Je n'arrive pas a créer la répartition pour une utilisation en réseau, après avoir copier 1.6 Go de données ça bloque.
Je pensais que ça venait du DVD mais meme en copiant tout sur le disque c le meme pb. Par contre une installation a partir du DVD marche.
Voici le LOG :
2009/6/3:16:37:32 vagelli VAGELLI Deployment VCREDIST2005X86 CreateAdminImage succeeded!
2009/6/3:16:37:32 vagelli VAGELLI Deployment VCREDIST2005X86 Finalize succeeded!
2009/6/3:16:37:40 vagelli VAGELLI Deployment VCREDISTX86 CreateAdminImage succeeded!
2009/6/3:16:37:40 vagelli VAGELLI Deployment VCREDISTX86 Finalize succeeded!
2009/6/3:16:38:49 vagelli VAGELLI Deployment DOTNET CreateAdminImage succeeded!
2009/6/3:16:38:49 vagelli VAGELLI Deployment DOTNET Finalize succeeded!
2009/6/3:16:38:50 vagelli VAGELLI Deployment ADR CreateTransform succeeded!
2009/6/3:16:38:54 vagelli VAGELLI Deployment ADR CreateAdminImage succeeded!
2009/6/3:16:38:54 vagelli VAGELLI Deployment ADR CopyUserFiles succeeded!
2009/6/3:16:38:54 vagelli VAGELLI Deployment ADR Finalize succeeded!
2009/6/3:16:38:55 vagelli VAGELLI Deployment DOTNETLANG Finalize succeeded!
2009/6/3:16:39:01 vagelli VAGELLI Deployment DIRECTX CreateAdminImage succeeded!
2009/6/3:16:39:01 vagelli VAGELLI Deployment DIRECTX Finalize succeeded!
2009/6/3:16:39:01 vagelli VAGELLI Deployment MSXML CreateAdminImage succeeded!
2009/6/3:16:39:01 vagelli VAGELLI Deployment MSXML Finalize succeeded!
2009/6/3:16:39:04 vagelli VAGELLI Deployment ACAD CreateTransform succeeded!
2009/6/4:00:13:33 vagelli VAGELLI Deployment ACAD CreateAdminImage succeeded!
2009/6/4:00:13:33 vagelli VAGELLI Deployment ACAD CopyUserFiles succeeded!
2009/6/4:00:13:34 vagelli VAGELLI Deployment ACAD CreateGPOMsi failed!
2009/6/4:08:14:00 vagelli VAGELLI Deployment VCREDIST2005X86 CreateAdminImage succeeded!
2009/6/4:08:14:00 vagelli VAGELLI Deployment VCREDIST2005X86 Finalize succeeded!
2009/6/4:08:14:07 vagelli VAGELLI Deployment VCREDISTX86 CreateAdminImage succeeded!
2009/6/4:08:14:07 vagelli VAGELLI Deployment VCREDISTX86 Finalize succeeded!
2009/6/4:08:15:18 vagelli VAGELLI Deployment DOTNET CreateAdminImage succeeded!
2009/6/4:08:15:18 vagelli VAGELLI Deployment DOTNET Finalize succeeded!
2009/6/4:08:15:18 vagelli VAGELLI Deployment ADR CreateTransform succeeded!
2009/6/4:08:15:21 vagelli VAGELLI Deployment ADR CreateAdminImage succeeded!
2009/6/4:08:15:21 vagelli VAGELLI Deployment ADR CopyUserFiles succeeded!
2009/6/4:08:15:21 vagelli VAGELLI Deployment ADR Finalize succeeded!
2009/6/4:08:15:21 vagelli VAGELLI Deployment DOTNETLANG Finalize succeeded!
2009/6/4:08:15:28 vagelli VAGELLI Deployment DIRECTX CreateAdminImage succeeded!
2009/6/4:08:15:28 vagelli VAGELLI Deployment DIRECTX Finalize succeeded!
