Comment purger la liste des echelles d\'annotation
Quand je reçois des plan transformer en .dwg sur autocad ,il arrive souvent que la liste d'echelle d'annotation soit impossible à purger.Celle-ci ralentit autocad et particulièrement quand je travail dans l'espace papier.Comment revenir à une liste d'echelle restreinte.
Merci.
Salut
Un Lisp...
 ;;;permet de supprimer une tres grande liste d'echelles
;;;commande:SCALELISTDELALL
;;; File: ScaleListDel.lsp
;;; Purpose: Scale list deletion and management for AutoCAD 2008
;;; Author: Steve Johnson
;;; Date: 13 August 2007
;;; Version: 0.7
;;; Copyright: (c) 2007 cad nauseam (www.cadnauseam.com)
;;; May be distributed and used freely provided this header is retained in full
;;; Disclaimer:
;;; This code is supplied as-is and with no warranty whatsoever.
;;; Destruction of annotative objects WILL result from incorrect use.
;;; Use at own risk. No responsibility accepted. Read all notes before use.
;;; Commands:
;;;  SCALELISTDEL
;;;   Deletes unused scales except 1:1 using a user-provided wildcard.
;;;  SCALELISTDELALL
;;;   Deletes all unused scales except 1:1.
;;;  SCALELISTDELINCH
;;;   Deletes all unused scales that contain the inch " character.
;;;  SCALELISTDELXREF
;;;   Deletes all unused scales that contain the "_XREF" string.
;;;  SCALELISTDEL_
;;;   Deletes all unused scales that contain the "_" character.
;;;  SCALELISTDELINCHXREF
;;;   Deletes all unused scales that contain either the inch " character or
;;;   the "_XREF" string.
;;;  SCALELISTDELINCH_
;;;   Deletes all unused scales that contain either the inch " or "_"
;;;   characters.
;;;  SCALELISTMETRIC
;;;   Deletes all existing unused scales except 1:1 and sets up metric scales.
;;;  SCALELISTMETRICTEMPLATE
;;;   Deletes all existing scales and sets up metric scales. For use only in
;;;   setting up scales in templates and pre-2008 drawings.
;;;   WARNING: potentially destructive to annotative objects!
;;;  SCALELISTINCH
;;;   Deletes all existing unused scales except 1:1 and sets up inch-based
;;;   scales.
;;;  SCALELISTINCHTEMPLATE
;;;   Deletes all existing scales and sets up inch-based scales. For use
;;;   only in setting up scales in templates and pre-2008 drawings.
;;; Functions:
;;;  (scaledel_all_unsafe)
;;;   Deletes all scales in the current drawing, including 1:1 and scales in
;;;   use.
;;;  (scaledel_wcard_unsafe WCARD-OR-LIST)
;;;   If WCARD-OR-LIST is a wildcard string, deletes scales that match that
;;;   wildcard, excluding 1:1 but including scales in use.
;;;   If WCARD-OR-LIST is a list of scale names, deletes those scales,
;;;   including 1:1 (if listed) and scales in use.
;;;  (scaledel_long_xref LONG-SCALE-LIST)
;;;   Cleans up those scales that are too long to delete using the command-line
;;;   (i.e. over 132 characters). These are usually only those created by the
;;;   AutoCAD 2008 pre-SP1 bug that created _XREF_XREF_XREF scales, and this
;;;   is checked before deletion.
;;;  (scaledel_warning)
;;;   Issues a warning and asks user to enter Yes before continuing.
;;;  (scaledel_get_scalelist)
;;;   Returns a list of scales in the drawing.
;;;  (scaledel_all)
;;;   Deletes all scales other than 1:1 and scales in use.
;;;  (scaledel_reset)
;;;   Performs a -SCALELIST Reset command.
;;;  (scaledel_smart_reset)
;;;   Performs a -SCALELIST Reset command if it is likely to reduce the number
;;;   of scales in the list, prior to setting things up.
;;;  (scaledel_wcard WCARD)
;;;   Deletes scales that match WCARD, excluding 1:1 and scales in use.
