acces entité dans un bloc
salut et bonne année 2007
je debute en vba et deja bloqué
je voudrais changer de calque un type d'entité parmis d'autre qui sont dans
un block a partir d'une selection a l'ecran
-mon probleme c'est que je n'arrive pas a acceder aux objet qui sont dans mon bloc
ligne,cercle,...
Sub CommandButton1_Click()
Dim gui As AcadEntity
Dim guiBlock As AcadBlockReference
Dim gui2 As AcadEntity
On Error Resume Next
ThisDrawing.SelectionSets("SelectionConv").Delete
Set Sset = ThisDrawing.SelectionSets.Add("SelectionConv")
Sset.SelectOnScreen
For Each gui In Sset
If gui.ObjectName = "AcDbBlockReference" Then
For Each gui2 In gui
If gui2.ObjectName = "AcDbLine" Then
gui2.Layer = "NEW CALQUE"
End If
Next
End If
Next
End Sub
Salut
Extrait de l'aide
Sub Example_GetSubEntity()
' This example prompts the user to select on object on the screen with a mouse click,
' and returns some information about the selected object.
Dim Object As Object
Dim PickedPoint As Variant, TransMatrix As Variant, ContextData As Variant
Dim HasContextData As String
On Error GoTo NOT_ENTITY
TRYAGAIN:
MsgBox "Use the mouse to click on an object in the current drawing after dismissing this dialog box."
' Get information about selected object
ThisDrawing.Utility.GetSubEntity Object, PickedPoint, TransMatrix, ContextData
' Process and display selected object properties
HasContextData = IIf(VarType(ContextData) = vbEmpty, " does not ", " does ")
MsgBox "The object you chose was an: " & TypeName(Object) & vbCrLf & _
"Your point of selection was: " & PickedPoint(0) & ", " & _
PickedPoint(1) & ", " & _
PickedPoint(2) & vbCrLf & _
"This object" & HasContextData & "have nested objects."
Exit Sub
NOT_ENTITY:
' If you click on empty space or do not select an entity,
' this error will be generated
If MsgBox("You have not selected an object. Click OK to try again.", _
vbOKCancel & vbInformation) = vbOK Then
Resume TRYAGAIN
End If
End Sub
Les Lisps de Patrick
Joseph Joubert, 1754-1824
merci ca m'aide un peu
mais ca marche pas
ce que je voudrais c'est lister toutes les entitées d'un bloc
en le selectionnant puis changer de calque tel ou tel type d'entitée
Salut
Je peux te pondre un lisp/vlisp pour ça mais pas un vba ;)
Regarde du cote de la table AcadBlocks. En la parcourant, tu retrouveras les entités qui composent un bloc
Voila, voila
(setq bls (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) ; Je pointe sur la table des blocs
(setq bl (vla-item bls "Un_bloc")) ; Je pointe sur le bloc "Un_bloc" de la table
(vlax-for ent bl ; je parcours les entités qui composent le bloc
 (vlax-dump-object ent) ; j'affiche les caractéristiques des entitée
(vla-get-count bl) ; histoire de donner le nombre d'entités qui composent le bloc
  • 4 semaines après...
salut kisscool73,
As-tu trouvé une solution en VB ?
Moi auss jecherche justement un moyen de remettre certains blocs en Bylayer (à l'origine) afin d'éviter de me trouver avec des layeurs qui n'existent que dans les blocs.
Bon courage !
Voila la solution que j'ai trouvè
Sub calques()
ThisDrawing.SelectionSets("Selection1").Delete
Set Sset = ThisDrawing.SelectionSets.Add("Selection1")
Sset.SelectOnScreen
Dim guiname As String
guiname = gui.Name
Set guiBlock = ThisDrawing.Blocks(guiname)
For Each gui2 In guiBlock
'dans cette selection je ne prend que les lignes
gui2.Layer = ListBox1.Value
'ou gui2.Layer= ce qu'on veut
End If
Next
End If
Next
voila j'esper que ca pourras t'aider
et si qq1 a une autre methode?
bienvenu
End Sub
  • 3 mois après...
Voir le lisp de (gile) edit_bloc... ça marche du tonnerre surtout la version 3.0. Je m'en sers pour nettoyer les plan lourds...
ATEGIE - Bureau d'Études Fluides
http://www.ategie.fr/uploads/ategie/ategie-at%C3%A9gie-bureau-%C3%A9tudes-etudes-fluides-logo-100x56.png
Exécution, Synthèse, Conception, Maîtrise d'Oeuvre, Audit, Chiffrage
www.ategie.fr
