(gile) Posté(e) le 28 avril 2010 Posté(e) le 28 avril 2010 (defun str2lst (str sep / pos) (if (setq pos (vl-string-search sep str)) (cons (substr str 1 pos) (str2lst (substr str (+ (strlen sep) pos 1)) sep) ) (list str) ) ) (defun in (n l / x r) (setq l (str2lst l ",")) (or (numberp n) (setq n (atof n))) (while (and (not r) l) (setq x (mapcar 'atof (str2lst (car l) "-")) l (cdr l) ) (if (or (= (car x) n) ( (setq r T) ) ) r ) (defun str2lst (str sep / pos) (if (setq pos (vl-string-search sep str)) (cons (substr str 1 pos) (str2lst (substr str (+ (strlen sep) pos 1)) sep) ) (list str) ) ) (defun in (n l) (or (numberp n) (setq n (atof n))) (vl-some '(lambda (x) (or (= (car x) n) ( (mapcar '(lambda (x) (mapcar 'atof (str2lst x "-"))) (str2lst l ",") ) ) ) Gilles Chanteau - gileCAD - GitHub Développements sur mesure pour AutoCAD
