je l ai retrouvé le lisp dyn-offset.lsp
bien pratique
a+
(defun draw_pt (pt / pt1 pt2 pt3 pt4)
(setq
rap (/ (getvar "viewsize") 50)
pt1 (list (+ (car pt) rap) (+ (cadr pt) rap))
pt2 (list (+ (car pt) rap) (- (cadr pt) rap))
pt3 (list (- (car pt) rap) (- (cadr pt) rap))
pt4 (list (- (car pt) rap) (+ (cadr pt) rap))
(grdraw pt pt1 -1)
(grdraw pt pt2 -1)
(grdraw pt pt3 -1)
(grdraw pt pt4 -1)
(defun c:dyn_offset ( / sel_ent pt_sel e_sel dxf_ent e_mark e_borne loop sav_osm dis_off key pt)
(while (null (setq sel_ent (entsel "\nChoix de l'objet à décaler: "))))
(setq
pt_sel (osnap (cadr sel_ent) "_near")
e_sel (car sel_ent)
dxf_ent (entget e_sel)
e_mark e_sel
e_borne (entlast)
loop T
sav_osm (getvar "osmode")
(cond
((and
(member (cdr (assoc 0 dxf_ent)) '("LWPOLYLINE" "POLYLINE" "LINE" "XLINE" "RAY" "ARC" "CIRCLE" "ELLIPSE" "SPLINE"))
(if (cdr (assoc 70 dxf_ent))
(< (rem (cdr (assoc 70 dxf_ent)) 128) 8)
T
(if (< (getvar "offsetdist") 0.0) (initget 7) (initget 6))
(setq dis_off (getdist (strcat "\nDistance de décalage<" (rtos (getvar "offsetdist")) ">: ")))
(if (not dis_off) (setq dis_off (getvar "offsetdist")) (setvar "offsetdist" dis_off))
(setvar "cmdecho" 0)
(setvar "osmode" 0)
(while (and (setq key (grread T 4 0)) (/= (car key) 3) loop)
(cond
((eq (car key) 5)
(setq pt (cadr key))
(draw_pt pt_sel)
(cond
((>= (distance pt_sel pt) dis_off)
(command "_.offset" "" e_sel pt "")
(if (not (eq (entlast) e_sel))
(setq
e_sel (entlast)
dis_off (+ dis_off (getvar "offsetdist"))
((and
(< (distance pt_sel pt) (- dis_off (getvar "offsetdist")))
(> (distance pt_sel pt) 0.0)
(not (eq e_mark e_sel))
(entdel e_sel)
(if (eq e_borne (entlast))
(setq e_sel (car sel_ent))
(setq e_sel (entlast))
(setq dis_off (- dis_off (getvar "offsetdist")))
((or (member key '((2 13) (2 32))) (eq (car key) 25)) (setq loop nil))
(redraw)
(setvar "osmode" sav_osm)
(setvar "cmdecho" 1)
(T (princ "\nL'objet ne peut pas être décalé."))
(prin1)
Merci d'utiliser un seul fil de discussion pour le même sujet... :casstet:
