usegomme Posté(e) le 15 février 2007 Posté(e) le 15 février 2007 routine pour tracer des tuyauteries en 2 D sans contrôle sur les longueurs mini. ;;;; TUYAU.LSP usegomme ;;; version acad2002 ---> 2007 et peut être 2000 (defun ertuyau () (setvar "snapang" res) (setvar "offsetdist" of7) (setvar "filletrad" fil) (setq res nil pt nil pd nil pti nil ang nil sommets nil lang nil i1 nil point nil rayo nil diam nil ddia nil ent1 nil angp90 nil angm90 nil pd1 nil pd2 nil of7 nil fil nil pw nil dn nil ) (redraw) (setvar "cmdecho" 1) (setq *error* m:err m:err nil) (princ) ) (defun soudure (/ pt0 ang1 ang2 angt dang long pa pb pc paa pbb pcc) (setq i2 1) (repeat (- (length sommets) 2) (setq pt0 (nth i2 sommets)) (setq ang1 (- (nth i2 lang) pi)) (setq ang2 (nth (1+ i2) lang)) (if (> ang1 ang2) (setq angt (- ang1 ang2)) (setq angt (- ang2 ang1)) ) (if (> angt pi) (setq angt (- (* 2 pi) angt))) (if (= (abs angt) pi) (setq long rayo) (progn (setq dang (/ (abs angt) 2 )) (setq long (* (cos dang) (/ rayo (sin dang)))) ) ) (setq pa (polar pt0 ang1 long) pb (polar pa (+ ang1 (/ pi 2)) ddia) pc (polar pb (- ang1 (/ pi 2)) (* ddia 2)) paa (polar pt0 ang2 long) pbb (polar paa (+ ang2 (/ pi 2)) ddia) pcc (polar pbb (- ang2 (/ pi 2)) (* ddia 2)) ) (command "_line" "_none" pb "_none" pc "" ) (command "_line" "_none" pbb "_none" pcc "") (setq i2 (1+ i2)) ) ) (defun diametre () (cond ((and (/= tuy:dn "Autre") (/= tuy:dn " ") (/= tuy:dn nil)) (setq dn tuy:dn) (initget "Autre") (setq dn (getreal (strcat "\nDiametre en DN [8/10/15/21/20/25/32/40/50/65/80/100/125/150/200/250/300/350/400/450/500/600/Autre en mm] DN<" (rtos dn 2 0) ">: "))) ) (T (initget "Autre") (setq dn (getreal (strcat "\nDiametre en DN [8/10/15/21/20/25/32/40/50/65/80/100/125/150/200/250/300/350/400/450/500/600/Autre en mm] : "))) ) ) (cond ((and (/= dn "A") (/= dn nil)) (setq tuy:dn dn)) ((= dn nil) (if tuy:dn (setq dn tuy:dn))) ((= dn "A") (setq dn nil)) ) (cond ((= dn 8) (setq diam 13.5 rayo 20 )) ((= dn 10) (setq diam 17.2 rayo 25 )) ((= dn 15) (setq diam 21.3 rayo 27.5 )) ((= dn 21) (setq diam 21.3 rayo 38 )) ; dn15 inox ((= dn 20) (setq diam 26.9 rayo 28.5)) ((= dn 25) (setq diam 33.7 rayo 38)) ((= dn 32) (setq diam 42.4 rayo 47.5)) ((= dn 40) (setq diam 48.3 rayo 57)) ((= dn 50) (setq diam 60.3 rayo 76)) ((= dn 505) (setq diam 60.3 rayo 137)) ; rayon 5d ((= dn 60) (setq diam 63.5 rayo 70)) ; soudure orbitale ((= dn 65) (setq diam 76.1 rayo 95)) ((= dn 80) (setq diam 88.9 rayo 114.5)) ((= dn 100) (setq diam 114.3 rayo 152.5)) ((= dn 125) (setq diam 139.7 rayo 190.5)) ((= dn 150) (setq diam 168.3 rayo 228.5)) ((= dn 200) (setq diam 219.1 rayo 305)) ((= dn 250) (setq diam 273 rayo 381)) ((= dn 300) (setq diam 323.9 rayo 457)) ((= dn 350) (setq diam 355.6 rayo 533.5)) ((= dn 400) (setq diam 406.4 rayo 609.5)) ((= dn 450) (setq diam 458 rayo 686)) ((= dn 500) (setq diam 508 rayo 762)) ((= dn 600) (setq diam 610 rayo 914)) ( T (cond ((and tuy:dia tuy:ray) (setq diam (getdist (strcat "\nDiametre Exterieur Tuyauterie ou 2 pts <" (rtos tuy:dia 2 4) ">: "))) (setq rayo (getdist (strcat "\nRayon coude ou 2 pts <" (rtos tuy:ray 2 4) ">: "))) (if diam (setq tuy:dia diam) (setq diam tuy:dia)) ; (setq ddia (/ diam 2)) (if rayo (setq tuy:ray rayo) (setq rayo tuy:ray)) ) (T (setq diam (getdist "\nDiametre Exterieur Tuyauterie ou 2 pts : ")) ; (setq ddia (/ diam 2)) (setq rayo (getdist "\nRayon coude , 2 pts ou <>: ")) (if (= rayo nil) (setq rayo (* diam 1.1))) (setq tuy:dia diam tuy:ray rayo) ) ) ) ) (setq ddia (/ diam 2)) ) (defun c:TUYAU () (setq