[ACAD/MAP/etc version 201X-202X] Infos
lecrabe
SVP si vous pouvez m'aider a completer les Noms de Code Autodesk !?
https://georezo.net/forum/viewtopic.php?id=77588
**** https://accounts.autodesk.com/ **** Gestion/Console Autodesk ****
******** Les routines Lisp indispensables pour les ODs de MAP/CIVIL (OD = Object Data - Donnees d Objet) ********
https://georezo.net/forum/viewtopic.php?pid=356144
**** System Requirements (for Autodesk Software) ****
https://knowledge.autodesk.com/support/system-requirements
**** System requirements for AutoCAD Map 3D ****
https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-AutoCAD-Map-3D.html
---- AutoCAD MAP 3D Concepts ----
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/MAP3D-Learn/files/GUID-B71F1470-C7DA-4D4A-A8AC-6F41C35A639E-htm.html
---- AutoCAD MAP 3D Features ----
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/MAP3D-Learn/files/GUID-D06ECF0C-A9E5-4668-BD85-502C888A800A-htm.html
---- ACAD MAP 3D 20XX ---- Map 3D Documentation ----
https://knowledge.autodesk.com/support/autocad-map-3d/getting-started/caas/simplecontent/content/map-3d-documentation.html
---- ACAD MAP 3D 20XX ---- Learning Videos ----
https://knowledge.autodesk.com/support/autocad-map-3d/getting-started/caas/CloudHelp/cloudhelp/2021/ENU/MAP3D-Learn/files/GUID-522313B6-9C80-4202-9370-0FF1734FC697-htm.html
-- AutoCAD 2022 (Nom de Code = SEQUOIA) est Dispo !
-- AutoCAD 2021 (Nom de Code = ROGUE) est Dispo !
-- AutoCAD 2020 (Nom de Code = QUBIT) est Dispo !
-- AutoCAD 2019 (Nom de Code = PI) est Dispo !
https://www.autodesk.com/products/autocad/features
*** Nouveautes AutoCAD 2025-2022 ****
https://help.autodesk.com/view/ACD/2025/FRA/?guid=GUID-07450FCA-16CA-4D7A-8EA2-9CE842631D75
*** Nouveautes AutoCAD 2022 ***
https://www.autodesk.com/campaigns/autocad/whatsnew2022
*** Nouveautes AutoCAD 2021 ***
https://www.augi.com/articles/detail/whats-new-in-autocad-2021
*** Nouveautes AutoCAD 2020 ***
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoCAD-WhatsNew/files/GUID-7D9278AC-5197-4FA8-8EBF-A50E1279559C-htm.html
*** Nouveautes AutoCAD 2019 ***
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Core/files/GUID-4B04BE19-E966-4EE1-A21D-D00540BFE635-htm.html
*** Nouveautes AutoCAD 2018 ***
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Core/files/GUID-CCF06693-24EB-4DCB-BC60-183A91093024-htm.html
*** Nouveautes AutoCAD 2017 ***
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Core/files/GUID-2158DFA1-FA3A-4081-87E7-1CB0038AE02F-htm.html
---- Nouveautes AutoCAD Map 3D Update 2023 ----
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-6CDF79B1-CFBA-435B-A1B1-9A0D6813D66B
---- Nouveautes AutoCAD Map 3D Update 2022 ----
https://help.autodesk.com/view/MAP/2022/FRA/?guid=GUID-9EC84B77-8F77-412A-A68B-19F306B12AFC
---- AutoCAD Map 3D Update 2022 ---- MAP 2022.0.1 ---- 23 sept 2021 ----
https://help.autodesk.com/view/MAP/2022/FRA/?guid=AUTOCAD_MAP_2022_0_1_UPDATE
---- Nouveautes AutoCAD Map 3D Update 2021 ----
https://help.autodesk.com/view/MAP/2022/FRA/?guid=GUID-74B5CBDF-75BF-4388-85FC-91A3617FDA1B
---- AutoCAD Map 3D Update 2021 ---- MAP 2021.0.1 ---- 22 sept 2020 ----
https://help.autodesk.com/view/MAP/2021/FRA/?guid=AUTOCAD_MAP_2021_0_1_UPDATE
-- AutoCAD MAP 2021 va disposer des Micro-Nouveautes de AutoCAD 2021
+ qq autres micro-ameliorations ...