;;;  (scaledel_create_scales SCALES)
;;;   Creates a set of scales defined in list SCALES.
;;;  (scaledel_create_metric)
;;;   Creates a set of metric scales: see *** in code to adjust list.
;;;  (scaledel_create_inch)
;;;   Creates a set of inch scales: see *** in code to adjust list.
;;; Notes:
;;; Other than the SCALELIST*TEMPLATE commands, the commands will not delete
;;; the 1:1 scale, even if it is not in use. This is because if the scale list
;;; is completely cleared, AutoCAD 2008 will automatically recreate it using
;;; its hardwired list when the user picks the "Custom..." item that
;;; remains in the list. Leaving in the 1:1 scale prevents this from happening.
;;; The (scaledel_*_unsafe) functions can be used to delete all scales,
;;; including 1:1 and those in use, if you really need to do so.
;;; Later AutoCAD releases:
;;; As AutoCAD 2008's annotative scaling feature needs work, it is quite likely
;;; that future releases of AutoCAD will do things differently. This may result
;;; in this software failing to work correctly, or working with unintended
;;; results. Check carefully before using this software in 2009 and later.
;;; WARNING:
;;; Any function that uses the (scaledel_*_unsafe) functions may be DESTRUCTIVE
;;; to any annotative objects in the drawing, because they allow the deletion
;;; of scales that are in use.
(if (>= (atof (substr (getvar "ACADVER") 1 4)) 17.1)
 (progn ; Only define these functions if they will work (ie. 2008 or later)
   (prompt "\nLoading ScaleListDel.lsp Version 0.7... ")
;;; Commands
   (defun C:SCALELISTDEL (/ wcard)
     (setq wcard (getstring "\nEnter scale name(s) to delete: "))
     (if (/= wcard "")
       (scaledel_long_xref (scaledel_wcard wcard))
   ) ; End C:SCALELISTDEL
   (defun C:SCALELISTDELALL ()
     (scaledel_all)
   ) ; End C:SCALELISTDELXREF
   (defun C:SCALELISTDELXREF ()
     (scaledel_long_xref (scaledel_wcard "*_XREF"))
   (defun C:SCALELISTDEL_ ()
     (scaledel_long_xref (scaledel_wcard "*_*"))
   ) ; End C:SCALELISTDEL_
   (defun C:SCALELISTDELINCH ()
     (scaledel_long_xref (scaledel_wcard "*\"*"))
   ) ; End C:SCALELISTDELINCH
   (defun C:SCALELISTDELINCHXREF ()
     (scaledel_long_xref (scaledel_wcard "*\"*,*_XREF"))
   ) ; End C:SCALELISTDELINCHXREF
   (defun C:SCALELISTDELINCH_ ()
     (scaledel_long_xref (scaledel_wcard "*\"*,*_*"))
   (defun C:SCALELISTMETRIC ()
     (prompt "\nDeleting existing unused scales...")
     (scaledel_long_xref (scaledel_wcard "*"))
     (prompt "\nCreating metric scales...")
   ) ; End C:SCALELISTMETRIC
   (defun C:SCALELISTMETRICTEMPLATE ()
     (if (= (scaledel_warning) "Yes")
       (progn
         (prompt "\nDeleting all existing scales...")
   ) ; End C:SCALELISTMETRICTEMPLATE
   (defun C:SCALELISTINCH ()
     (prompt "\nCreating inch scales...")
