ObjectDBX
Bonsoir,
Aprés avoir lu le sujet sur les objets DBX du forum vlisp,
j'ai cherché sur le net ce qui existe en VBA.
Un peut en vrac le résultat !
Juste un petit point par rapport Vlisp, par le VBA l'accès aux possibiltés de ces fonctions est
beaucoup plus aisé.
Mais le but de toute chose varie selon chacun !
Daniel OLIVES
Lyon - FRANCE
Option Explicit
' Module
Type MessPunkt
Rechtswert As Double
Hochwert As Double
Höhe As Double
PNR As String
End Type
Public Punkte() As MessPunkt
' Opening a drawing with ObjectDBX
'Function dbxOpen(fn As String) As AXDB16Lib.AxDbDocument
' If Dir(fn) <> "" Then
' Dim dwgX As New AXDB16Lib.AxDbDocument
' dwgX.Open (fn)
' If Err.Number <> 0 Then
' If Err.Number <> -2147467259 Then 'Invalid filename
' regObjectDBX
' dwgX.Open (fn)
' End If
' End If
' Set dbxOpen = dwgX
' End If
'End Function
Sub ImportLayout(ByVal lyName As String, ByVal fileName As String)
Dim cmdName As String
cmdName = Join(Split(fileName, "\", , 1), "/")
cmdName = "(command ""._Layout"" ""_T"" """ & cmdName & """ """ & lyName & """) "
ThisDrawing.SendCommand cmdName
End Sub
' Add reference to AutoCAD/ObjectDBX Common 16.0 Type Library (axdb16enu.dll)
' This samples copies all dimstyles from specified drawing to the current drawing
' Existing dimstyles are not affected
Public Sub ImportDimstyles()
Dim oAxDbDoc As New AxDbDocument
oAxDbDoc.Open "c:\DimStyles.dwg"
Dim oObj() As Object
Dim oDs As AcadDimStyle
Dim i As Integer
For i = 0 To oAxDbDoc.DimStyles.Count - 1
ReDim Preserve oObj(i)
Set oObj(i) = oAxDbDoc.DimStyles(i)
Next
oAxDbDoc.CopyObjects oObj, ThisDrawing.Database.DimStyles
End Sub
' 2000-03-08
' By Jimmy Bergmark
' Copyright © 1997-2003 JTB World, All Rights Reserved
' Website: www.jtbworld.com
' E-mail: info@jtbworld.com
' Runs in All AutoCAD version if axdb1'x'.dll (must be referenced)
' Example of batch for listing all layers on all drawings in a directory.
' http://www.jtbworld.com/VBA/listlayer.htm
' Corrected by d.OLIVES - for All version and test vbReadOnly
' 2007-02-02
Private Sub ListLayers()
Dim indir As String
Dim elem As Object
Dim filenom As String
Dim WholeFile As String
Dim newHeight As Double
Dim objDbx As AxDbDocument
Dim MyAttr As Integer
Dim acadTyp As String
acadTyp = Left$(ThisDrawing.Application.Version, 2)
Set objDbx = ThisDrawing.Application.GetInterfaceObject("ObjectDBX.AxDbDocument." & acadTyp)
indir = "C:\Program Files\Egid\Cache"
filenom = Dir$(indir & "\*.dwg")
MyAttr = GetAttr(indir & "\" & filenom)
Do While filenom <> ""
ThisDrawing.Utility.Prompt vbCrLf & "File: " & filenom
ThisDrawing.Utility.Prompt vbCrLf & "-----------------"
WholeFile = indir & "\" & filenom
objDbx.Open WholeFile
For Each elem In objDbx.Layers
ThisDrawing.Utility.Prompt vbCrLf & elem.name
Next
Set elem = Nothing
If (MyAttr And vbReadOnly) <> vbReadOnly Then
objDbx.SaveAs WholeFile
End If
filenom = Dir$
Loop
End Sub
' 2000-03-08
' By Jimmy Bergmark
' Example of batch for listing all xrefs on all drawings in a directory.
' http://www.jtbworld.com/VBA/listxref.htm
' 2007-02-02
Private Sub ListXREF()
Dim indir As String
Dim elem As Object
For Each elem In objDbx.Blocks
If elem.IsXRef = True Then
End If
Next
Set elem = Nothing
End If
filenom = Dir$
Loop
End Sub
' Example of batch for listing all SummaryInfo = DWG Properties in a directory.
