lili2006 Posté(e) le 12 avril 2008 Posté(e) le 12 avril 2008 Bonjour à toutes et tous, Quande je lance ce lisp, AutoCAD me retourne => Commande: (if (not c:box_text) (load"box_text")) nilCommande: box_textChoix d'un MultiTEXTE ou TEXTE: ; erreur: nombre d'arguments trop importantCommande: Le Lisp => (defun transpts (apt matrix / ) (list (+ (* (car (nth 0 matrix)) (car apt)) (* (car (nth 1 matrix)) (cadr apt)) (* (car (nth 2 matrix)) (caddr apt)) (cadddr (nth 0 matrix)) ) (+ (* (cadr (nth 0 matrix)) (car apt)) (* (cadr (nth 1 matrix)) (cadr apt)) (* (cadr (nth 2 matrix)) (caddr apt)) (cadddr (nth 1 matrix)) ) (+ (* (caddr (nth 0 matrix)) (car apt)) (* (caddr (nth 1 matrix)) (cadr apt)) (* (caddr (nth 2 matrix)) (caddr apt)) (cadddr (nth 2 matrix)) ) ) ) (defun v_matr (dpt alphax alphay alphaz echx echy echz / ) (list (list (* echx (cos alphaz) (cos alphay)) (- (sin alphaz)) (sin alphay) (car dpt) ) (list (sin alphaz) (* echy (cos alphaz) (cos alphax)) (- (sin alphax)) (cadr dpt) ) (list (- (sin alphay)) (sin alphax) (* echz (cos alphax) (cos alphay)) (caddr dpt) ) (list 0.0 0.0 0.0 1.0) ) ) (defun c:box_text ( / ent_txt dxf_ent ins_point ht_txt lg_box ht_box ang_box pt_just lst_box transform diag_box sv_osm sv_cmd sv_blp cur_col mask_txt) (while (null (setq ent_txt (entsel "\nChoix d'un MultiTEXTE ou TEXTE: ")))) (setq dxf_ent (entget (car ent_txt))) (cond ((and (equal (assoc 210 dxf_ent) '(210 0.0 0.0 1.0)) (eq (cdr (assoc 0 dxf_ent)) "MTEXT")) (setq ins_point (cdr (assoc 10 dxf_ent)) ht_txt (/ (cdr (assoc 40 dxf_ent)) 5.0) lg_box (cdr (assoc 42 dxf_ent)) ht_box (cdr (assoc 43 dxf_ent)) ang_box (cdr (assoc 50 dxf_ent)) pt_just (cdr (assoc 71 dxf_ent)) ) (setq lst_box (list (list (- ht_txt) ht_txt 0.0) (list (+ lg_box ht_txt) ht_txt 0.0) (list (+ lg_box ht_txt) (- 0.0 ht_box ht_txt) 0.0) (list (- ht_txt) (- 0.0 ht_box ht_txt) 0.0) ) ) (cond ((eq pt_just 1) (setq transform (v_matr (list 0.0 0.0 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 2) (setq transform (v_matr (list (- (/ lg_box 2.0)) 0.0 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 3) (setq transform (v_matr (list (- lg_box) 0.0 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 4) (setq transform (v_matr (list 0.0 (+ (/ ht_box 2.0)) 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 5) (setq transform (v_matr (list (- (/ lg_box 2.0)) (/ ht_box 2.0) 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 6) (setq transform (v_matr (list (- lg_box) (/ ht_box 2.0) 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 7) (setq transform (v_matr (list 0.0 ht_box 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 8) (setq transform (v_matr (list (- (/ lg_box 2.0)) ht_box 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ((eq pt_just 9) (setq transform (v_matr (list (- lg_box) ht_box 0.0) 0.0 0.0 0.0 1.0 1.0 1.0)) ) ) (setq lst_box (mapcar '(lambda (x) (transpts x transform)) lst_box)) (setq transform (v_matr (trans ins_point 0 1) 0.0 0.0 (- ang_box) 1.0 1.0 1.0)) (setq lst_box (mapcar '(lambda (x) (transpts x transform)) lst_box)) ) ((and (equal (assoc 210 dxf_ent) '(210 0.0 0.0 1.0)) (eq (cdr (assoc 0 dxf_ent)) "TEXT")) (setq diag_box (textbox dxf_ent) ins_point (cdr (assoc 10 dxf_ent)) ht_txt (/ (cdr (assoc 40 dxf_ent)) 5.0) ang_box (cdr (assoc 50 dxf_ent)) ) (setq lst_box (list (list (- (caar diag_box) ht_txt) (- (cadar diag_box) ht_txt) 0.0) (list (+ (caadr diag_box) ht_txt) (- (cadar diag_box) ht_txt) 0.0) (list (+ (caadr diag_box) ht_txt) (+ (cadadr diag_box) ht_txt) 0.0) (list (- (caar diag_box) ht_txt) (+ (cadadr diag_box) ht_txt) 0.0) ) ) (setq transform (v_matr ins_point 0.0 0.0 (- ang_box) 1.0 1.0 1.0)) (setq lst_box (mapcar '(lambda (x) (transpts x transform)) lst_box)) (setq lst_box (mapcar '(lambda (x) (trans x 0 1)) lst_box)) ) (T (princ "\nN'est pas un TEXTE/TEXTE MultiLigne, ou non parallèle au SCG.") (setq lst_box nil) ) ) (cond (lst_box (setq sv_osm (getvar "osmode") sv_cmd (getvar "cmdecho") sv_blp (getvar "blipmode") cur_col (getvar "CECOLOR") ) (setvar "cmdecho" 0) (setvar "blipmode" 0) (setvar "osmode" 0) (setvar "CECOLOR" "255") (command "_.solid" (car lst_box)) (setq lst_box (cdr lst_box)) (repeat 3 (command (car lst_box)) (setq lst_box (reverse (cdr lst_box))) ) (command "") (setq mask_txt (entlast)) (setvar "CECOLOR" cur_col) (command "_.draworder" (cdar dxf_ent) "" "_above" mask_txt) (setvar "cmdecho" sv_cmd) (setvar "blipmode" sv_blp) (setvar "osmode" sv_cmd) (princ "\nCadre de texte colorisé en gris/blanc - 255") ) ) (princ) ) Je ne sais plus de qui est ce Lisp, désolé ! Une idée ? [Edité le 12/4/2008 par lili2006] Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
(gile) Posté(e) le 12 avril 2008 Posté(e) le 12 avril 2008 Salut, Ça fonctionne chez moi. Mais sans vouloir me mettre en avant, je pense que mt est plus performant et polyvalent (choix de la couleur et du décalage du masque d'arrière plan). Gilles Chanteau - gileCAD - GitHub Développements sur mesure pour AutoCAD
lili2006 Posté(e) le 12 avril 2008 Auteur Posté(e) le 12 avril 2008 Re, Effectivement, (gile), je ne mes souvenais plus du tout de ce lisp !! C'est en partie la raison qui me fait faire un tri dans les Lisps car je finis par rater l'essentiel, la preuve encore ici ! Merci encore de ton aide et tes conseils (gile) Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
lili2006 Posté(e) le 12 avril 2008 Auteur Posté(e) le 12 avril 2008 Re, Lorsque je tape "p", pour accèder aux paramètres, je n'arrive pas à y accèder, il faut que je selectionne des textes et après je sors de la BD. Quelle manip faut-il faire STP (gile)? Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
(gile) Posté(e) le 12 avril 2008 Posté(e) le 12 avril 2008 Il faut faire Entrée au lieu de sélectionner. Décalage: 0.50 Couleur: 1Sélectionnez les textes ou .Choix des objets: Dans la syntaxe habituelle d'AutoCAD, on accède à ce qui apparaît entre en validant par Entrée, Espace ou clic droit.À ma connaissance, il n'est pas possible en LISP de faire apparaître ce type d'invites dans la case de l'affichage dynamique (encore un gadget mal abouti). Gilles Chanteau - gileCAD - GitHub Développements sur mesure pour AutoCAD
lili2006 Posté(e) le 12 avril 2008 Auteur Posté(e) le 12 avril 2008 Re, Merci de ta réponse (gile).En effet, le dyn c'est bien mais il faut garder un oeil sur la ligne de commande. Dommage parce qu'elle est pratique en Palette, mais il m'arrive de rater des options de ce type du coup,... Civil 3D 2025 - COVADIS_18.3d https://www.linkedin...3%ABt-95313341/
