A titre d'information et sous toutes réserves, voilà une routine de Bill Kramer qui fait cela, je n'ai pas testée... Plus d'infos et le téléchargement ici.
;; Point A
;; A scroll from the Wizard's Lab.
;; Bill Kramer 2002
;; Interface with Excel Worksheet
;; Example that writes a list of data to a spreadsheet.
;; Global Variables
;; xL - Object reference to EXCEL instance
;; myXLWbs - Object reference to EXCEL work books
;; myXLWb1 - Object reference to Work book #1
;; myXLShs - Object reference to Sheets in Work book
;; myXLSh1 - Object reference to Sheet 1
(defun List_2_Excel (aList /
Row ;;integer row number
Col ;;integer column number
RowItem ;;each primary element in list
ColItem ;;each secondary element in list
myRange ;;object reference for cell in sheet
;;Does an interface to Excel already exist?
(if (null xL)
(setq xL ;;if not, then try to make one
(vlax-get-or-create-object "Excel.Application")))
(if xL ;;success?
(progn
;; We have the application object, now we need to tunnel
;; down into a work book.
(if (null xl-open) ;;Check to see if type library defined
;;It is not, import the type library for EXCEL
(vlax-import-type-library
:tlb-filename "C:/Program Files/Microsoft Office/Office/Excel8.olb"
:methods-prefix "xL-"
:properties-prefix "xLp-"
:constants-prefix "xLc-"))
;; Now dig into the EXCEL object
(setq myXLWbs (vlax-get xL "Workbooks") ;workbooks
myXLWb1 (xl-add myXLWbs) ;add a new workbook
myXLShs (vlax-get myXLWb1 "Sheets") ;worksheets of new workbook
myXLSh1 (xlp-get-item myXLShs 1) ;worksheet number 1
Row 1
;; Loop through the list
(foreach RowItem aList
(setq Col 1) ;;reset column counter
;; List expected to be nested, if not, then we fake it.
(if (atom RowItem) (setq RowItem (list RowItem)))
;; Loop through each nested list
(foreach ColItem RowItem
;; Create range object given column and row location
(setq myRange (xlp-get-range
myXLSh1
(strcat
(ColLetter Col) ;;see below
(itoa Row)
Col (1+ Col)) ;;increment column counter
;; Write the value to the spreadsheet
(xlp-Put-Value myRange ColItem)
(setq Row (1+ Row)) ;;increment row counter
) ;;end FOREACH
)) ;;end IF PROGN
;; ColLetter - Given a number, returns a string that is the Excel
;; method of numbering columns.
;; 1="A", 2="B", ... 26="Z", 27="AA", 28 = "Ab" ...
(defun ColLetter (N /
Res ;;resulting string
TMP ;;work variable
(setq Res "")
(while (> N 0)
(setq TMP (rem N 26) ;;remainder of N divided by 26
TMP (if (zerop TMP) ;;reset to "Z"
(setq N (1- N) ;;move under next order
TMP 26 ;;set to Z offset value
TMP) ;;use value as it is
Res (strcat ;;Add character
(chr (+ 64 TMP)) ;;Offset plus 64 ("A" = 65)
Res) ;;existing string
N (/ N 26) ;;shift down an order
Res
