ALIGNER SUR X Y XY TEXTE MTEXT
Bonjour
c'est pas du visual LISp
pas de boite de dialogue
mais ca marche
et plus rapide que la boite des proprietes
l'alignement est incremente sur X ou Y ou XY si la valeur de decalage est different de zero
phil
				; ALIGNEMENT DES TEXT MTEXT AVEC POSSIBILITE DE COPIE
(defun C:ALT (/ ENTX)
  (setvar "cmdecho" 0)
  (setq COPIETEXT (getcfg "APPDATA/COPIETEXT"))
  (setq TYPEALGN (getcfg "APPDATA/TYPEALGN"))
  (setq DALTX (atof (getcfg "APPDATA/DALTX")))
  (setq DALTY (atof (getcfg "APPDATA/DALTY")))
  (initget "X Y XY")
  (setq TMP (getkword (strcat "\nENTRER LE PLAN DE PROJECTION (X) (Y) (XY) ACTUELLEMENT <" TYPEALGN "> : ")))
  (if TMP
     (setq TYPEALGN TMP)
  (setq TMP1 (getdist (strcat "\nENTRER LA VALEUR DU DECALAGE DE TEXTE SUR X DESIRE <" (rtos DALTX 2 8) ">: ")))
  (if TMP1
     (setq DALTX TMP1)
  (setq TMP1 (getdist (strcat "\nENTRER LA VALEUR DU DECALAGE DE TEXTE SUR Y DESIRE <" (rtos DALTY 2 8) ">: ")))
  (if TMP1
     (setq DALTY TMP1)
  (initget "oui OUI non NON")
  (setq TMP (getkword
	(strcat "\nVOULEZ VOUS FAIRE DES COPIES DU TEXTE OU MTEXT ( OUI / NON ) <" COPIETEXT "> : ")
  (if TMP
     (setq COPIETEXT TMP)
  (setq ENTX NIL)
  (prompt "\nSELECTIONNER LE(S) TEXTE(S) A MODIFIER :")
  (while (null ENTX)
     (setq ENTX (ssget (list (cons -4 ""))))
  (setq POINTREF (getpoint (strcat "\nENTRER LE POINT DE REFERENCE POUR L'ALIGNEMENT : ")))
  (setq XPOINTREF (car POINTREF))
  (setq YPOINTREF (cadr POINTREF))
  (if (or (= COPIETEXT "oui") (= COPIETEXT "OUI"))
     (command "COPIER" ENTX "" "0,0" "0,0")
  (setq COMPT 0)
  (setq COM (sslength ENTX))
  (while (< COMPT COM)
     (progn (setq ENT (entget (ssname ENTX COMPT)))
     (if (= (cdr (assoc 0 ENT)) "TEXT")
	(setq CLEF72 (cdr (assoc 72 ENT))
	      CLEF73 (cdr (assoc 73 ENT))
	(setq CLEF72 0
	      CLEF73 0
     (if (and (= CLEF72 0) (= CLEF73 0))
	(progn (if (= TYPEALGN "X")
		  (if (= DALTX 0)
		     (setq ENT (subst (cons 10 (list (car (cdr (assoc 10 ENT))) YPOINTREF 0)) (assoc 10 ENT) ENT))
		     (setq ENT (subst (cons 10 (list (+ XPOINTREF (* COMPT DALTX)) YPOINTREF 0)) (assoc 10 ENT) ENT))
	       (if (= TYPEALGN "Y")
		  (if (= DALTY 0)
		     (setq ENT (subst (cons 10 (list XPOINTREF (cadr (cdr (assoc 10 ENT))) 0)) (assoc 10 ENT) ENT))
		     (setq ENT (subst (cons 10 (list XPOINTREF (- YPOINTREF (* COMPT DALTY)) 0)) (assoc 10 ENT) ENT))
	       (if (= TYPEALGN "XY")
		  (setq	ENT (subst (cons 10 (list (+ XPOINTREF (* COMPT DALTX)) (- YPOINTREF (* COMPT DALTY)) 0))
				   (assoc 10 ENT)
