 4))
  ; Convert Attribute Entity to Text Entity or MText Entity
  (Defun ATT-TEXT (AENT / ANAME TENT ILIST INUM)
     (setq ANAME (cdr (assoc -1 AENT)))
     (if (_MATTS_UTIL ANAME)
        (progn
           ; Multiple Line Text Attributes (MATTS) -
           ; make an MTEXT entity from the MATTS data
           (_MATTS_UTIL ANAME 1)
        (progn
           ; else -Single line attribute conversion
           (Setq TENT '((0 . "TEXT")))
           (ForEach INUM '(8
                           6
                           38
                           39
                           62
                           67
                           210
                           10
                           40
                           1
                           50
                           41
                           51
                           7
                           71
                           72
                           73
                           11
                           74
              (If (Setq ILIST (Assoc INUM AENT))
                  (Setq TENT (Cons ILIST TENT))
           (Setq
              tent (Subst
                      (Cons 73 (item 74 aent))
                      (Assoc 74 tent)
                      tent
           (EntMake (Reverse TENT))
  ; Find True last entity
  (Defun LASTENT (/ E0 EN)
     (Setq E0 (EntLast))
     (While (Setq EN (EntNext E0))
        (Setq E0 EN)
     E0
  ; See if a block is explodable. Return T if it is,
  ; otherwise return nil
  (Defun EXPLODABLE (BNAME / B expld)
     (vl-load-com)
     (setq BLOCKS (vla-get-blocks
                    (vla-get-ActiveDocument (vlax-get-acad-object)))
     (vlax-for B BLOCKS (if (and (= :vlax-false (vla-get-islayout B))
                                 (= (strcase (vla-get-name B)) (strcase BNAME)))
                     (setq expld (= :vlax-true (vla-get-explodable B)))
      expld
  ; Burst one entity
  (Defun BURST-ONE (BNAME / BENT ANAME ENT ATYPE AENT AGAIN ENAME
                    ENT BBLOCK SS-COLOR SS-LAYER SS-LTYPE mirror ss-mirror
                    mlast)
     (Setq
        BENT   (EntGet BNAME)
        BLAYER (ITEM 8 BENT)
        BCOLOR (ITEM 62 BENT)
        BBLOCK (ITEM 2 BENT)
        BCOLOR (Cond
                  ((> BCOLOR 0) BCOLOR)
                  ((= BCOLOR 0) "BYBLOCK")
                  ("BYLAYER")
        BLTYPE (Cond ((ITEM 6 BENT)) ("BYLAYER"))
     (Setq ELAST (LASTENT))
     (If (and (EXPLODABLE BBLOCK) (= 1 (ITEM 66 BENT)))
        (Progn
           (Setq ANAME BNAME)
           (While (Setq
                     ANAME (EntNext ANAME)
                     AENT  (EntGet ANAME)
                     ATYPE (ITEM 0 AENT)
                     AGAIN (= "ATTRIB" ATYPE)
              (bump "Converting attributes")
              (ATT-TEXT AENT)
        (Progn
           (bump "Exploding block")
           (acet-explode BNAME)
           ;(command "_.explode" bname)
     (Setq
        SS-LAYER (SsAdd)
        SS-COLOR (SsAdd)
        SS-LTYPE (SsAdd)
        ENAME    ELAST
     (While (Setq ENAME (EntNext ENAME))
        (bump "Gathering pieces")
        (Setq
           ENT   (EntGet ENAME)
           ETYPE (ITEM 0 ENT)
        (If (= "ATTDEF" ETYPE)
           (Progn
              (If (BITSET (ITEM 70 ENT) 2)
                 (ATT-TEXT ENT)
              (EntDel ENAME)
           (Progn
              (If (= "0" (ITEM 8 ENT))
                 (SsAdd ENAME SS-LAYER)
              (If (= 0 (ITEM 62 ENT))
                 (SsAdd ENAME SS-COLOR)
              (If (= "BYBLOCK" (ITEM 6 ENT))
                 (SsAdd ENAME SS-LTYPE)
     (If (> (SsLength SS-LAYER) 0)
        (Progn
           (bump "Fixing layers")
           (Command
              "_.chprop" SS-LAYER "" "_LA" BLAYER ""
     (If (> (SsLength SS-COLOR) 0)
        (Progn
           (bump "Fixing colors")
           (Command
              "_.chprop" SS-COLOR "" "_C" BCOLOR ""
     (If (> (SsLength SS-LTYPE) 0)
        (Progn
           (bump "Fixing linetypes")
           (Command
              "_.chprop" SS-LTYPE "" "_LT" BLTYPE ""
  ; BURST MAIN ROUTINE
  (Defun BURST (/ SS1)
     (setq PSFLAG (if (= 1 (caar (vports)))
                      1 0
     (Setq SS1 (SsGet (list (cons 0 "INSERT")(cons 67 PSFLAG))))
     (If SS1
        (Progn
           (Setvar "highlight" 0)
           (terpri)
           (Repeat
              (SsLength SS1)
              (Setq ENAME (SsName SS1 0))
              (SsDel ENAME SS1)
              (BURST-ONE ENAME)
           (princ "\n")
  ; BURST COMMAND
  (BURST)
 (acet-error-restore)
);end defun
J'ai bien peur que de fournir le lisp ne soit pas suffisant pour qu'il fonctionne.
Il fait certainement appel à des fonctions contenu dans la bibliothèque des ExpressTools.
Donc si ceux-ci ne sont pas installé, retour au point de départ...
Bonjour
désole, pour la réponse tardive
Je viens de faire le test et effectivement j'ai une erreur du type
; erreur: no function definition: ACET-ERROR-INIT
enfin un grand merci tout de même
Cordialement