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/MAP3D-Learn/files/GUID-74B5CBDF-75BF-4388-85FC-91A3617FDA1B-htm.html
-- AutoCAD MAP 2020 va disposer des Micro-Nouveautes de AutoCAD 2020
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/MAP3D-Learn/files/GUID-74B5CBDF-75BF-4388-85FC-91A3617FDA1B-htm.html
-- AutoCAD MAP 2019 va disposer des nouveautes de AutoCAD 2019
et aussi de 2 nouvelles fonctionnalites interessantes :
- Import / Export City GML
- Import / Export KML
http://geospatialfrance.typepad.com/geospatialfrance/autocad_map_3d/
2021 - Les nouveautes MAP 2021 - RESUME
---- Les Micro-Evolutions de MAP 2021 sont :
- Edit ArcGIS Features (A priori IDEM InfraWorks !?),
- FDO WMTS Support,
- FDO SQLite 3.27.2 Support,
- FDO Oracle 19c (19.3) Support,
- Diverses micro-micro-corrections.
2020 - Les nouveautes MAP 2020 en US/English
**** MAP 3D 2020 New Features ****
From the HELP page >>>
Autodesk Connector for ArcGIS
AutoCAD Map 3D 2020 toolset allows you to access your GIS data on ArcGIS Online or Portal for ArcGIS Enterprise and bring them into your drawings. After adding the data to your drawing, you can view the features in the canvas, check the records in the data table, stylize the layers, and query to filter the data. For the current release, you cannot edit the data from ArcGIS Online or Portal for ArcGIS Enterprise. You can check the related topics in Help for more details.
Coordinate System Enhancements
The following issues are now fixed in this release of AutoCAD Map 3D 2020 toolset:
Nova Scotia coordinate Reference System (NSCRS):
NS.NAD83.2010.UTM.20N
NS.NAD83.2010.MTM.5
NS.NAD83.2010.MTM.4
NS.NAD83.1997.MTM.5
NS.NAD83.1997.MTM.4
NS.ATS77.MTM.5
NS.ATS77.MTM.4
Transformation from OSGB1936 to ETRS89
Deutsche Bahn Reference System
Large size GSB files
Added support for:
GDA2020 Grid Transformation
Rocky Mountain Tribal Coordinate Reference System (RMTCR)
Other Enhancements
Extended support for the following FDO providers to newer versions:
FDO MySQL Provider: MySQL 8.0
FDO ArcGIS Provider: ArcGIS 10.6.1, ArcGIS 10.5
FDO SQL Server Spatial Provider: MS SQL Server 2017
FDO Oracle Provider: Oracle 18c (18.3)
Note: Due to a known problem that exists from Oracle 12.2, users must follow the workaround described here to work with the industry models job in Oracle 12.2 or Oracle 18c: Configure the system with "_allow_insert_with_UPDATE_CHECK" set to True, by executing the following SQL command:
ALTER SYSTEM SET "_allow_insert_with_update_check"=TRUE scope=spfile
Then, restart the database.
Support Middle Point Grip for polygons with interior rings.
A new command MAPNORTHARROWDEFAULTNORTH is introduced in this release. It allows the user to specify whether the North Arrow points to the default north (i.e., the angle of Pi/2) or the north defined in the current coordinate system. When this command sets to 0, the North Arrow will point to the north defined in the coordinate system. When this command sets to 1, the North Arrow will point to the default north.
Enhanced the Industry Module Plot.
The following customer issues have also been resolved in AutoCAD Map 3D 2020 toolset:
Some of the WFS data got flipped in AutoCAD Map 3D toolset. To solve this problem, in the Data Connect dialog, a new checkbox ‘Invert Axis’ is provided to allow you to specify whether to invert the axis when handling the WFS.