				   ENT
		  (if (= DALTX 0)
		     (setq ENT (subst (cons 11 (list (car (cdr (assoc 11 ENT))) YPOINTREF 0)) (assoc 11 ENT) ENT))
		     (setq ENT (subst (cons 11 (list (+ XPOINTREF (* COMPT DALTX)) YPOINTREF 0)) (assoc 11 ENT) ENT))
		  (if (= DALTY 0)
		     (setq ENT (subst (cons 11 (list XPOINTREF (cadr (cdr (assoc 11 ENT))) 0)) (assoc 11 ENT) ENT))
		     (setq ENT (subst (cons 11 (list XPOINTREF (- YPOINTREF (* COMPT DALTY)) 0)) (assoc 11 ENT) ENT))
		  (setq	ENT (subst (cons 11 (list (+ XPOINTREF (* COMPT DALTX)) (- YPOINTREF (* COMPT DALTY)) 0))
				   (assoc 11 ENT)
				   ENT
     (entmod ENT)
     (setq COMPT (1+ COMPT))
  (setcfg "APPDATA/COPIETEXT" COPIETEXT)
  (setcfg "APPDATA/TYPEALGN" TYPEALGN)
  (setcfg "APPDATA/DALTX" (rtos DALTX 2 8))
  (setcfg "APPDATA/DALTY" (rtos DALTY 2 8))
[Edité le 16/11/2007 par PHILPHIL]
FREELANCE
Autodesk Architecture 2025 sous windows 11 64
REVIT
24 pouces vertical + 30 pouces horizontal + 27 pouces horizontal
bonjour,
(initget "X Y XY")
(setq TMP (getkword (strcat "\nENTRER LE PLAN DE PROJECTION (X) (Y) (XY) ACTUELLEMENT  : ")))
(if TMP
(setq TYPEALGN TMP)
(setq TMP1 (getdist (strcat "\nENTRER LA VALEUR DU DECALAGE DE TEXTE SUR X DESIRE : ")))
(if TMP1
(setq DALTX TMP1)
(setq TMP1 (getdist (strcat "\nENTRER LA VALEUR DU DECALAGE DE TEXTE SUR Y DESIRE : ")))
(if TMP1
(setq DALTY TMP1)
(setq TMP (getkword
(strcat "\nVOULEZ VOUS FAIRE DES COPIES DU TEXTE OU MTEXT ( OUI / NON )  : ")
(if TMP
(setq ENTX NIL)
(while (null ENTX)
[surligneur] (setq ENTX (ssget (list (cons -4 "  [b] il manque qqes choses?) [/b][b] )))[/b][/surligneur]
(setq COMPT 0)
(while ((progn (setq ENT (entget (ssname ENTX COMPT)))
(setq CLEF72 0
CLEF73 0
(if (= DALTX 0)
(if (= DALTY 0)
(assoc 10 ENT)
ENT
(if (= DALTX 0)
(if (= DALTY 0)
(assoc 11 ENT)
ENT
(entmod ENT)
Voila j'ai trouvé l'erreur mais je ne sais pas la corriger.
@plus
bonjour
est ce que ton texte ou mtext est "annotative " ?? car avec ca j'ai des problemes
ca reduit les textes
est ce que tu arrives a ces questions la ??
Commande: alt
ENTRER LA VALEUR DU DECALAGE DE TEXTE SUR X DESIRE <0.00000000>:
ENTRER LA VALEUR DU DECALAGE DE TEXTE SUR Y DESIRE <0.00000000>:
Choix des objets: Spécifiez le coin opposé: 6 trouvé(s)
Choix des objets:
as tu acces au fichier AutoCAD.cfg par autocad ?? au acad2008.cfg acad2007.cfg
a+
phil
FREELANCE
REVIT
Lovecraft a bien trouvé un erreur : si des caractères alphabétiques suivent le signe inférieur (
(setq ENTX (ssget (list (cons -4 "")))) -> la liste de filtre n'est pas valide.