m:err *error* *error* ertuyau) (setvar "cmdecho" 0) (setq res (getvar "snapang") of7 (getvar "offsetdist") fil (getvar "filletrad") ) (diametre) (while (setq pt (getpoint "\nPoint Depart Tuyauterie : ")) (setq pd pt pti pt ang 0 sommets (list pt) lang (list ang)) (while (setq pt (getpoint pti "\nPoint suivant : ")) (grdraw pti pt 1) (setq ang (angle pti pt) sommets (append sommets (list pt)) lang (append lang (list ang)) pti pt ) ) (if (= (length sommets) 1) (exit)) (command "_undo" "_be") (setq pw (getvar "plinewid")) (setvar "plinewid" 0) (command "_pline" "_none" pd ) (setq i1 1) (repeat (- (length sommets) 1) (setq point (nth i1 sommets)) (command "_none" point) (setq i1 (1+ i1)) ) (command ) (setvar "plinewid" pw) (setq ent1 (entlast)) (command "_fillet" "_r" rayo) (command "_fillet" "_p" ent1) (setq angp90 (+ ang (/ pi 2)) angm90 (- ang (/ pi 2)) pd1 (polar pti angp90 ddia) pd2 (polar pti angm90 ddia) pti (cons ent1 (list pti)) ) (command "_offset" "_through" "_none" pti "_none" pd1 "") (setq ent2 (entlast)) (command "_offset" "_through" "_none" pti "_none" pd2 "") ; par (setq ent3 (entlast)) (command "_change" ent1 "" "_pr" "_lt" "axes2" "") (command "_explode" ent1) (command "_explode" ent2) (command "_explode" ent3) (if (>= rayo ddia) (if (= ddia 31.75) ;; soudure orbitale (progn (setq rayo 105) (soudure) (setq rayo 70)) (soudure) ) ) (command "_undo" "_e") (redraw) ) (ertuyau) )
sauron Posté(e) le 1 juillet 2010 Posté(e) le 1 juillet 2010 Bonjour,je découvre un peu ton œuvre concernant les lisp sur les tuyauteries, et j'avoue être assez impressionné!J'ai vu ton lisp sur les tuyaux en 3D avec plein d'options intéressantes.Aurais tu par hasard dans tes tiroirs l'équivalent pour améliorer ce lisp 2D? Merci
usegomme Posté(e) le 2 juillet 2010 Auteur Posté(e) le 2 juillet 2010 Bonjour , ça fait un bon moment que je n'ai plus rien fait dans ce domaine, et je n'ai donc pas fait l'équivalent de la 3d . Mais dis toujours ce que tu souhaiterais , on verra aprés s'il y a moyen et temps...
sauron Posté(e) le 2 juillet 2010 Posté(e) le 2 juillet 2010 bin le même en 2D serait vraiment parfait, mais je ne sais pas le boulot que ça représente, je ne voudrais pas abuser :p avec celui ci on peux déjà faire pas mal de chose, mais en résumé , garder la base, ajouter les différentes normes de tubes et le calo, le tout pour du dessin purement à plat. (je le fais actuellement en faisant des décalés, ça marche bien, mais c'est plutôt fastidieux xD ) j'aime bien le dessin 3D, mais le rendu en 2D n'est généralement pas terrible :(
usegomme Posté(e) le 7 juillet 2010 Auteur Posté(e) le 7 juillet 2010 Salut ,Voici une version plus moderne de tuyau.lsp ,mais qui n'est pas encore terminée puisque les emboitements ne sont pas dessinés. C'est un dérivé du lisp pour la 3D , le fonctionnement est donc identique , et c'est aussi pour cette raison que le code est parfois bizarre. Modif : version 1.2les emboitements aux coudes sont symbolisés par un rectangle17-07-10 version 1.3 " SCU" ;; Tuyau 2d ;; et avec ou sans calorifuge ;; fait à partir de tuy.lsp ( tuyau 3 D ) ;;usegomme 17-07-2010 version 1.3 (defun choixnormetdd (/ sv_dm dm) (setq sv_dm (getvar "DYNMODE")) (cond ((< sv_dm 0) (setq dm (* sv_dm -1)) (setvar "DYNMODE" dm)) (t (setq sv_dm nil dm nil)) ) (initget 1 "ISO3D ISO5D INOX-VIS 3000Lbs-VIS PE-PP-EMB PVC-PRESSION PVC-ECOUL CINTRE-SGN") ;;;; bit refus reponse nulle (setq norme (getkword "\nChoisir une Norme [iSO3D/ISO5D/INOX-VIS/3000Lbs-VIS/PE-PP-EMB/PVC-PRESSION/PVC-ECOUL/CINTRE-SGN] : ")) (if