   ) ; End C:SCALELISTINCH
   (defun C:SCALELISTINCHTEMPLATE ()
       (progn
   ) ; End C:SCALELISTINCHTEMPLATE
;;; Functions
   (defun scaledel_all_unsafe (/ scale-en-list)
     (foreach item (dictsearch (namedobjdict) "ACAD_SCALELIST")
       (if (= 350 (car item))
         (setq scale-en-list (cons (cdr item) scale-en-list))
     (foreach item scale-en-list
       (entdel item)
   ) ; End scaledel_all_unsafe
   (defun scaledel_wcard_unsafe (WCARD-OR-LIST / scale-list scale)
         (setq
           scale-list
           (cons
             (cons (strcase (cdr (assoc 300 (entget (cdr item))))) (cdr item))
             scale-list
     (if (= (type WCARD-OR-LIST) 'STR)
       (foreach item scale-list
         (if
           (and
             (wcmatch (car item) (strcase WCARD))
             (/= (car item) "1:1")
           (entdel (cdr item))
       (foreach item WCARD-OR-LIST
         (if (setq scale (assoc (strcase item) scale-list))
           (entdel (cdr scale))
   ) ; End scaledel_wcard_unsafe
   (defun scaledel_long_xref (LONG-SCALE-LIST / scale-list)
     (foreach scale LONG-SCALE-LIST
       (if (wcmatch (strcase scale) "*_XREF_XREF_XREF*")
         (setq scale-list (cons scale scale-list))
     (if scale-list
       (progn
         (prompt "\nDeleting the following long _XREF scale(s):")
         (foreach scale scale-list
           (prompt (strcat "\n " scale))
         (scaledel_wcard_unsafe scale-list)
   ) ; End scaledel_long_xref
   (defun scaledel_warning ()
     (initget "Yes No")
     (getkword
       (strcat
         "\nThis command will first destroy all existing scales including those in use."
         "\nAre you sure you want to do this? [Yes/No] : "
   ) ; End scaledel_warning
   (defun scaledel_get_scalelist (/ scale-list)
         (setq
           scale-list
           (cons (strcase (cdr (assoc 300 (entget (cdr item))))) scale-list)
     scale-list
   ) ; End scaledel_get_scalelist
   (defun scaledel_all ()
   (defun scaledel_reset (/ cmdecho)
     (setq cmdecho (getvar "CMDECHO"))
     (setvar "CMDECHO" 0)
     (command "_.-SCALELISTEDIT" "_R" "_Y" "_E")
     (setvar "CMDECHO" cmdecho)
   ) ; End scaledel_reset
   (defun scaledel_smart_reset ()
     (if (> (length (scaledel_get_scalelist)) 40)
       (scaledel_reset)
   ) ; End scaledel_smart_reset
   (defun scaledel_wcard (WCARD / scale-list cmdecho long-scale-list)
     (foreach scale (scaledel_get_scalelist)
       (if
         (and
           (wcmatch (strcase scale) (strcase WCARD))
           (/= scale "1:1")
     (if scale-list
       (progn
         (command "_.-SCALELISTEDIT")
           (if (<= (strlen item) 132)
             (command "_D" item) ; Attempt to delete scale
             (setq long-scale-list (cons item long-scale-list))
         (command "_E")
     long-scale-list ; Returns list of scales too long to delete
   (defun scaledel_create_scales (SCALES / scale-list-all cmdecho)
     (setq
       scale-list-all (scaledel_get_scalelist)
     (foreach scale SCALES
       (if (not (member (strcase (car scale)) scale-list-all))
         (command "_A" (car scale) (cadr scale))
     (command "_E")
   ) ; End scaledel_create_scales
;; *** Note: several uncommon scales have been commented out.
;; Delete the leading semi-colon to make a scale active.
;; You can comment out an unwanted scale by placing a semi-colon at
;; the start of its line.
