decaler automatique
Utilisant l'outil DECALER à outrance lorsque je dessine du batiment, j'utilise ces raccourcis.
(defun c:1 (/)
(command "_offset" "1")
(princ))
(defun c:2 (/)
(command "_offset" "2")
(princ))
Y aurait il une autre solution?
l'ideal serai, si l'on tappe un entier ou un réel, que cela fonctionne sans devoir créer un lisp avant.
quand j'ai fais ca je devais décaler toujours les même valeurs
au d'un moment ca gonfle
alors voila
une commande "decaler" avec mémoire
a tester
(defun c:dcc  (/ ent pt what_next)
 (setq what_next 2)
 (if (not dec)
   (setq dec "1.00")
 (if (not dclist)
   (setq dclist '("0.10" "0.20" "0.30"	"0.40" "0.50" "0.52" "0.60" "0.70"
	   "1.00"))
 (while (>= what_next 2)
   (setq id_dcl (load_dialog "choixdc.dcl"))
   (if	(not (new_dialog "CHOIXDC" id_dcl))
     (exit)
   (set_tile "dc_selec" dec)
   (setq dclist (acad_strlsort dclist))
   (start_list "dcselec")
   (mapcar 'add_list dclist)
   (end_list)
   (action_tile "dcselec" "(dcc3)")
   (action_tile "dc_selec" "(dcc2)")
   (action_tile "dellist" "(dcc1)")
   (action_tile "cancel" "(exit)")
   (action_tile "pick" "(done_dialog 4)")
   (setq what_next (start_dialog))
   (cond
     ((= what_next 4)
      (initget 64)
      (setq dist (rtos (getdist "\nDistance :") 2 2))
      (if (= (member dist dclist) nil)
 (setq dclist (cons dist dclist))
      (set_tile "dc_selec" (setq dec dist))
      (setq what_next 2)
   ) ;fin while
 (unload_dialog id_dcl)
 (setq ent (car (entsel "\nChoix de l'objet à decaler :")))
 (setq pt (getpoint "\nCoté a decaler :"))
 (command "decaler" (atof dec) ent pt)
(defun dcc1  ()
 (setq dclist '("1.00"))
 (end_list)
(defun dcc2  ()
 (setq dec $value)
 (if (= (member dec dclist) nil)
   (setq dclist (cons dec dclist))
 (setq what_next 2)
(defun dcc3  ()
 (setq dec (nth (atoi $value) dclist))
 (setq what_next 2)
;;;partie a copier de un fichier CHOIXDC.DCL
CHOIXDC:dialog
{label = "Valeur du décalage";
:button{label="Effacer la liste";key="dellist" ;width=5;}
:boxed_column{alignment = centered;width = 25;fixed_width = true;spacer;
:list_box{label = "décalage";key = "dcselec";fixed_width = true;width = 25;height = 10;list = dclist;}
:button{label="Pick >";key="pick" ;width=5;}
:edit_box{label="Décalage";key="dc_selec";edit_width=10;}
spacer;
ok_cancel;
Vous fîtes ce que vous pûtes
et vous m'épatâtes !!!!
  • 1 mois après...
Invité samuelM
bonjour,
Je veux créer un outil de DECALAGE similaire à celui qui existe déjà.
le différence que je veux c'est pouvoir rentrer deux valeurs en addition au lieu d'un nombre entier.
Savez vous où ou comment je peux accéder à la programmation de DECALAGE qui existe déjà?
Invité samuelM
oui j'ai vu ça mais il faut que je rajoute un message