sv_dm (setvar "DYNMODE" sv_dm)) ) (Defun getDNtuytdd ( a b d e f g / c) ;(setq c (strcat a d g "<" b ">" e f " ")) ; (setq c (strcat a d g "<" b ">" " ")) (setq c (strcat a g "<" b ">" " ")) (setq c (getreal c)) ) (defun diam-tdd (/ dn diam d b) (setq dn "Norme" epcd 0 emboit 0 EPemboit nil L90 nil L45 nil ecart 0) (if (not norme) (setq norme "ISO3D")) ;; par defaut (if (not epcalo)(setq epcalo 0)) ;; par defaut (while (or(= dn "Norme")(= dn "Calo")) (if (> epcalo 0) (setq msgcalo " CALO ep" msgecalo (rtos epcalo 2 0)) (setq msgcalo " Sans" msgecalo " calo") ) (cond ((= norme "ISO3D") (setq msgdn " DN:") (if (and (/= iso3d:dn "Autre")(/= iso3d:dn nil)) (setq dn (rtos iso3d:dn 2 0)) (setq dn "Autre") ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/8/10/15/21/20/25/32/40/50/65/80/100/125/150/200/250/300/350/400/450/500/600/Autre]") ) ) ((= norme "CINTRE-SGN") (setq msgdn " DN:") (if (and (/= CINTRE-SGN:dn "Autre")(/= CINTRE-SGN:dn nil)) (setq dn (rtos CINTRE-SGN:dn 2 0)) (setq dn "Autre") ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/8/10/15/20/25/32/40/Autre]") ) ) ((= norme "ISO5D") (setq msgdn " DN:") (if (and (/= iso5d:dn "Autre")(/= iso5d:dn nil)) (setq dn (rtos iso5d:dn 2 0))(setq dn "Autre") ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/20/25/32/40/50/65/80/100/125/150/200/250/300/350/Autre]") ) ) ((= norme "INOX-VIS") (setq msgdn " DN:") (if (and (/= inox-vis:dn "Autre")(/= inox-vis:dn nil)) (setq dn (rtos inox-vis:dn 2 0)) (setq dn (rtos 25 2 0) inox-vis:dn 25) ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/6/8/10/15/20/25/32/40/50/65/80]") ) ) ((= norme "3000Lbs-VIS") (setq msgdn " DN:") (if (and (/= 3000Lbs-VIS:dn "Autre")(/= 3000Lbs-VIS:dn nil)) (setq dn (rtos 3000Lbs-VIS:dn 2 0)) (setq dn (rtos 50 2 0) 3000Lbs-VIS:dn 50) ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/6/8/10/15/20/25/32/40/50/65/80]") ) ) ((= norme "PE-PP-EMB") (setq msgdn " DN:") (if (and (/= PE-PP-EMB:dn "Autre")(/= PE-PP-EMB:dn nil)) (setq dn (rtos PE-PP-EMB:dn 2 0)) (setq dn (rtos 50 2 0) PE-PP-EMB:dn 50) ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/10/15/20/25/32/40/50/65/80/100]") ) ) ((= norme "PVC-PRESSION") (setq msgdn " Diam:") (if (and (/= PVC-P:dn "Autre")(/= PVC-P:dn nil)) (setq dn (rtos PVC-P:dn 2 0)) (setq dn (rtos 50 2 0) PVC-P:dn 50) ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/6/8/10/12/16/20/25/32/40/50/63/75/90/110/125/140/160/200/225/250]") ) ) ((= norme "PVC-ECOUL") (setq msgdn " Diam:") (if (and (/= PVC-ECOUL:dn "Autre")(/= PVC-ECOUL:dn nil)) (setq dn (rtos PVC-ECOUL:dn 2 0)) (setq dn (rtos 40 2 0) PVC-ECOUL:dn 40) ) (setq choixdn (strcat "\n " norme msgcalo msgecalo msgdn "[Norme/Calo/32/40/50]") ) ) ) ;; fin cond (initget "Autre Norme Calo") (setq dn (getDNtuytdd choixdn dn norme msgcalo msgecalo msgdn )) (if (= dn "Norme") (choixnormetdd)) (if (= dn "Calo") (if (setq epc (getdist (strcat "\nEpaisseur calo ou 2 pts <" (rtos epcalo 2 0) ">: "))) (setq epcalo epc epc nil) ) ) ) ;; while dn= norme (cond ((= norme "ISO3D") (cond ((and (/= dn "A") (/= dn nil))(setq iso3d:dn dn)) ((= dn nil) (if iso3d:dn (setq dn iso3d:dn))) ) (cond ((= dn 8) (setq diam 13.5 rayo 20 )) ((= dn 10) (setq diam 17.2 rayo 25 )) ((= dn 15) (setq diam 21.3 rayo 28 )) ;27 ((= dn 21) (setq diam 21.3 rayo 38 )) ; dn15 inox ((= dn 20) (setq diam 26.9 rayo 28.5)) ((= dn 25) (setq diam 33.7 rayo 38)) ((= dn 32) (setq diam 42.4 rayo 47.5)) ((= dn 40) (setq diam 48.3 rayo 57)) ((= dn 50) (setq diam 60.3 rayo 76)) ((= dn 65) (setq diam 76.1 rayo 95)) ((= dn 