AutoCAD to SolidWorks
http://solidworkstv.blogspot.com/2008/03/autocad-to-solidworks.html
AutoCAD Files (Unit)
169-Moving from AutoCAD
170-Import Options
171-DWGeditor
172-Maintaining AutoCAD Files
173-Communicate with eDrawings
174-Add to PDMWorks Workgroup Vault
175-DWGgateway
176-Accessing AutoCAD Data
2D to 3D Conversion
177-Import DWG as a Part Sketch
178-Editing Imported Data
179-Extracting Sketches
180-Align Sketches
181-Extruding in 2D to 3D
182-Multiple Profiles
183-Cutting in 2D to 3D
184-Create Sketch from Selections
185-Completing a Model
186-Defining Sketches
187-Defining Features
188-Removing Construction Geometry
189-2D to 3D Conversion
190-Import DXF as a Part Sketch
191-Removing Unneeded Data
192-Creating Profiles
193-Check Sketch for Feature
194-Revolving in 2D to 3D
195-Combined Technique
196-DXF Conversion
197-Copy-Paste from DWGeditor
198-Convert to Solid Model
199-Generate Features
200-Using the DWGeditor
AutoCAD Data & Drawings (Unit)
201-AutoCAD Drawing
202-Convert Drawing
203-Accessing AutoCAD Data
204-Add Intelligence
205-Sketch from Drawing
206-Replace Hatching
207-Edit Block
208-Reuse Block Data
209-Paper Space Drawing
210-Resolving Scale Problems
211-Embed Drawing
212-Edit Embedded Drawing
213-Batch Print Drawings
214-Import Drawing
Models & Layouts Introduction
215-Exporting 3D from AutoCAD
216-Importing 3D from AutoCAD
217-Feature Recognition
218-Import Layout Sketch
219-Mate Components
220-Export/Import Model
