créer des hachures personnalisées
Bonjour à tous
je débute sur autocad 2008
je cherche tout simplement à créer une hachure personnalisée
type représentation d'un isolant laine de verre
comment proceder
merci de votre aide
A+
monlappin
Win XP pro SP 3 (il est vieux mais ça marche)
ACAD ARCHI 2014
Un éditeur de texte tout simple du type du Bloc note de windows, et une bonne dose de patience et d'obstination, l'aide d'Autocad explique comment programmer les "familles".
Pour ma part, je commence par dessiner mon motif dans un carré de 1x1 puis j'utilise l'outils cote superposées avec une précision importante.
Ci-joint un exemple. Bon courage
*MarneEtCaillasse,
134.999915,0.095709,0.558214,0.536051,0.536053,0.050000,-1.022105
134.999915,0.474756,0.179168,0.536051,0.536053,0.050000,-1.022105
134.999915,0.010354,0.472858,0.536051,0.536053,0.014643,-1.057462
134.999915,0.389401,0.093812,0.536051,0.536053,0.050000,-1.022105
45.000085,0.354046,0.179168,0.536051,-0.536053,0.050000,-1.022105
45.000085,0.000000,0.583215,0.536051,-0.536053,0.014643,-1.057462
45.000085,0.439401,0.093741,0.536051,-0.536053,0.050000,-1.022105
45.000085,0.060354,0.472788,0.536051,-0.536053,0.050000,-1.022105
90.000000,0.095711,0.508214,0.000000,-0.758092,0.050000,-0.708094
90.000000,0.474757,0.129168,0.000000,-0.758092,0.050000,-0.708094
90.000000,0.354047,0.129168,0.000000,-0.758092,0.050000,-0.708094
0.000000,0.010356,0.593570,0.000000,0.758094,0.050000,-0.708092
0.000000,0.010356,0.472859,0.000000,0.758094,0.050000,-0.708092
0.000000,0.389402,0.214523,0.000000,0.758094,0.050000,-0.708092
0.000000,0.389402,0.093812,0.000000,0.758094,0.050000,-0.708092
134.999915,0.449756,0.687382,0.536051,0.536053,0.100000,-0.972105
134.999915,0.070709,0.308335,0.536051,0.536053,0.100000,-0.972105
45.000085,0.549756,0.687382,0.536051,-0.536053,0.100000,-0.972105
45.000085,0.170710,0.308336,0.536051,-0.536053,0.100000,-0.972105
45.000085,0.587381,0.308335,0.536051,-0.536053,0.100000,-0.972105
45.000085,0.208335,0.687382,0.536051,-0.536053,0.100000,-0.972105
0.000000,0.070709,0.308335,0.000000,0.758094,0.100000,-0.658092
0.000000,0.449756,0.687382,0.000000,0.758094,0.100000,-0.658092
0.000000,0.279047,0.758094,0.000000,0.758094,0.100000,-0.658092
134.999915,0.758092,0.483214,0.536051,0.536053,0.035355,-1.036750
45.000085,0.733092,0.558214,0.536051,-0.536053,0.035354,-1.036751
90.000000,0.733093,0.508214,0.000000,-0.758092,0.050000,-0.708094
0.000000,0.658093,0.379047,0.000000,0.758094,0.100000,-0.658092
bonjour
j'essaye depuis ta réponse de créer une hachure sans succes
même en utilisant une copie du fichier AutoCAD.pat dans le chemin personnalisation d'entreprise ( résultat erreur dans le fichier de motifs)
je comprends pas ?
je ne trouve pas non plus dans l'aide
merci pour les réponses
a+
monlappin
ACAD ARCHI 2014
Il est préférable de faire un fichier .pat par hachure et de lui donner le même nom que la hachures, dans mon exemple c'est : MarneEtCaillasse.pat
de le sauvegardé dans un dossier préalablement déclaré dans les chemins de recherche de fichier supports (Options ; onglet fichiers ).
Enfin, faire attention à ce qu'il n'y est pas de lignes vides à la fin du fichier.
A plus
salut
merci pour l'aide
mais je ne comprends pas car dans option fichier je ne peux insérer que des fichiers avec l'extension .CUI
alors que tu me parle de .PAT
au secours
a+
MONLAPPIN
ACAD ARCHI 2014
Dans l'espace de travail, click droit. Tout en bas du menu contextuel choisi "options" dans cette grosse boite de dialogue il y a un onglet "fichiers", c'est là que ça se passe.
Les hachures n'ont aucun rapport avec les fichiers cui ou l'interface de personnalisation oublis ça pour ton problème de hachures