80) (setq diam 88.9 rayo 114.5)) ((= dn 100)(setq diam 114.3 rayo 152.5)) ((= dn 125) (setq diam 139.7 rayo 190.5)) ((= dn 150) (setq diam 168.3 rayo 228.5)) ((= dn 200) (setq diam 219.1 rayo 305)) ((= dn 250) (setq diam 273 rayo 381)) ((= dn 300) (setq diam 323.9 rayo 457)) ((= dn 350) (setq diam 355.6 rayo 533.5)) ((= dn 400) (setq diam 406.4 rayo 609.5)) ((= dn 450) (setq diam 458 rayo 686)) ((= dn 500) (setq diam 508 rayo 762)) ((= dn 600) (setq diam 610 rayo 914)) (t (autrediametretdd) ) ) ) ((= norme "CINTRE-SGN") ;;;; cintrage tube d'après un document SGN (cond ((and (/= dn "A") (/= dn nil))(setq CINTRE-SGN:dn dn)) ((= dn nil) (if CINTRE-SGN:dn (setq dn CINTRE-SGN:dn))) ) (cond ((= dn 8) (setq diam 13.5 rayo 70 )) ((= dn 10) (setq diam 17.2 rayo 90 )) ((= dn 15) (setq diam 21.3 rayo 110 )) ((= dn 20) (setq diam 26.9 rayo 135)) ((= dn 25) (setq diam 33.7 rayo 170)) ((= dn 32) (setq diam 42.4 rayo 215)) ((= dn 40) (setq diam 48.3 rayo 245)) (t (autrediametretdd) ) ) (setq ecart 110) ;;; longueur droite entre 2 courbes ) ((= norme "ISO5D") (cond ((and (/= dn "A") (/= dn nil))(setq iso5d:dn dn)) ((= dn nil) (if iso5d:dn (setq dn iso5d:dn))) ) (cond ((= dn 20) (setq diam 26.9 rayo 57.5)) ((= dn 25) (setq diam 33.7 rayo 72.5)) ((= dn 32) (setq diam 42.4 rayo 92.5)) ((= dn 40) (setq diam 48.3 rayo 109.5)) ((= dn 50) (setq diam 60.3 rayo 137.5)) ((= dn 65) (setq diam 76.1 rayo 175)) ((= dn 80) (setq diam 88.9 rayo 207.5)) ((= dn 100) (setq diam 114.3 rayo 270)) ((= dn 125) (setq diam 139.7 rayo 330)) ((= dn 150) (setq diam 168.3 rayo 390)) ((= dn 200) (setq diam 219.1 rayo 515)) ((= dn 250) (setq diam 273 rayo 650)) ((= dn 300) (setq diam 323.9 rayo 770)) ((= dn 350) (setq diam 355.6 rayo 850)) (t (autrediametretdd) ) ) ) ((= norme "INOX-VIS") (cond ((and (/= dn "A") (/= dn nil))(setq inox-vis:dn dn)) ((= dn nil) (if inox-vis:dn (setq dn inox-vis:dn))) ) (cond ;; d diametre ext coude ((= dn 6) (setq diam 10.2 L90 19 d 14.5)) ((= dn 8) (setq diam 13.5 L90 21 d 17.5)) ((= dn 10) (setq diam 17.2 L90 25 d 21.5)) ((= dn 15) (setq diam 21.3 L90 28 d 27)) ((= dn 20) (setq diam 26.9 L90 33 d 33.5)) ((= dn 25) (setq diam 33.7 L90 38 d 40.5)) ((= dn 32) (setq diam 42.4 L90 45 d 50)) ((= dn 40) (setq diam 48.3 L90 50 d 57)) ((= dn 50) (setq diam 60.3 L90 58 d 70)) ((= dn 65) (setq diam 76.1 L90 75 d 86)) ((= dn 80) (setq diam 88.9 L90 85 d 100)) (t (autrediametretdd) ) ) (setq epcd (* (- d diam) 0.5)) ; epaisseur coude (setq rayo (+ (* diam 0.5) epcd 1) emboit (- l90 rayo) epemboit epcd) ) ((= norme "3000Lbs-VIS") (cond ((and (/= dn "A") (/= dn nil))(setq 3000Lbs-VIS:dn dn)) ((= dn nil) (if 3000Lbs-VIS:dn (setq dn 3000Lbs-VIS:dn))) ) (cond ;;;; b = diametre "manchon" ((= dn 8) (setq diam 13.5 L90 24.5 l45 22 b 26.5)) ((= dn 10) (setq diam 17.2 L90 28.5 l45 22 b 34)) ((= dn 15) (setq diam 21.3 L90 33.5 l45 25 b 38.5)) ((= dn 20) (setq diam 26.9 L90 38 l45 28.5 b 46.5)) ((= dn 25) (setq diam 33.7 L90 44.5 l45 33.5 b 56.5)) ((= dn 32) (setq diam 42.4 L90 51 l45 38 b 62.5)) ((= dn 40) (setq diam 48.3 L90 60.5 l45 41.5 b 76)) ((= dn 50) (setq diam 60.3 L90 63.5 l45 50.5 b 92)) ((= dn 65) (setq diam 76.1 L90 82.5 l45 63.5 b 110)) ((= dn 80) (setq diam 88.9 L90 95.5 l45 63.5 b 122)) ((= dn 100)(setq diam 114.3 L90 114.5 l45 80 b 152)) (t (autrediametretdd) ) ) (setq epcd (* (- b diam) 0.25)) ;; ep coude = moitie epaisseur manchon ?.. (setq rayo (+ (* diam 0.5) epcd 1) emboit (- l90 rayo) epemboit (* 2 epcd)) ) ((= norme "PE-PP-EMB") (cond ((and (/= dn "A") (/= dn nil))(setq PE-PP-EMB:dn