zebulon_ Posté(e) le 13 septembre 2016 Partager Posté(e) le 13 septembre 2016 Bonjour, je me suis placé dans un scu tourné de 180° par rapport au SCG et j'ai créé un TEXT et un MTEXT. En regardant les propriétés du TEXT :Commande: (vlax-dump-object e); IAcadText: Interface AutoCAD Text; Valeurs de propriétés:; Alignment = 0; Application (RO) = #<VLA-OBJECT IAcadApplication 000000014005d910>; Backward = 0; Document (RO) = #<VLA-OBJECT IAcadDocument 00000000362b9668>; EntityTransparency = "DuCalque"; Handle (RO) = "2C3"; HasExtensionDictionary (RO) = 0; Height = 150.0; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000002d21d188>; InsertionPoint = (787.296 2013.97 0.0); Layer = "REPNM-50"; Linetype = "ByLayer"; LinetypeScale = 1.0; Lineweight = -1; Material = "ByLayer"; Normal = (0.0 0.0 1.0); ObjectID (RO) = 47; ObjectID32 (RO) = 47; ObjectName (RO) = "AcDbText"; ObliqueAngle = 0.0; OwnerID (RO) = 45; OwnerID32 (RO) = 45; PlotStyleName = "ByLayer"; Rotation = 3.14159; ScaleFactor = 1.0; StyleName = "$fersys-nom"; TextAlignmentPoint = (0.0 0.0 0.0); TextGenerationFlag = 0; TextString = "toto"; Thickness = 0.0; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000002d21cfa0>; UpsideDown = 0; Visible = -1Ton voit une rotation de pi. On en conclu que la propriété "Rotation" est relative au SCG Les propriétés du MTEXT :Commande: (vlax-dump-object e); IAcadMText: Interface AutoCAD Mtext (texte multiple); Valeurs de propriétés:; Application (RO) = #<VLA-OBJECT IAcadApplication 000000014005d910>; AttachmentPoint = 7; BackgroundFill = 0; Document (RO) = #<VLA-OBJECT IAcadDocument 00000000362b9668>; DrawingDirection = 5; EntityTransparency = "DuCalque"; Handle (RO) = "2BE"; HasExtensionDictionary (RO) = 0; Height = 150.0; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000002d21dae8>; InsertionPoint = (952.856 1257.44 0.0); Layer = "REPNM-50"; LineSpacingDistance = 250.0; LineSpacingFactor = 1.0; LineSpacingStyle = 1; Linetype = "ByLayer"; LinetypeScale = 1.0; Lineweight = -1; Material = "ByLayer"; Normal = (0.0 0.0 1.0); ObjectID (RO) = 46; ObjectID32 (RO) = 46; ObjectName (RO) = "AcDbMText"; OwnerID (RO) = 45; OwnerID32 (RO) = 45; PlotStyleName = "ByLayer"; Rotation = 0.0; StyleName = "$fersys-nom"; TextString = "toto"; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000002d21d9c0>; Visible = -1; Width = 0.0on voit une rotation de 0.0 et on conclu que la propriété "Rotation" dépend du scu local. Je me demande en quoi c'est logique ? AmicalementVincent C'est au pied du mur que l'on reconnaît le maçon ! (Anonyme) C’est en restant au pied du mur qu’on ne voit que le mur (Anonyme aussi) Lien vers le commentaire Partager sur d’autres sites More sharing options...
bonuscad Posté(e) le 13 septembre 2016 Partager Posté(e) le 13 septembre 2016 Bonjour, Voici comment je peux expliquer la chose... Je vais partir des codes DXFPour un texte tu auras outre le point d'insertion (dxf 10):(50 . 1.5708) (11 0.0 0.0 0.0) Pour un mtexte tu auras ceci:(11 2.83277e-016 1.0 0.0) (50 . 0.0) qu'on peut assimiler à -> (11 0.0 1.0 0.0) (50 . 0.0) Pour un MTEXT le code 11 est un vecteur (un peu comme le code d'extrusion 210) qu'on peut comprendre comme scu objet, alors que pour un TEXT le code 11 est un point d'alignement. (voir l'aide DXF)Donc pour avoir l'angle dans le SCG, il faut faire la transformation vectorielle en s'aidant du code 11. J'espère avoir été compréhensible? Choisissez un travail que vous aimez et vous n'aurez pas à travailler un seul jour de votre vie. - Confucius Lien vers le commentaire Partager sur d’autres sites More sharing options...