For some WFS service, query the data by ‘Locate on map’ option didn’t work.
The command MAPTOACAD took a long time for some specific data.
After exported to DWG, the circle symbols got stretched or compressed depending on zoom level.
The input values like line thickness, the rotation would change when users change the symbol.
Relative Orientation for Utility Point label did not work well for SQLite based industry models.
AutoCAD Map 3D 2020 toolset added some Autodesk.Map.IM namespaces to the Form Controls: Formula Box and Script-Programmable-Control.
Import from Excel lacked a detailed error message.
Intersection Area/Point did not remove deleted/moved feature if using "intersect over the area."
AutoCAD Map 3D toolset could not save projection code to the drawing.
2019 - Les Nouveautes MAP 2019 en US/English
**** MAP 3D 2019 New Features ****
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/MAP3D-Learn/files/GUID-74B5CBDF-75BF-4388-85FC-91A3617FDA1B-htm.html
**** New in This Release ****
The 2019 release of AutoCAD Map 3D contains customer-focused enhancements across the product, including the following specifics.
**** Support Mid-Points Grips on Polygon
AutoCAD Map 3D 2019 now supports the mid-point grips on polygon features. The editing options for mid-point grips are: stretch, add vertex, convert to arc and convert to line.
**** Import/Export support for CityGML and Google KML Files
AutoCAD Map 3D 2019 enables users to import CityGML and Google KML data and export data to CityGML and Google KML file format.
**** Coordinate System Enhancements
The following are the enhancements to the coordinate system in AutoCAD Map 3D 2019:
Support for Nova Scotia coordinate systems:
NS.NAD83.2010.MTM.5
NS.NAD83.2010.MTM.4
NS.NAD83.1997.MTM.5
NS.NAD83.1997.MTM.4
NS.ATS77.MTM.5
NS.ATS77.MTM.4
Useful range of 8 Minnesota County coordinate systems
Support for Australian GDA 2020
Deprecated 221 Wisconsin County HPGN coordinate systems
Update to EPSG 9.0
Support the transformation from OSGB1936 to ETRS89
Added Deutsche Bahn Reference System and related coordinate systems
**** New Version Support for FDO Oracle Provider
Extended support for the FDO Oracle provider to newer versions:
FDO Oracle Provider: Oracle 12.2.0.1
Note: Due to a known problem in Oracle 12.2, users have to follow the workaround described here so as to work with the industry models job in Oracle 12.2:
Configure the system with "_allow_inserts_with_UPDATE_CHECK" set to True, by executing the following SQL command:
**** High Resolution (4K) Monitor Support
Some icons in the Ribbon and Status Bar have been updated to ensure the best possible viewing experience in Dark and Light theme on 4K and higher display monitors.
**** Other Enhancements
The following customer issues have also been resolved in AutoCAD Map 3D 2019:
Increased memory usage for the generate graphic operation.
Graphics were generated for the updates in other jobs.
Map 3D took a long time to update or delete features from templates in large, job-enabled databases.
Crash when creating the job perimeter by selecting a complex polygon from the area.
Stretching a vertex caused other vertices to be moved together.
Stretching vertex for arcs had an offset.
Rotated raster files were displayed in a filled orthogonal frame.
Bulk Copy would fail if the source layer contains a join.
Geolocation would be shifted when the drawing was reopened in AutoCAD Map 3D.
ANSI31 hatch was exported with wrong scaling and orientation during MAPTOACAD.
During MAPTOACAD operation, exported symbols with feature labels didn't get replaced with DWT blocks, so they had no global width and a different block naming.
MAPSYMBOLIMPORTEXPORT didn't replace the symbols correctly.
In Industry Model Forms, for ComboBox control with multiple detail tables, Detail SortOrder setting didn't work with other attributes except FID.
DETAILFILTER statement of Combo Box control was composed differently in Form and Designer preview.
AutoCAD Map 3D created the wrong result with intersection for some data when performing overlay analysis.
