Appel au lispeur! Polyline to multiline
Salut les pros,
J'ai trouvé cela comme routine:
(defun c:po2ml ( / ent dxf_ent typent name_layer closed lst l_bub e_next dxf_next oldlayer oldosm key_mod scale_ml)
(while (null (setq ent (entsel "\nChoix de l'entité: "))))
(setq typent (cdr (assoc 0 (setq dxf_ent (entget (car ent))))) name_layer (cdr (assoc 8 dxf_ent)))
(cond
((eq typent "LWPOLYLINE")
(setq
closed (boole 1 (cdr (assoc 70 dxf_ent)) 1)
lst (mapcar '(lambda (x) (trans x (car ent) 1)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
l_bub (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 42)) dxf_ent))
((eq typent "POLYLINE")
(setq
e_next (entnext (car ent))
(while (= "VERTEX" (cdr (assoc 0 (setq dxf_next (entget e_next)))))
(if (zerop (boole 1 223 (cdr (assoc 70 dxf_next))))
(setq
lst (cons (trans (cdr (assoc 10 dxf_next)) (car ent) 1) lst)
l_bub (cons (cdr (assoc 42 dxf_next)) l_bub)
(setq e_next (entnext e_next))
(setq
lst (reverse lst)
l_bub (reverse l_bub)
(cond
((and lst (apply 'and (mapcar 'zerop l_bub)))
(setq oldlayer (getvar "clayer") oldosm (getvar "osmode"))
(setvar "clayer" name_layer)
(setvar "osmode" 0)
(setvar "cmdecho" 0)
(initget "Dessus Nulle dEssous _Top Zero Bottom")
(setq key_mod
(getkword
(strcat
"\nEntrez le type de justification [Dessus/Nulle/dEssous] <"
(cond
((eq (getvar "cmljust") 0)
"Dessus"
((eq (getvar "cmljust") 1)
"Nulle"
((eq (getvar "cmljust") 2)
"dEssous"
(if key_mod
(cond
((eq key_mod "Top") (setvar "cmljust" 0))
((eq key_mod "Zero") (setvar "cmljust" 1))
((eq key_mod "Bottom") (setvar "cmljust" 2))
(setq scale_ml (getreal (strcat "\nEntrez l'échelle de la multiligne <" (rtos (getvar "cmlscale")) ">: ")))
(if scale_ml (setvar "cmlscale" scale_ml))
(command "_.mline")
(foreach n lst (command "_none" n))
(if closed (command "_close") (command ""))
(setvar "clayer" oldlayer)
(setvar "osmode" oldosm)
(setvar "cmdecho" 1)
(entdel (car ent))
(T (princ "\nN'est pas une polyligne, ou celle ci comporte des arrondis!"))
(prin1)
Mais voilà mon problème:
Ex: j'ai des Polylignes de 400, 800 et 1200....que je devrai modifier en multilignes mais tout en gardant l'épaisseur de chacune. Et comme j'ai 8 epaisseurs differentes pour plus de 67 segments dans un plan, vous comprendrez que je cherche à me simplifier la vie.
Deplus j'ai un tout petit message d'erreur à la fin de la commande...
Merci!!! :cool:
  • 2 semaines après...
En faisant juste une petite modif (mise en remarque de la demande de l'épaisseur) avec le semi-colon ";"
;			(setq scale_ml (getdist (strcat "\nEntrez l'échelle de la multiligne [b]<[/b]" (rtos (getvar "cmlscale")) "[b]>[/b]: ")))
;			(if scale_ml (setvar "cmlscale" scale_ml))
et insertion de la récupération de la largeur constante de la polyligne et assignation à la variable CMSCALE
           [surligneur] (setvar "cmlscale" (cdr (assoc 43 dxf_ent)))[/surligneur]
Possible, mais là je ne vois pas de quoi il s'agit sans plus d'explication...
Comme je ne suis pas sure que le code intégral que tu as mis n'a pas été modifié, je préfère reposter le code en entier.
(defun c:po2ml ( / jspl nbr ent dxf_ent typent name_layer closed lst l_bub e_next dxf_next oldlayer oldosm key_mod)
(princ "\nChoix des polylignes à transformer en multilignes: ")
(setq
	jspl (ssget '((0 . "*POLYLINE") (-4 . "[b]<[/b]NOT") (-4 . "&") (70 . 112) (-4 . "NOT[b]>[/b]")))
	nbr 0
(cond
	(jspl
		(setq key_mod
			(getkword
				(strcat
					"\nEntrez le type de justification [Dessus/Nulle/dEssous] [b]<[/b]"
					(cond
							"Dessus"
							"Nulle"
							"dEssous"
					"[b]>[/b]: "
		(if key_mod
			(cond
		(setvar "osmode" 0)
		(repeat (sslength jspl)
			(setq
				typent (cdr (assoc 0 (setq dxf_ent (entget (setq ent (ssname jspl nbr))))))
			(cond
					(setq
						lst (mapcar '(lambda (x) (trans x ent 1)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
					(setq
						e_next (entnext ent)
							(setq
								lst (cons (trans (cdr (assoc 10 dxf_next)) ent 1) lst)
					(setq
						lst (reverse lst)
			(cond
					(command "_.mline")
					(foreach n lst (command n))
					(if (not (zerop closed)) (command "_close") (command ""))
					(entdel ent)
				(T (princ "\nLes polylignes comportant des arrondis n'ont pas été traitées!"))
			(setq nbr (1+ nbr) lst nil l_bub nil)
	(T (princ "\nSélection vide"))
(prin1)