(gile) Posté(e) le 13 septembre 2016 Partager Posté(e) le 13 septembre 2016 Salut, C'est quand même assez énorme qu'il n'y ait aucune propriété correspondant à la direction avec COM/ActiveX.On l'a en DXF comme l'a montré bonuscad ou avec (getpropertyvalue mtexte "Direction"). Gilles Chanteau - gileCAD - Développements sur mesure pour AutoCAD Lien vers le commentaire Partager sur d’autres sites More sharing options...
zebulon_ Posté(e) le 13 septembre 2016 Auteur Partager Posté(e) le 13 septembre 2016 Merci c'est très clair ! Les lignes de repères multiples sont d'ailleurs très voisines des textes multiples de ce point de vue. Ce qui est surtout gênant, c'est le fait que les propriétés aient le même nom "Rotation" et qu'elles n'aient pas la même signification selon le cas. Pour un MTEXT, si on regarde le code de groupe 50, on le voit évoluer en fonction du scu égalementCommande: (entget e)((-1 . <Nom d'entité: 7ffffb61d40>) (0 . "MTEXT") (330 . <Nom d'entité: 7ffffb649f0>) (5 . "24C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "REPNM-50") (100 . "AcDbMText") (10 282.581 164.981 0.0) (40 . 150.0) (41 . 0.0) (46 . 0.0) (71 . 1) (72 . 5) (1 . "Toto") (7 . "$fersys-nom") (210 0.0 0.0 1.0) (11 -1.0 1.22465e-016 0.0) (42 . 406.617) (43 . 152.456) (50 . 0.0) (73 . 1) (44 . 1.0))Commande: scuNom du SCU courant: *AUCUN NOM*Spécifiez l'origine du SCU ou [Face/NOMmé/OBjet/Précédent/Vue/Général/X/Y/Z/axEZ] <Général>:Commande: (entget e)((-1 . <Nom d'entité: 7ffffb61d40>) (0 . "MTEXT") (330 . <Nom d'entité: 7ffffb649f0>) (5 . "24C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "REPNM-50") (100 . "AcDbMText") (10 282.581 164.981 0.0) (40 . 150.0) (41 . 0.0) (46 . 0.0) (71 . 1) (72 . 5) (1 . "Toto") (7 . "$fersys-nom") (210 0.0 0.0 1.0) (11 -1.0 1.22465e-016 0.0) (42 . 406.617) (43 . 152.456) (50 . 3.14159) (73 . 1) (44 . 1.0)) Alors que pour le texte "ligne", ce code de groupe 50 reste constant quel que soit le scuCommande: (entget e)((-1 . <Nom d'entité: 7ffffb61d50>) (0 . "TEXT") (330 . <Nom d'entité: 7ffffb649f0>) (5 . "24D") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "REPNM-50") (100 . "AcDbText") (10 -234.379 470.607 0.0) (40 . 150.0) (1 . "Lig") (50 . 3.14159) (41 . 1.0) (51 . 0.0) (7 . "$fersys-nom") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0))Commande: scuNom du SCU courant: *AUCUN NOM*Spécifiez l'origine du SCU ou [Face/NOMmé/OBjet/Précédent/Vue/Général/X/Y/Z/axEZ] <Général>:Commande: (entget e)((-1 . <Nom d'entité: 7ffffb61d50>) (0 . "TEXT") (330 . <Nom d'entité: 7ffffb649f0>) (5 . "24D") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "REPNM-50") (100 . "AcDbText") (10 -234.379 470.607 0.0) (40 . 150.0) (1 . "Lig") (50 . 3.14159) (41 . 1.0) (51 . 0.0) (7 . "$fersys-nom") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0)) Il en est de même si on scrute la rotation de ces objets dans la fenêtre propriétés. AmicalementVincent C'est au pied du mur que l'on reconnaît le maçon ! (Anonyme) C’est en restant au pied du mur qu’on ne voit que le mur (Anonyme aussi) Lien vers le commentaire Partager sur d’autres sites More sharing options...