dn)) ((= dn nil) (if PE-PP-EMB:dn (setq dn PE-PP-EMB:dn))) ) (cond ;;;; d= diametre ext coudes ((= dn 10) (setq diam 16 L90 25 L45 20 d 26)) ((= dn 15) (setq diam 20 L90 28 L45 21 d 30.5)) ((= dn 20) (setq diam 25 L90 32 L45 24 d 36)) ((= dn 25) (setq diam 32 L90 38 L45 28 d 43.5)) ((= dn 32) (setq diam 40 L90 44 L45 33 d 53.5)) ((= dn 40) (setq diam 50 L90 51 L45 36 d 66)) ((= dn 50) (setq diam 63 L90 62 L45 43 d 82)) ((= dn 65) (setq diam 75 L90 75.5 L45 51 d 92.5)) ((= dn 80) (setq diam 90 L90 88 L45 58 d 110)) ((= dn 100) (setq diam 110 L90 106 L45 68 d 134)) (t (autrediametretdd) ) ) (setq epcd (* (- d diam) 0.5)) ; ep coude (setq rayo (+ (* diam 0.5) epcd 1) emboit (- l90 rayo) epemboit epcd ecart 5) ) ((= norme "PVC-PRESSION") (cond ((and (/= dn "A") (/= dn nil))(setq PVC-P:dn dn)) ((= dn nil) (if PVC-P:dn (setq dn PVC-P:dn))) ) (cond ;;;; D diam ext coude ((= dn 6) (setq diam dn L90 16 D 11)) ((= dn 8) (setq diam dn L90 17 D 13)) ((= dn 10) (setq diam dn L90 18 D 14)) ((= dn 12) (setq diam dn L90 19 D 17)) ((= dn 16) (setq diam dn L90 23 L45 18.5 D 21)) ((= dn 20) (setq diam dn L90 27 L45 21 D 25)) ((= dn 25) (setq diam dn L90 33 L45 25 D 30.5)) ((= dn 32) (setq diam dn L90 39 L45 30 D 38.2)) ((= dn 40) (setq diam dn L90 49 L45 36 D 47.2)) ((= dn 50) (setq diam dn L90 57 L45 42.5 D 58.5)) ((= dn 63) (setq diam dn L90 71 L45 52 D 73.4)) ((= dn 75) (setq diam dn L90 83 L45 60.5 D 87.2)) ((= dn 90) (setq diam dn L90 97 L45 70.5 D 105)) ((= dn 110) (setq diam dn L90 116 L45 86 D 127)) ((= dn 125) (setq diam dn L90 172 L45 97 D 146.2)) ((= dn 140) (setq diam dn L90 146 L45 108 D 162)) ((= dn 160) (setq diam dn L90 166 L45 122 D 185)) ((= dn 200) (setq diam dn L90 207 L45 149 D 225.2)) ((= dn 225) (setq diam dn L90 233 L45 168 D 250)) ((= dn 250) (setq diam dn L90 263 L45 191.5 D 282)) (t (autrediametretdd) ) ) (setq epcd (* (- d diam) 0.5)) ;; ep coude (setq rayo (+ (* diam 0.5) epcd 1) emboit (- L90 rayo) epemboit epcd ecart 5) ) ((= norme "PVC-ECOUL") (cond ((and (/= dn "A") (/= dn nil))(setq PVC-ECOUL:dn dn)) ((= dn nil) (if PVC-ECOUL:dn (setq dn PVC-ECOUL:dn))) ) (cond ;;;; L87 longueur pour coude 87.5° ((= dn 32) (setq diam dn L87 48 L45 34 emboit 26)) ;; +3 ((= dn 40) (setq diam dn L87 58 L45 40 emboit 30)) ((= dn 50) (setq diam dn L87 71 L45 49 emboit 35)) (t (autrediametretdd) ) ) (setq L90 (/ (- (* L87 45)(* L45 2.5)) 42.5)) ;; 90-87.5=2.5 et 45-2.5=42.5 (setq rayo (- L90 emboit) epemboit 2 epcd 0 ecart 5) ;;; ecart = ecartement mini entre 2 embouts de coude ) ) ; fin cond dn suivant norme (setq ddia (/ diam 2)) (if (not (> rayo (+ ddia epcd))) (setq rayo (* (+ ddia epcd) 1.01))) ) (defun autrediametretdd () (setq epcd 0) (if (not tuy:dia)(if ddia (setq tuy:dia (* ddia 2))(setq tuy:dia 8))) (setq diam (getdist (strcat "\nDiametre Exterieur Tuyauterie ou 2 pts <" (rtos tuy:dia 2 4) ">: "))) (if diam (setq tuy:dia diam) (setq diam tuy:dia)) (if (not tuy:ray)(setq tuy:ray diam)) (setq rayo (getdist (strcat "\nRayon coude ou 2 pts <" (rtos tuy:ray 2 4) ">: "))) (if rayo (setq tuy:ray rayo) (setq rayo tuy:ray)) ) (defun tubagetdd (ent typ / lent p10 a50 a51 p11 pw) (command "_ucs" "") ;; dessine les contours du tube (cond ((= typ 1) ;; coude (setq p10 (trans (cdr (assoc 10 (entget ent))) 0 1)) (setq a50 (cdr (assoc 50 (entget ent)))) (setq a51 (cdr (assoc 51 (entget ent)))) (command "_offset" ddia ent "_non" p10 "") (command "_offset" ddia ent "_non" (polar p10 a50 (* 2 rayo)) "") (cond ((and (> emboit 0)(> epemboit 0)) (setq pw (getvar "plinewid")) (setvar "plinewid" 0) (command "_pline" "_non" (polar p10 a50 (+ rayo ddia epemboit)) "_non" (polar p10 a50 (- rayo ddia epemboit)) "_non" (polar (polar p10 a50 (- rayo ddia epemboit)) (- a50 (* 0.5 pi)) emboit) "_non" (polar (polar (polar p10 a50 (- rayo ddia epemboit)) (- a50 (* 0.5 pi)) emboit) a50 (+ (* 2 ddia) (* 2 epemboit)) ) "_c" ) (command "_pline" "_non" (polar p10 a51 (+ rayo ddia epemboit)) "_non" (polar p10 a51 (- rayo ddia epemboit)) "_non" (polar (polar p10 a51 (- rayo ddia epemboit)) (- a51 (* 1.5 pi)) emboit) "_non" (polar (polar (polar p10 a51 (- rayo ddia epemboit)) (- a51 (* 1.5 pi)) emboit) a51 (+ (* 2 ddia) (* 2 epemboit)) ) "_c" ) (setvar "plinewid" pw) ) (t (command "_line" "_non" (polar p10 a50 (+ rayo ddia)) "_non" (polar p10 a50 (- rayo ddia)) "" ) (command "_line" "_non" (polar p10 a51 (+ rayo ddia)) "_non" (polar p10 a51 (- rayo ddia)) "" ) ) ) (cond ((and (> epcalo 0) (> rayo (+ ddia epcalo))) (command "_offset" (+ ddia epcalo) ent "_non" p10 "") (setq lent (entget (entlast))) (setq lent (subst (cons 8 calqcalo) (assoc 8 lent) lent)) (entmod lent) (command "_offset" (+ ddia epcalo) ent "_non" (polar p10 a50 (* 2 rayo)) "") (setq lent (entget (entlast))) (setq lent (subst (cons 8 calqcalo) (assoc 8 lent) lent)) (entmod lent) ) ) ) (t ;; tube (setq p10 (trans (cdr (assoc 10 (entget ent))) 0 1)) (setq p11 (trans (cdr (assoc 11 (entget ent))) 0 1)) (command "_offset" ddia ent "_non" (polar p10 (+ (* 0.5 pi)(angle p10 p11)) ddia ) "") (command "_offset" ddia ent "_non" (polar p10 (+ (* 0.5 pi)(angle p11 p10)) ddia ) "") (cond ((> epcalo 0) (command "_offset" (+ ddia epcalo) ent "_non" (polar p10 (+ (* 0.5 pi)(angle p10 p11)) ddia) "") (setq lent (entget (entlast))) (setq lent (subst (cons 8 calqcalo) (assoc 8 lent) lent)) (entmod lent) (command "_offset" (+ ddia epcalo) ent "_non" (polar p10 (+ (* 0.5 pi)(angle p11 p10)) ddia) "") (setq lent (entget (entlast))) (setq lent (subst (cons 8 calqcalo) (assoc 8 lent) lent)) (entmod lent) ) ) ) ) ;change proprietes de l'axe (setq lent (entget ent)) ;; si le code 62 pour la couleur est présent ... ; (if (assoc 62 lent) ;; ... le remplacer par un nouveau ; (setq lent (subst (cons 62 6) ;;Nouvelle couleur magenta ; (assoc 62 lent) lent) ; ) ;; sinon, en ajouter un ; (setq lent (append lent (list (cons 62 6)))) ;; magenta ; ) ;; idem pour type de ligne (if (assoc 6 lent) (setq lent (subst (cons 6 "AXES2") (assoc 62 lent) lent) ) (setq lent (append lent (list (cons 6 "AXES2")))) ) (entmod lent) (command "_ucs" "_p") ) (defun descoudetdd ( L1 L2 pt long) (command "_fillet" L1 L2) (setq coude (entlast)) (if (or del1 (if dminp (= (- long dminp) dmin) (= long dmin))) (entdel L1) (tubagetdd L1 lg) ) (setq del1 nil) (tubagetdd coude cd) ) (defun deterdmintdd ( / a a90 p) ;; determine la distance mini pour placer un coude (cond ;; restauration rayon original ((and l90 l45 epemboit) (setq rayo (- l90 emboit)) (setvar "FILLETRAD" rayo)) ) (if dmin (setq dminp dmin)) ;;; dminp = dmin du coude precedent (if (= b (+ d01 d10)) (setq a180 t) (setq a180 nil)) ;; si angle 180 pas de coude mais prolongement (if (or (= d01 (+ b d10)) (= d10 (+ b d01))) (setq a0 t) (setq a0 nil) ;; si angle 0 pas possible alors arret ) (if (= (* b b) (+ (* d01 d01) (* d10 d10))) ;; si angle 90 dmin = rayon (setq a90 t dmin rayo) (setq a90 nil) ) (if (and (not a0) (not a90)(not a180)) ;;; si autre alors calcul (progn (setq p (/ (+ d01 d10 b) 2)) ;;; p=1/2 perimetre (setq a (abs (atan (sqrt (/ (* (- p d01)(- p d10)) (* p (- p b))))))) ;; 1/2 angle (setq at (* 2 (* a (/ 180 