   (defun scaledel_create_metric ()
;          ("10:1" "10:1")
;          ("5:1" "5:1")
;          ("2:1" "2:1")
         ("1:1" "1:1")
         ("1:2" "1:2")
;          ("1:2.5" "1:2.5")
         ("1:5" "1:5")
         ("1:10" "1:10")
         ("1:20" "1:20")
;          ("1:25" "1:25")
         ("1:50" "1:50")
         ("1:100" "1:100")
         ("1:200" "1:200")
;          ("1:250" "1:250")
         ("1:500" "1:500")
         ("1:1000" "1:1000")
         ("1:2000" "1:2000")
;          ("1:2500" "1:2500")
         ("1:5000" "1:5000")
;          ("1:10000" "1:10000")
;          ("1:20000" "1:20000")
;          ("1:25000" "1:25000")
;          ("1:50000" "1:50000")
;          ("1:100000" "1:100000")
;          ("1:200000" "1:200000")
;          ("1:250000" "1:250000")
;          ("1:500000" "1:500000")
         ("1:1 m" "1000:1")
         ("1:2 m" "1000:2")
;          ("1:2.5 m" "1000:2.5")
         ("1:5 m" "1000:5")
         ("1:10 m" "1000:10")
         ("1:20 m" "1000:20")
;          ("1:25 m" "1000:25")
         ("1:50 m" "1000:50")
         ("1:100 m" "1000:100")
         ("1:200 m" "1000:200")
;          ("1:250 m" "1000:250")
         ("1:500 m" "1000:500")
         ("1:1000 m" "1000:1000")
         ("1:2000 m" "1000:2000")
;          ("1:2500 m" "1000:2500")
         ("1:5000 m" "1000:5000")
         ("1:10000 m" "1000:10000")
         ("1:20000 m" "1000:20000")
;          ("1:25000 m" "1000:25000")
         ("1:50000 m" "1000:50000")
;          ("1:100000 m" "1000:100000")
;          ("1:200000 m" "1000:200000")
;          ("1:250000 m" "1000:250000")
;          ("1:500000 m" "1000:500000")
   ) ; End scaledel_create_metric
   (defun scaledel_create_inch ()
;          ("8:1" "8:1")
;          ("4:1" "4:1")
;          ("2:1" "2:1")
         ("1:1" "1:1")
         ("1/32\" = 1'-0\"" "0.03125:12")
         ("1/16\" = 1'-0\"" "0.0625:12")
         ("3/32\" = 1'-0\"" "0.09375:12")
         ("1/8\" = 1'-0\"" "0.125:12")
         ("3/16\" = 1'-0\"" "0.1875:12")
         ("1/4\" = 1'-0\"" "0.25:12")
         ("3/8\" = 1'-0\"" "0.375:12")
         ("1/2\" = 1'-0\"" "0.5:12")
         ("3/4\" = 1'-0\"" "0.75:12")
         ("1\" = 1'-0\"" "1:12")
         ("1-1/2\" = 1'-0\"" "1.5:12")
         ("3\" = 1'-0\"" "3:12")
         ("6\" = 1'-0\"" "6:12")
         ("1\" = 10'-0\"" "1:120")
         ("1\" = 20'-0\"" "1:240")
         ("1\" = 30'-0\"" "1:360")
         ("1\" = 40'-0\"" "1:480")
         ("1\" = 50'-0\"" "1:600")
         ("1\" = 60'-0\"" "1:720")
         ("1\" = 100'-0\"" "1:1200")
;          ("1\" = 250'-0\"" "1:3000")
;          ("1\" = 500'-0\"" "1:6000")
;          ("1\" = 1000'-0\"" "1:12000")
;          ("1\" = 5280'-0\"" "1:63360")
;          ("1\" = 12000'-0\"" "1:144000")
;          ("1\" = 24000'-0\"" "1:288000")
;          ("1\" = 48000'-0\"" "1:576000")
;          ("1\" = 50000'-0\"" "1:600000")
;          ("1\" = 52800'-0\"" "1:633600")
   ) ; End scaledel_create_inch
   (prompt
     (strcat
       "SCALELISTDEL SCALELISTDELALL SCALELISTDELINCH SCALELISTDELXREF "
       "SCALELISTDEL_ SCALELISTDELINCHXREF SCALELISTDELINCH_ SCALELISTMETRIC "
       "SCALELISTMETRICTEMPLATE SCALELISTINCH SCALELISTINCHTEMPLATE "
       "commands loaded.\n"
 ) ; End progn to test for AutoCAD release
 (prompt "\nRequires AutoCAD 2008 or above.")
;;; End of file ScaleListDel.lsp