2009/6/4:08:15:29 vagelli VAGELLI Deployment MSXML CreateAdminImage succeeded!
2009/6/4:08:15:29 vagelli VAGELLI Deployment MSXML Finalize succeeded!
2009/6/4:08:15:32 vagelli VAGELLI Deployment ACAD CreateTransform succeeded!
2009/6/4:10:35:50 vagelli VAGELLI Deployment ACAD CreateAdminImage failed!
2009/6/4:10:36:00 vagelli VAGELLI === Setup ended ===
[Edité le 21/6/2009 par LOLO2B82]
bonjour
comment fais-tu pour créer ta répartition ? tu le fait directement sur le serveur, ou à partir d'un poste de travail, et en créant la répartition sur le serveur via un partage réseau?
J'ai fait de nombreuses création d'image d'installation (ou répartition) de cette 2eme manière et cela a toujours fonctionné.
as tu bien rentré les infos de licence et de CdKey ?
en relisant mon message, il faut que j'apporte une précision :
J'ai eu une seule fois un problème lors de la création d'image d'installation, et c'était à cause d'un antivirus qui bloquait l'écriture sur le serveur d'un fichier.
Du coup l'image n,'était pas créé correctement.
mais c'était pour une version 2008.
d'habitude je la fais d'un poste de travail, mais là j'ai meme essayé a partir du server parce que j'ai pensé a un pb de partage.
Sinon pour créer ma répartition, je clique sur créer la répartition et je suis les différentes étapes, les numéro je les connais par coeur <acronym class=dict title=
Comme tu dis je vois plus que l'antivirus mais l'an dernier ça a marché tres bien :casstet:
Ce soir je test a domicile on verra bien...
Chez moi la répartition se créée bien, demain j'essayerai sans antivirus et sans outlook qui peut créer des pbs...
Autre question: comment installer l'activateur de licence ??
Dans les outils complémentaires j'ai tt installé mais pas d'activateur de licence comme ils disent sur un pdf. j'ai LMtools mais ça c pour la gestion des licenses non ?
merci
l'hypothèse de l'antivirus est peut-être la bonne. tu verras demain. tiens nous au courant.
Sinon, je ne vois qu'un problème de configuration sur le poste qui créé la répartition avec une mauvaise version de l'installeur ou autre.
Mais moins probable que l'antivirus.
Je ne sais pas ce que tu appelles l'activateur de licence. LMtools est le serveur de licences réseau.
Le principe des licences réseau est que, si tu en achète par ex 4, tu peux installer autant de postes clients que tu veux, mais tu ne pourra jamais en faire tourner plus de 4 en même temps.
bien sûr elles sont plus chère que les monoposte.
J'ai recopier la répartion faite chez moi puis je l'ai modifier pour rentrer tout ce qu'il faut. Par contre comment t'active et obtiens le fichier licence ???
Ils parlent de l'activateur de licence que je ne trouve pas :(
Sinon tu m'as l'air de t'y connaitre, je suis à la recherche d'un moyen de gérer manuellement les jetons de licence. Savoir qui les utilisent au moins...
Est ce que ça existe ?
[Edité le 5/6/2009 par LOLO2B82]
bonjour
désolé de ne pas avoir répondu plus vite. Je ne suis pas au bureau aujourd'hui et n'ai allumé l'ordinateur qu'il y a peu.
Donc si j'ai bien compris, tu utilise bien des licences réseau. Moi, je n'utilise pas d'activation en ligne, je préfère envoyer systématiquement un mail à leur service d'autorisation. Je n'ai pas l'adresse ici, mais si tu ne la connais pas, je pourrais te la donner lundi.
Je leur fourni le numéro de série, ce que j'ai droit comme licences et ils me renvoient le fichier de licences qui va bien.