pi)))) ;; angle tuyauterie (cond ((and l90 l45 epemboit (> at 90)) (setq dmin (- (- l90 emboit) (* (/ (- (- l90 emboit)(- l45 emboit)) 45)(- at 90)))) (setq rayo (/ (* (sin a) dmin) (cos a))) (if (not (> rayo (+ ddia epemboit))) (setq rayo (* (+ ddia epemboit) 1.01) dmin (* (cos a) (/ rayo (sin a))) ) ) (setvar "FILLETRAD" rayo) ) (t (setq dmin (* (cos a) (/ rayo (sin a))))) ) ) ) (if a90 (setq at 90.0)) (if a180 (setq at 180.0)) ) (defun onfekoitdd (L1 L2 pt1 pt2 pt3 d1 d2) (cond (a180 (tubagetdd L1 lg)) (a0 (tubagetdd L1 lg) (entdel L2) (setq p0 nil p1 nil)) ((and (not a0) (not a180)) (if (> rayo 0) (cond ((and (if dminp (>= (- d1 dminp) (+ dmin (* 2 emboit) ecart)) (>= d1 dmin)) (>= d2 dmin) ) (descoudetdd L1 L2 pt2 d1) ) ((or (if dminp (< (- d1 dminp) (+ dmin (* 2 emboit) ecart)) (< d1 dmin)) (< d2 dmin) ) (correctiontdd L1 L2 pt1 pt2 pt3 d1 d2) ) ) (tubagetdd L1 lg) ;;; si rayon 0 pas de raccordement ) ) ) ) (defun correctiontdd (L1 L2 pt1 pt2 pt3 d1 d2) (setq lg (if dminp (+ dmin dminp (* 2 emboit) ecart) dmin)) (if (< d1 lg) (progn (setq pt1 (trans (cdr (assoc 10 (entget L1))) 0 1)) (if dminp (setq lgmin (+ dmin (* 2 emboit) ecart))(setq lgmin dmin)) (redefsommettdd pt1 pt2 lgmin) (entdel L1) (command "_line" "_none" pt1 "_none" sbn "") (setq L1 (entlast)) (command "_move" L2 "" "_none" pt2 "_none" sbn) (setq pt2 sbn) (if (and (= emboit 0)(= ecart 0))(setq del1 t)) ) ;;; progn ) ;;; if (cond ((> d2 dmin) (setq pt3 (trans (cdr (assoc 11 (entget L2))) 0 1)) (if (= dp t) (setq p1 pt3 p0 pt2) (setq p0 pt3 p1 pt2) ) (descoudetdd L1 L2 pt2 lg) ;; pas modif ok ) ((= d2 dmin) (descoudetdd L1 L2 pt2 lg) (entdel L2) (setq p0 nil p1 nil) ;;; arret sur coude ) ((< d2 dmin) ;; modification L2 (if (< d1 lg) (progn (setq pt2 sbn) (setq pt3 (trans (cdr (assoc 11 (entget L2))) 0 1)) (setq d1 lg) ) ) (redefsommettdd pt2 pt3 dmin) (command "_move" L2 "" "_none" pt3 "_none" sbn) (descoudetdd L1 L2 pt2 d1) (entdel L2) (setq p0 nil p1 nil) ;;; arret sur coude ) ) ) (defun redefsommettdd (sa sb dist / h a ab za zb z y x b bn hn ap psbn) (setq h (- (caddr sb)(caddr sa))) ;;; hauteur triangle (if (= h 0.0) ;; si parallele plan xy (progn (setq a (angle sa sb)) (setq sbn (polar sa a dist)) ) ;; si vertical suivant axe Z (if (and (= (rtos (car sa) 2 1) (rtos (car sb) 2 1)) ;; probleme de precision avec deplacement ligne (= (rtos (cadr sa) 2 1) (rtos (cadr sb) 2 1)) ) (progn (setq za (caddr sa) zb (caddr sb)) (if (> za zb) (setq z (- za dist)) (setq z (+ za dist)) ) (setq x (car sa) y (cadr sa)) (setq sbn (list x y z)) ;;; nouv sommet b ) ;; orientation quelconque (progn (setq ab (distance sa sb)) (setq b (sqrt (- (* ab ab) (* h h)))) ;;; base triangle (setq hn (/ (* h dist) ab)) ;;; nouvelle hauteur (setq bn (/ (* b dist) ab)) ;;; nouvelle base (setq ap (angle sa sb)) ;;; angle projeté de ab (setq psbn (polar sa ap bn)) ;;; projection nouv sommet b (setq z (+ (caddr sa) hn)) ;;; z nouv pb (setq x (car psbn)) (setq y (cadr psbn)) (setq sbn (list x y z)) ;;; nouv sommet b ) ) ) ) (defun creercalqueAXEtdd (/ calqax) ;;; pas utilisé *** ;creer calque de l'axe (setq calqax (strcat (getvar "clayer") "-AXE")) (if (not (tblsearch "layer" calqax)) ; (command "_-layer" "_n" calqax "" "" ) (command "_-layer" "_n" calqax "_co" "6" calqax "_lt" "axes2" calqax "") ) ) (defun creercalqueCALOtdd ();creer calque pour calorifuge (setq calqcalo (strcat (getvar "clayer") "-CALO")) (if (not (tblsearch "layer" calqcalo)) ; s'il n'existe pas le calque est créé avec la couleur 9 (command "_-layer" "_n" calqcalo "_co" "9" calqcalo "") ) ) (defun c:TUYAU (/ L01 L10 p0 p1 coude mtrim ent eptub at) (setvar "cmdecho" 0) (diam-tdd) (setq p1 nil dmin nil dminp nil L10 nil del1 nil cd 1 lg 0) ;(creercalqueaxetdd) ;; pas utilisé (if (not (tblsearch "ltype" "axes2")) (command "_-linetype" "_l" "AXES2" "" "")) (if (> epcalo 0)(creercalquecalotdd)) (setvar "FILLETRAD" rayo) (setq mtrim (getvar "trimmode"))(setvar "trimmode" 1) (if (not tuy:ep) (setq tuy:ep 0)) (setq p0 (getpoint (strcat "\nPOINT DE DEPART :"))) (while p0 (if p1 (setq pd p1)) ;;; pd point de depart (cond (at (princ "Angle tuyauterie ")(princ at)(princ "°") (princ " et Coude ")(princ (- 180 at))(princ "°") ) ) (princ " Rayon ")(princ rayo) (setq p1 (getpoint p0 "\nPoint suivant : ")) (if p1 (progn (command "_line" "_none" p0 "_none" p1 "") (setq L01 (entlast) d01 (distance p0 p1) dp t) ;;; dp = dernier point p1 (if l10 ;;; si plusieurs boucles ;;; (progn (setq b (distance p1 pd)) ;;; b base triangle (deterdmintdd) (onfekoitdd L10 L01 pd p0 p1 d10 d01) ) ) (if p0 (setq pd p0)) (cond (at (princ "Angle tuyauterie ")(princ at)(princ "°") (princ " et Coude ")(princ (- 180 at))(princ "°") )) (princ " Rayon ")(princ rayo) (if p1 (setq p0 (getpoint p1 "\nPoint suivant : "))) (if p0 (progn (command "_line" "_none" p1 "_none" p0 "") (setq l10 (entlast) d10 (distance p1 p0) dp nil) (setq b (distance p0 pd)) (deterdmintdd) (onfekoitdd L01 L10 pd p1 p0 d01 d10) ) ) ) ;;; si p1 nil (progn (if (and l10 p0 ) (tubagetdd l10 lg)) ;; si plusieurs boucles ;;;; (setq p0 nil ) ) ) ;;;; fin if p1 ) ;;; fin while (cond ((and l01 p1)(tubagetdd l01 lg))) ;;;; termine dernier tronçon (setvar "trimmode" mtrim)(setvar "cmdecho" 1) (cond (at (princ "\nAngle tuyauterie ")(princ at)(princ "°") (princ " et Coude ")(princ (- 180 at))(princ "°") )) (cond (rayo (princ " Rayon ")(princ rayo))) (gc) (prin1) ) [Edité le 8/7/2010 par usegomme][Edité le 11/7/2010 par usegomme] [Edité le 17/7/2010 par usegomme]
usegomme Posté(e) le 8 juillet 2010 Auteur Posté(e) le 8 juillet 2010 Bonsoir Je n'avais pas suffisamment testé et j'ai donc réparé quelques oublis.
sauron Posté(e) le 9 juillet 2010 Posté(e) le 9 juillet 2010 Oui j'avais aperçu quelques bugs en effet :P Merci encore ça semble pas mal du tout ;)
usegomme Posté(e) le 11 juillet 2010 Auteur Posté(e) le 11 juillet 2010 Salut , petite amélioration pour les tubes emboités ou vissés.Modif : version 1.2les emboitements aux coudes sont symbolisés par un rectangle.
sauron Posté(e) le 16 juillet 2010 Posté(e) le 16 juillet 2010 testé et approuvé! par contre j'ai relevé un petit bug, je joue souvent avec les scu, et les coudes ne suivent pas, c'est pas très méchant mais bon... tiens petite question "purement technique" au passage, est il possible avec un lisp dans ce style, d'insérer un bloc pour les coudes, enfin, est ce faisable?
usegomme Posté(e) le 17 juillet 2010 Auteur Posté(e) le 17 juillet 2010 Merci monsieur le testeur, n'étant pas actuellement utilisateur de cette routine j' ai zappé le problème bien qu'il soit commun, j' ai mis une rustine sur le code en basculant le scu au moment de tracer les contours, c'est rapide et pas cher, et ça semble suffisant , je tacherai de faire mieux ultérieurement. tiens petite question "purement technique" au passage, est il possible avec un lisp dans ce style, d'insérer un bloc pour les coudes, enfin, est ce faisable? Oui, je pense , mais je n'ai pas l'expérience de ce genre de truc , il se pourrait que ce soit compliqué avec les angles et les orientations. [Edité le 17/7/2010 par usegomme]
