Bonjour rebonjour
Sur ce prog ci qu'est-ce qui ne va pas ............................d'apès vous.
;Tip1781: VALVE.LSP INSERT VALVES ©2002, Badr Bayoumi
(defun
WELDST ()
(setq DCL_ID (load_dialog "P&ID.dcl"))
(if (not (new_dialog "fl11" DCL_ID))
(exit)
) ;_ end of if
(setq CN 1)
(repeat 18 ;repeat slide drawing
(setq
X (dimx_tile (strcat "ve" (itoa CN)))
Y (dimy_tile (strcat "ve" (itoa CN)))
) ;_ end of setq
(start_image (strcat "ve" (itoa CN)))
(slide_image 0 0 X Y (strcat "pid1(v" (itoa CN) ")"))
; start the slide from the slide library pid1
(end_image)
(setq CN (1+ CN))
;to make slide librari : make a text file contaning the slide and from dos write the flowiing :C:\Program Files\ACAD......................ok\Tip1781\Slidelib pid1
(action_tile "cancel" "(done_dialog 0)(setq ext 0)")
(action_tile "accept" "(ch_input)")
(action_tile "ve1" "(ch1 0)")
(action_tile "ve2" "(ch1 1)")
(action_tile "ve3" "(ch1 2)")
(action_tile "ve4" "(ch1 3)")
(action_tile "ve5" "(ch1 4)")
(action_tile "ve6" "(ch1 5)")
(action_tile "ve7" "(ch1 6)")
(action_tile "ve8" "(ch1 7)")
(action_tile "ve9" "(ch1 8)")
(action_tile "ve10" "(ch1 9)")
(action_tile "ve11" "(ch1 10)")
(action_tile "ve12" "(ch1 11)")
(action_tile "ve13" "(ch1 12)")
(action_tile "ve14" "(ch1 13)")
(action_tile "ve15" "(ch1 14)")
(action_tile "ve16" "(ch1 15)")
(action_tile "ve17" "(ch1 16)")
(action_tile "ve18" "(ch1 17)")
(setq
FS1
(list
"Angle Globe" "Ball Rotary" "Butterfly" "Check" "Control"
"Diaphragm" "Flush bottom" "Gate" "Globe" "Needle" "Plug"
"Quick Opening" "Safty" "Stop Check" "Vacum Breake"
"Pattern Globe" "3-Way" "4-Way"
) ;_ end of list
) ;_ end of setq
(start_list "Pt_d")
(mapcar 'add_list FS1)
(end_list)
(action_tile "Pt_d" "(list1)")
(start_dialog)
(unload_dialog DCL_ID)
) ;_ end of defun
(defun
CH_INPUT ()
(setq EXT 1)
(setq POS (atoi (get_tile "Pt_d")))
(setq PP (+ 1 POS))
(done_dialog)
) ;_ end of defun
(defun LIST1 () (setq POS (atoi (get_tile "Pt_d"))) (CH1 POS))
(defun
CH1 (VV)
(setq POS1 (itoa (1+ VV)))
(IMAG)
(start_image (strcat "ve" POS1))
(fill_image 0 0 X Y 1)
(slide_image 0 0 X Y (strcat "pid1(v" (itoa (+ 1 VV)) ")"))
(end_image)
(set_tile "Pt_d" (strcat (itoa VV))) ;(set_tile "Pt_d" "0" )
) ;_ end of defun
(defun
IMAG ()
(setq CNT 1)
(repeat 18
(start_image (strcat "ve" (itoa CNT)))
(fill_image 0 0 X Y 0)
(slide_image 0 0 X Y (strcat "pid1(v" (itoa CNT) ")"))
(end_image)
(setq CNT (+ 1 CNT))
) ; this subroten convert all side librari in to black color
) ;_ end of defun
(defun
DRWW ()
(setq SP (getpoint "\nEnter start point :"))
(if (= PP 1)
(command "_.Insert" "AngleGlobes" SP)
) ;_ end of if
(if (= PP 2)
(command "_.Insert" "Ballrotary" SP)
) ;_ end of if
(if (= PP 3)
(command "_.Insert" "butterfly" SP)
) ;_ end of if
(if (= PP 4)
(command "_.Insert" "Check" SP)
) ;_ end of if
(if (= PP 5)
(command "_.Insert" "controls" SP)
) ;_ end of if
(if (= PP 6)
(command "_.Insert" "diaphram" SP)
) ;_ end of if
(if (= PP 7)
(command "_.Insert" "tankvalve" SP)
) ;_ end of if
(if (= PP 8)
(command "_.Insert" "gate" SP)
) ;_ end of if
(if (= PP 9)
(command "_.Insert" "globes" SP)
) ;_ end of if
(if (= PP 10)
(command "_.Insert" "needle" SP)
) ;_ end of if
(if (= PP 11)
(command "_.Insert" "plug" SP)
) ;_ end of if
(if (= PP 12)
(command "_.Insert" "quickops" SP)
) ;_ end of if
(if (= PP 13)
(command "_.Insert" "saf-rels" SP)
) ;_ end of if
(if (= PP 14)
(command "_.Insert" "stopcheck" SP)
) ;_ end of if
(if (= PP 15)
(command "_.Insert" "vacumbreaker" SP)
) ;_ end of if
(if (= PP 16)
(command "_.Insert" "patternglobe" SP)
) ;_ end of if
(if (= PP 17)
(command "_.Insert" "3way" SP)
) ;_ end of if
(if (= PP 18)
(command "_.Insert" "4way" SP)
) ;_ end of if
(setq PP 0)
) ;_ end of defun
(defun
C:VALVE ()
(WELDST)
(if (> PP 0)
(DRWW)
) ;_ end of if
) ;_ end of defun
(terpri)
(prompt "\nType to run ")
Difficile à dire comme çà :casstet:
As tu le fichier" P&ID.dcl" qui va avec ? Si oui, est-il dans un dossier du chemin de recherche des fichiers de support ?
As tu la librairie de diapositives (pid1.slb) qui va avec ? Si oui, est-il dans un dossier du chemin de recherche des fichiers de support ?
Plus généralement, quel message d'erreur as-tu quand tu essayes de lancer le LISP ?
Chez moi çà fonctionne, je ne vois pas où est le problème.
Si tu ne dis pas précisément ce que tu veux, je ne peux pas t'aider.
Je ne comprends pas l'enigme, je ne suis pas plombier, je suis menuisier, ceci explique peut-être celà. ;)
si ça marche déjà c'est rassurant.
Donc ça vient de chez moi:
je t'explique
une fois charge et en place la ligne de commande m'indique ceci
Commande:
Type to run
Commande:
et rien de nouveau à l'écran ...............
Que faut--il faire que je n e fais pas
Milles escuses GILE
PB erreur de ma part :nom de fichier
déformé
OK ça marche je remercie j'ai identifié le pb et encore merci.
C'est juste un problème de avec les copier/coller et les bbcodes.
À la fin du LISP, il est écrit
(prompt "\nType to run ") mais sans les espaces après et au copier/coller dans CADxp tout çà disparaît (c'est interprété comme du html, je crois).
Donc dans ce cas là, rien de grave, le LISP fonctionne quand même si tu entres VALVE à la ligne de commande.
Tu peux corriger en changeant cette ligne par :
(prompt "\nType VALVE to run ")
Pour info, dans un LISP la commande à entrer directement à la ligne c'est ce qui est écrit après c: dans la routine de lancement ex : (defun C:VALVE ...