' by d.OLIVES - for All version and test vbReadOnly
' 2007-02-02
Private Sub ListPROPS()
Dim indir As String
Dim elem As Object
Dim myProps As AcadSummaryInfo
Set myProps = ThisDrawing.SummaryInfo
myProps.RevisionNumber = 1
Set myProps = Nothing
ThisDrawing.Utility.Prompt vbCrLf & "Auteur : " & objDbx.SummaryInfo.Author
Set elem = Nothing
End If
filenom = Dir$
Loop
End Sub
' Pour VB
'http://discussion.autodesk.com/thread.jspa?messageID=5167190
Public Sub DbxRefTest()
' To test, set references to:
'Microsoft Visual Basic for Applications Extensibility 5.3
'C:\Program Files\Common Files\Microsoft Shared\VBA\VBA6\VBE6EXT.OLB
'AutoCAD/ObjectDBX Common 16.0 Type Library
'C:\Program Files\Common Files\Autodesk Shared\axdb16enu.tlb
'Run in: AutoCAD 2007
Dim Dbx As AxDbDocument
Dim i As Integer
Dim oVBE As VBE
Dim oVBP As VBProject
Dim Version As String
Version = Mid(ThisDrawing.GetVariable("acadver"), 1, 2)
'Fix Reference
Set oVBE = Application.VBE
Set oVBP = oVBE.ActiveVBProject
With oVBP.References
For i = 1 To .Count
If .Item(i).name Like "AXDBLib" Then
If Not .Item(i).Description Like _
"AutoCAD/ObjectDBX Common " & _
Version & ".0 Type Library" Then
.Remove .Item(i)
.AddFromFile _
"C:\Program Files\Common Files" & _
"\Autodesk Shared\axdb" & _
Version & "enu.tlb"
End If
GoTo FixRefDone
End If
Next
End With
FixRefDone:
Set oVBP = Nothing
Set oVBE = Nothing
'Get Template Dbx
If CInt(Version) < 16 Then
Set Dbx = AcadApplication.GetInterfaceObject("ObjectDBX.AxDbDocument")
Else
Set Dbx = AcadApplication.GetInterfaceObject("ObjectDBX.AxDbDocument." & Version) '
End If
Dbx.Open ThisDrawing.Application.Preferences.Files.QNewTemplateFile
'Clear Dbx
Set Dbx = Nothing
End Sub
Sub TestATTRIBUTS()
Dim objDbx As Object
'Dim arx As AxDbDocument
Dim col(0) As Object
Dim blockdef As AcadBlock
Dim indir As String
Dim elem As Object
'Dim objDbx As AxDbDocument
Dim Anzahl As Long
Dim Entity As AcadEntity
Dim BlockRef As AcadBlockReference
Dim InsPkt As Variant
Dim PNR As String
Dim Attr As AcadAttributeReference
ReDim Punkte(0 To 0)
' For Each blockdef In objDbx.Blocks
' If blockdef.IsLayout = False Then
' Set col(0) = blockdef
' Call objDbx.CopyObjects(col, ThisDrawing.Blocks)
' End If
' Next blockdef
indir = "C:\TEMP\T_Essai"
On Error GoTo Err_Trap
For Each Entity In objDbx.PaperSpace
If Entity.EntityType = acBlockReference Then
If Entity.name = "Cartouche" Then
Anzahl = Anzahl + 1
Set BlockRef = Entity
InsPkt = BlockRef.insertionPoint
ReDim Preserve Punkte(0 To UBound(Punkte) + 1)
Punkte(UBound(Punkte)).Rechtswert = InsPkt(0)
Punkte(UBound(Punkte)).Hochwert = InsPkt(1)
Punkte(UBound(Punkte)).Höhe = InsPkt(2)
If BlockRef.HasAttributes Then
Dim varAttributes As Variant
Dim i As Integer
Dim strAttributes As String
varAttributes = BlockRef.GetAttributes
For i = LBound(varAttributes) To UBound(varAttributes)
strAttributes = strAttributes & " Tag: " & varAttributes(i).TagString & _
" Value: " & varAttributes(i).textString & " "
ThisDrawing.Utility.Prompt vbCrLf & "Auteur : " & strAttributes
ThisDrawing.SummaryInfo.Author = varAttributes(i).textString
strAttributes = ""
Next
PNR = 12345678
Punkte(UBound(Punkte)).PNR = PNR
End If
End If
End If
End If
Next Entity
' Cas du fichier déjà ouvert passe au fichie suivant
suite:
filenom = Dir$
Loop
Set objDbx = Nothing
Exit Sub
Err_Trap:
Select Case Err.Number
Case -2147467259
MsgBox "Attention ce fichier est déjà ouvert veuillez d'abord le fermer !", _
vbCritical, "Gestion des cartouches"
Err.Clear
GoTo suite
Case Else
Err.Clear
Exit Sub ' Sortie sous-routine
End Select
End Sub
Sub TestobjDbx()
objDbx.Open "C:\Program Files\Egid\Modeles\2002\Cartouche.DWG"
End If
Next blockdef
End Sub
