Pieroka Posté(e) le 24 août 2010 Posté(e) le 24 août 2010 Salut, L'update 1 pour Autocad 2011 est ici. (32 et 64 bits) L'update 1 pour Autocad LT 2011 est là. (32 et 64 bits) Les différents points corrigés en anglais : .NET API * .NET applications built for AutoCAD 2010 may not run on AutoCAD 2011. * When opening multiple drawings, the minimize and maximize buttons may not always be visible. * You may experience a random exception when loading custom ARX applications. 2D Display * When using Software Acceleration, AutoCAD may become unstable. 3D Cache * When VSINTERSECTIONEDGES is set to “0” Camera preview can be extremely slow. 3D Modeling * AutoCAD may become unstable when stretching along the Z access of the Gizmo. * Using the Gizmo grip on a 3D model may not work correctly from the right-click menu. 3D Navigation Tools * Navigation Bar tooltips may cause AutoCAD to become unstable when switching between drawings. * Clicking on the “X” to close AutoCAD may fail if the drawing is maximized, and both the ViewCube and SteeringWheel are enabled. * Orbiting 3D models does not degrade when Adaptive Degradation is checked in the Performance Tuner and uses the 3D Connexion device * AutoCAD may become unstable when using the Look tool in the WHEEL command. * AutoCAD may become unstable when using 3D Orbit in degradation mode with 3Dconnexion devices. * AutoCAD may become unstable when using the Walk tool in the SteeringWheel feature with degradation and when FPS is set to a limit of 30. Annotation Scaling * Drawings containing 100 or more annotation scales cannot be reset. ARX * Third party applications may fail when using "removeCmd" in custom ARX applications. Attributes * Multiline attributes in a dynamic block created in AutoCAD 2011 may not display in AutoCAD 2010. Command Line * With Dynamic Mode set to “0” you may not be able to input Japanese or Chinese characters at the command line. Customer Involvement Program * AutoCAD fails to start due to Customer Involvement Program on Windows 7 workstations with Windows 2008 Server on the same subnet. CUI * When an Enterprise menu is loaded, the Workspace control in the CUI Editor may be grayed out. * Unable to copy and paste Toolbar Controls in the CUI Editor. * When switching profiles that point to a CUIx file that cannot be found, AutoCAD may become unstable. * When using "^P" in a macro, the MENUECHO is not displayed properly. Digitizer * AutoCAD will display a CER (Customer Error Report) dialog when exiting AutoCAD with a digitizer configured. DGN Support * DGNIMPORT command may not work with the option to ignore external references. Dimensions * Some AutoCAD Mechanical objects cannot be selected after being inserted as a block and exploded. * AutoCAD may become unstable when using eTransmit on drawings containing multileaders. Display Acceleration * AutoCAD may become unstable when a password protected screen saver displays on the screen. Display Drivers * May have issues updating the Graphics Card drivers on Windows Vista or Windows 7. * Some display drivers may show up as certified even though they were not certified. DWG * WBLOCK may be unable to save the drawing to the AutoCAD 2000 file format for “DWG” and “DXF” External References * AutoCAD may become unstable when an External Reference is reloaded after XOPEN, EDIT, or SAVE. Graphic System * AutoCAD may become unstable when opening multiple drawings in the same session when running out of video memory. * AutoCAD may become unstable when opening large amounts of drawings. Hatch * Hatch may not display properly when dynamic blocks are part of the boundary and live preview is enabled. * Some hatch objects on a newly thawed layer may require a “REGEN” to display. * Some custom hatch patterns may not display in the Ribbon Panel. * AutoCAD may become unstable when using grips to select hatches in some drawings. * AutoCAD may become unstable when editing annotative hatch through the Ribbon. * Hatch Scale may revert to 1 when setting transparency and angle on a hatch pattern on a 64-bit operating system. Help * Welcome Screen Videos may not play on 64-bit operating systems. * Searching Online Help may be slow. Layer * Changing layers transparently from the Ribbon will not update to the new layer when you complete the command. * Layer properties cannot be changed transparently from the Ribbon. * When a large amount of layers exist in the layer dialog, changing them in the Ribbon layer control will not update the layer dialog. * After setting a new layer current, focus is set to the "Name" Column. Licensing * Cascading license can't be checked out if one of the distributed server machines doesn't exist on the network. * AutoCAD cannot get a license from the distributed server when one of servers is stopped. Image * AutoCAD may become unstable when plotting a drawing with plot transparency set to "On". Materials * Protein Materials values created on a 64-bit operating system will not work on a 32-bit operating system. * When FBXEXPORT is using the default settings, de-selecting the Insert as Block option in FBXIMPORT results in nothing being imported. MText * Mtext Paragraph spacing cannot be removed. * Text in AutoCAD Mechanical-created Fit dimension can change unexpectedly after DDEDIT. Object DBX * Unable to export multi-line attribute values with Object DBX OLE (Object Linking & Embedding) * Drawings with OLE objects saved as a DXF file no longer contain OLE options. Open/Save * AutoCAD may become unstable when using undo on large drawings. Other * FBX files imported from Autodesk 3ds Max will not import unless materials are unchecked. * AutoCAD may become unstable if a drawing REGEN occurs after editing a block. * AutoCAD will not take advantage of the 3 gigabyte switch when enabled on a 32-bit operating system. * Color book values may not display properly in AutoCAD * Some PGP aliases may not function in AutoCAD LT. Partial Open * AutoCAD may become unstable when SDI (Single Document Interface) is set to 1, while editing drawings with OPENPARTIAL are set to 1. PDF Export * Adobe Reader may display a warning message “Cannot find or create the font “ArialMT” when opening PDF files created in AutoCAD. Publish * AutoCAD may become unstable when publishing large drawings to PDF. Raster Design * AutoCAD may become unstable when inserting some BMP images. * Saving with ISAVE, ISAVEAS, and ISAVE again may cause an error message that you cannot save the file. Ribbon * AutoCAD may become unstable in a side-by-side install if the files tab path points to the Install Directory of AutoCAD 2010. * AutoCAD may become unstable when Regional and Language Options are set to Turkish language. * Ribbon Fold Panels cannot be transferred in the CUI Editor. * AutoCAD may become unstable if you have a "." in your menugroup name. * While in a command, changing the workspace from the Quick Access toolbar will not work. * Loading custom toolbars from the Ribbon may fail. Section & Flatten * All cut-away geometry in sectionplane may not display properly when selecting “Show Cut-away Geometry”. Selection Highlighting * Selection Cycling displays when none should be visible. * AutoCAD may become unstable when holding control and hovering over intersections of lines. * Changing the Selection Cycling toggle from "Off" to "On" and then quitting AutoCAD may cause you to receive an error report. * AutoCAD may become unstable after using the "CapturePreviewImage" method Snaps * Crosshairs do not extend across the screen when set to 100% in isometric snap style. Visual Lisp * Visual Lisp may display an error message when using ads_defun and ads_regfunc calls in AcApp.arx. * When using the lisp function, "vl-directory-files" may cause AutoCAD to become unstable if the directory path is long. Formateur Autocad - Revit - Sketchup - Photoshop
lili2006 Posté(e) le 24 août 2010 Posté(e) le 24 août 2010 Bonsoir à toutes et tous, Merci pour l'info Pieroka, :P Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