Après, avec LMtools, tu vois en temps réél qui utilise les jetons, combien il en reste de dispo, ...
tu as aussi un fichier de log qui indique toutes les ""out" et les "in" de jetons , par qui sur quelle machine. mais ce log ne permet pas de faire de statistiques, ou alors il faut faire un outil pour les remettre en forme. de plus il est effacé à chaque redémarrage du serveur.
Tu as aussi un programme que tu peux installer sur le DVD qui s'appelle SAMreport lite qui permet de faire des statistiques d'utilisation, mais je ne l'ai jamais essayé, je ne sais pas ce qu'il vaut. Nous, on utilise une solution "faite maison" pour la surveillance de LMtools.
ça m'interresse bcp... le mail d'autodesk et ton logiciel maison (si c possible :D ).
Sinon le log s'appelle comment et se trouve où ?
SAMReport lite je l'ai installé, faudrait que je me penche dessus il a l'air pas simple... surtout qu'il est en anglais <acronym class=dict title=
En tout cas merci a toi orio !
PS: ça serait bien de pouvoir administrer les jetons distribués...
pour faire les demandes de licences à Autodesk, nous écrivons à l'adresse
emea.register@activation.autodesk.com
en leur présisant notre numéro de série + le logiciel + le nombre de licence voulues. ils t'envoient une licence pour la version en cours et les 3 précédentes.
Pour le soft maison, c'est plus délicat. La surveillance des serveurs de jetons est incluse dans un systéme global de surveillance de serveurs, en utilisant le produit libre NAGIOS
http://www.nagios.org/
et plus partitulièrement pour les serveurs FlexLM (nom du service serveur de jetons)
http://rpmfind.net//linux/RPM/epel/4/i386/nagios-plugins-flexlm-1.4.6-3.el4.i386.html
c'est une solution assez lourde à mettre en place.
Il y a une autre solution, mais qui te demandrais un peu de développement, en interrogant à distance le serveur FlexLM de manière périodique. tu récupérera le nombre d'utilisateurs et qui utilise. il te faudra alor faire undéveloppement pour traiter ces infos.
pour info
pour lire à distance les états du serveur de jeton :
tu récupère le fichier lmutil.exe dans le dossier d'installation de FlexLM sur le serveur et le tu le recopies sur ton poste de travail
tu tapes :
lmutil lmstat -A -c 27000\@
Ca va te répondre le nombre de licences utilisées, qui les utilise, ...
Il suffit après de lancer cette requette de manière périodique et de l'analyser pour avoir des stats d'utilisations des jetons.
  • 2 semaines après...
j'ai récupérer le fichier lmutil.exe mais lorsque je le lance une fenetre msdos s'ouvre et se ferme desuite apres...
en tapant t'as ligne de commande sur dos il me dit que lmutil n'est pas reconnu ...
:casstet: désolé pour cette novicité <acronym class=dict title=
bienvenue dans le monde de la ligne de commande ;-)
il te faut
- mettre le fichier lmutils.exe dans un dossier de ton choix
- lancer la fenêtre de commande
- te positionner dans le bon dossier
- taper la ligne de commande déjà indiquée
et cela devrait marcher. Sinon donne moi le message d'erreur exact que je comprenne mieux
Non c bon... ça marche :D
Par contre est ce que tu n'aurais pas un .bat ou .vbs pour récupérer les données et faire des stats?
[Edité le 18/6/2009 par LOLO2B82]
là, je n'ai pas. Chez nous, le résultat est analysé par un daemon qui utilise Nagios
cela fait partie d'une stratégie globale de surveillance des serveurs, et ce n'est pas moi qui l'ai mis en place.
Mais le résultat est génial. j'ai en temps réel le nombre de jetons consomés et des statistiques d'utilisation sur maintenant plus de 6 mois (depuis que ca marche en fait).
Mais si tu as des développeurs dans ta société, ils pourront facilement te mettre en place un systeme automatique qui utilise LMutils et stocke de manière cyclique (toutes les 5 minutes par ex) le nombre de jetons utilisés.
Ensuite à toi les belles stats...