(cons 0 "TEXT")
(cons 0 "MTEXT")
(cons -4 "or>")
Solutions :
- Pour celui qui poste : soit mettre un espace après le
- Pour celui qui copie, si les astuces ci dessus n'ont pas été utilisée, passer par Citer (en bas du message) pour avoir le code original.
PS pour PHILPHIL : tu peux aussi écrire simplement :
(setq ENTX (ssget '((0 . "MTEXT,TEXT")))) ou encore (setq ENTX (ssget '((0 . "*TEXT"))))
Re,
Pour moi, toujours même message :
Commande: _appload ALT.LSP correctement chargé(s)
Commande: ; erreur: structure incorrecte de la chaîne en entrée
Commande:
Commande: ALT
Commande inconnue "ALT". Appuyez sur F1 pour obtenir de l'aide.
Civil 3D 2025 - COVADIS_18.3d
ok gile
ca devrait marcher
j ai fait la simplification / variante de gile
et ca devrait regler le probleme du "<"
gile tu avais une autre solution plus visualisp ???
pour ce qui est des données perso elle s'enregistre a la fin donc pas de souci si personne ne les a au debut
  (command "scu" "")
  (initget "X Y XY")
  (setq TMP
   (getkword
	      TYPEALGN
  (if TMP
     (setq TYPEALGN TMP)
  (setq
     TMP1 (getdist
	      (rtos DALTX 2 8)
  (if TMP1
     (setq DALTX TMP1)
  (setq
     TMP1 (getdist
	      (rtos DALTY 2 8)
  (if TMP1
     (setq DALTY TMP1)
  (initget "oui OUI o O non NON n N")
  (setq TMP
   (getkword
      (strcat
	 "\nVOULEZ VOUS FAIRE DES COPIES DU TEXTE OU MTEXT ( O(UI) / N(ON)  ) <"
	 COPIETEXT
  (if TMP
  (setq ENTX NIL)
  (while (null ENTX)
  (setq POINTREF
   (getpoint
  (setq COMPT 0)
	(setq CLEF72 0
	      CLEF73 0
		  (if (= DALTX 0)
		     (setq ENT
			     (subst
				(cons
				   10
				(assoc 10 ENT)
				ENT
		     (setq
			ENT (subst (cons 10
					       YPOINTREF
					       0
				   (assoc 10 ENT)
				   ENT
		  (if (= DALTY 0)
		     (setq ENT
			     (subst
				(cons
				   10
				(assoc 10 ENT)
				ENT
		     (setq
			ENT (subst (cons 10
					 (list XPOINTREF
					       0
				   (assoc 10 ENT)
				   ENT
					       0
				   (assoc 10 ENT)
				   ENT
		  (if (= DALTX 0)
		     (setq ENT
			     (subst
				(cons
				   11
				(assoc 11 ENT)
				ENT
		     (setq
			ENT (subst (cons 11
					       YPOINTREF
					       0
				   (assoc 11 ENT)
				   ENT
		  (if (= DALTY 0)
		     (setq ENT
			     (subst
				(cons
				   11
				(assoc 11 ENT)
				ENT
		     (setq
			ENT (subst (cons 11
					 (list XPOINTREF
					       0
				   (assoc 11 ENT)
				   ENT
					       0
				   (assoc 11 ENT)
				   ENT
     (entmod ENT)
  (command "scu" "p")
FREELANCE
REVIT
À mon avis ça ne change pas grand chose, les gros intérêts de Visual LISP sont d'eviter les command* et d'accéder à des propriétés ou méthodes inaccessibles en AutoLISP. les entmake, entmod, etc... sont plus compatibles.
* tu peux éviter le (command "COPIER" ENTX "" "0,0" "0,0") en faisant (entmake (entget entx))
