kclement Posté(e) le 6 octobre 2010 Posté(e) le 6 octobre 2010 Bonjour, J'ai trouvé ceci sur Cadalyst : ;;; CADALYST 03/08 www.cadalyst.com/code ;;; Tip 2276: BRICKS.lsp Brick Hatch Generator (c) 2008 Raymond Rizkallah ;;;============================================================================= ;;; "BRICKS.LSP" : BRICKS HATCH PATTERN CREATOR ;;;;;; * Bricks patterns are created on the fly, with length, height & joint size of ;;; your choice.;;; * Two different heights can be used. ;;; * Overlapping bricks is optional. ;;; * Afterwards, BHATCH command is invoked with the new pattern name as default. ;;;;;; "Your imagination is the limit" - Raymond Rizkallah - Nov./2007 ;;;============================================================================== (defun C:BRK () (prompt " **Bricks, Tiles, & Stone Masonry Hatch Creator**") (if (null (numberp l1)) (setq l1 15.0) ) (if (null (numberp h1)) (setq h1 5.0) ) (if (null (numberp h2)) (setq h2 3) ) (if (null (numberp j1)) (setq j1 0.5) ) (setq dir-name (findfile "acad.pat") str-len (strlen dir-name) ) (setq dir-name (substr dir-name 1 (- str-len 8))) (while (findfile (strcat dir-name (setq b-name (getstring "\n Brick pattern name to create: ")) ".pat" ) ) (alert "\nPattern name already exist... Please try again. ") ) (setq nl1 (getdist (strcat "\n Brick length <" (rtos l1) ">: "))) (setq nh1 (getdist (strcat "\n First height <" (rtos h1) ">: "))) (setq nh2 (getdist (strcat "\n Second height <" (rtos h2) ">: "))) (setq nj1 (getdist (strcat "\n Joint size <" (rtos j1) ">: "))) (initget "Yes No") (setq opt (getkword "\n Overlap bricks? [Yes/No] : ")) (if (null opt) (setq opt "Yes") ) (if nl1 (setq l1 nl1) ) (if nh1 (setq h1 nh1) ) (if nh2 (setq h2 nh2) ) (if nj1 (setq j1 nj1) ) (setq l1x (/ l1 2.0)) (setq j1x (/ j1 2.0)) ;------------------- Overlapped ----------------------------------- (setq p-lst1 (list ;___ brick hatch pattern name (overlapped bricks) (strcat "*" b-name ", " "L=" (rtos l1 2 2) " H1=" (rtos h1 2 2) " H2=" (rtos h2 2 2) " Jt=" (rtos j1 2 2) " - Ovr." ) ;___ ;___ brick-1: line 1 (strcat "0, " "0,0, " "0," (rtos (+ h1 j1 h2 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-1: line 2 (strcat "0, " "0," (rtos h1 2 3) ", " "0," (rtos (+ h1 j1 h2 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-1: line 3 (strcat "90, " "0,0, " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h1 2 3) ",-" (rtos (+ j1 h2 j1) 2 3) ) ;___ brick-1: line 4 (strcat "90, " (rtos l1 2 3) ",0, " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h1 2 3) ",-" (rtos (+ j1 h2 j1) 2 3) ) ;___ ;___ brick-2: line 1 (strcat "0, " (rtos (+ l1x j1x) 2 3) "," (rtos (+ h1 j1) 2 3) ", " "0," (rtos (+ h2 j1 h1 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-2: line 2 (strcat "0, " (rtos (+ l1x j1x) 2 3) "," (rtos (+ h1 j1 h2) 2 3) ", " "0," (rtos (+ h1 j1 h2 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-2: line 3 (strcat "90, " (rtos (+ l1x j1x) 2 3) "," (rtos (+ h1 j1) 2 3) ", " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h2 2 3) ",-" (rtos (+ j1 h1 j1) 2 3) ) ;___ brick-2: line 4 (strcat "90, " (rtos (+ l1x j1x l1) 2 3) "," (rtos (+ h1 j1) 2 3) ", " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h2 2 3) ",-" (rtos (+ j1 h1 j1) 2 3) ) ) ) ;end list/setq ;------------------- Not Overlapped ------------------------------- (setq p-lst2 (list ;___ brick hatch pattern name (not overlapped) (strcat "*" b-name ", " "L=" (rtos l1 2 2) " H1=" (rtos h1 2 2) " H2=" (rtos h2 2 2) " Jt=" (rtos j1 2 2) " - Str." ) ;___ ;___ brick-1: line 1 (strcat "0, " "0,0, " "0," (rtos (+ h1 j1 h2 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-1: line 2 (strcat "0, " "0," (rtos h1 2 3) ", " "0," (rtos (+ h1 j1 h2 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-1: line 3 (strcat "90, " "0,0, " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h1 2 3) ",-" (rtos (+ j1 h2 j1) 2 3) ) ;___ brick-1: line 4 (strcat "90, " (rtos l1 2 3) ",0, " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h1 2 3) ",-" (rtos (+ j1 h2 j1) 2 3) ) ;___ ;___ brick-2: line 1 (strcat "0, " "0," (rtos (+ h1 j1) 2 3) ", " "0," (rtos (+ h2 j1 h1 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-2: line 2 (strcat "0, " "0," (rtos (+ h1 j1 h2) 2 3) ", " "0," (rtos (+ h1 j1 h2 j1) 2 3) ", " (rtos l1 2 3) ",-" (rtos j1 2 3) ) ;___ brick-2: line 3 (strcat "90, " "0," (rtos (+ h1 j1) 2 3) ", " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h2 2 3) ",-" (rtos (+ j1 h1 j1) 2 3) ) ;___ brick-2: line 4 (strcat "90, " (rtos l1 2 3) "," (rtos (+ h1 j1) 2 3) ", " "0," (rtos (+ l1 j1) 2 3) ", " (rtos h2 2 3) ",-" (rtos (+ j1 h1 j1) 2 3) ) ) ) ;end list/setq ;------------------------------------------------------------------ (if (= opt "Yes") (setq p-lst p-lst1) (setq p-lst p-lst2) ) (setq n1 1) (foreach n p-lst (if (> (strlen n) 80) (progn (alert (strcat "\n Line [" (itoa n1) "] Pattern Definition Contains more than 80 Characters." "\n " ) ) (EXIT) ) ) (setq n1 (1+ n1)) ) (setq f (open (strcat dir-name b-name ".pat") "w")) (foreach n p-lst (write-line n f)) (close f) (princ) (alert (strcat "\n* File [" b-name ".pat] Created in the Following Directory:" "\n [" dir-name "]" "\n " "\n Press to Continue with BHATCH Command." ) ) (setvar "hpname" b-name) (setvar "hpscale" 1) (princ) (command "_bhatch") ) ;end C:BRICK;;;==================================================================== (PROMPT "\n Use [C:BRK] to create bricks & tiles hatch patterns. " ) (PRINC) Ca crée un motif de briques (avec 2 hauteur de briques différentes possibles) et lance la commande hachure avec le motif qui vient d'être créé. Ma question est la suivante : peut-on adapter ce lisp pour avoir des lignes et des colonnes alignées (pas de joints croisés) ? Merci
kclement Posté(e) le 6 octobre 2010 Auteur Posté(e) le 6 octobre 2010 Bon, je retire ma question : j'avais zappé l'option OVERLAP qu'il propose !!! Enfin, ça servira peut-être à quelqu'un quand même ! A+