Split Cable operation associated the wrong devices to split cables.
When you digitize multiple points at the same location, whether an internal structure is automatically generated now depends on the field value that you set in the database table.
Note: To turn on this function, access the TB_info table, add one record, set param: to ALLOW_DUPLICATE_DEVICE, and Value_numer to 1. To turn off this function, set Value_numer to 0.
AutoCAD Map 3D encountered an SSL connect error when connecting to FEMA WMS service.
Some attribute values from WFS service were not displayed correctly in AutoCAD Map 3D.
Stylized FDO data disappeared in a viewport that was rotated.
Qu'on se le dise !
Avoir choisi PI comme petit nom de version est représentatif de l'état d'esprit des développeurs, non ?
PI est irrationnel et la précision des décimales dans AutoCAD le devient aussi
Souhaitons-leur que cette version ne soit pas PIratée.
De là à parler de la quadrature du cercle avec cette nouvelle version, les quelques avant-propos des quelques intervenants ayant déjà mis PI en route laissent supposer une "nouvelle" version purement "commerciale".
Tant que je ne suis pas obligé de changer, je reste en 2015, changer juste pour dire qu'on a changé n'est pas dans mes habitudes.
Edit : si on a vraiment un export KML dans MAP on peut parler de nouveauté...
Hello Didier
Tu es toujours aussi "caustique" : j'adore !
Le nom de code de la version 2018 etait OMEGA donc la derniere lettre de l'alphabet grecque !
Ainsi certains ont dit (A tort) que c'etait le derniere version d'AutoCAD ...
Bonne Continuation "sableuse et desertique", Bye, lecrabe
PS: en resume, tu es un vieux GG = Goeleand Grincheux !
Salut vieux Crabe
2) AutoCAD MAP 2019 va disposer des nouveautes de AutoCAD 2019
YOUPEE !!
Moi je dis pas Youpee !
j'ai passé 1 journée à améliorer mon import Kml !
(pour importer depuis le géoportail ign)
et là je vois que j'ai perdu mon temps ! grr !
a+
gégé
Site: https://www.g-eaux.fr
a+
gégé
Et que dire de Lommig, qui a développé une fonctionnalité identique en parallèle... :(
SVP c quand meme une heureuse / bonne surprise ces 2 petites evolutions du MAPIMPORT / MAPEXPORT !
DONC je dis MERCI a Autodesk ...
Car cela fait au moins 5 ans qu'il n'y avait eu aucune amelioration significative
sauf des corrections de certains bugs (surtout dans la partie "Modeles Metiers / TopoBase") !
RAPPEL : la derniere version de MAP avec de "vraies" Evolutions, c'etait la 2012 avec le nouveau moteur d'affichage & stylisation "FDO Engine" !!
Oui, oui, tu as entièrement raison. Pour une fois qu'il y a une vrai évolution, il ne faut pas cracher dans la soupe. De ce coté là je dis bravo....
Ma remarque viens juste du fait que je me suis mis à la place de Lommig, qui à 1.5 mois près se serait économisé pas mal de temps de développement.
c'est vrais que certain clients aiment bien ce petit plus.
Je fait mes kml à la main pour des petits chantiers exenple
<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom"><Document><name>
SAR_072_FOYER-LA-MAISONNERAIE_S01_APD_GC_V20180323
</name><description>
Chambre L4T Sartel Existante + 2 PVC %%c42/45 à 0.50 Prof. sur 3.30m + 1 Chambre L4T FT Existante
</description><Style id="style00001"><LineStyle><color>
ff0000ff
</color><colorMode>
normal
</colorMode><width>
4
</width></LineStyle><BalloonStyle><displayMode>
default
</displayMode><bgColor>
ffffffff
</bgColor><textColor>
ff000000
</textColor><text>
</text></BalloonStyle></Style><Folder><name>
Layers
</name><Folder><name>
1C_Tranchée
</name><Placemark><name /><description /><styleUrl>#style00001</styleUrl><LineString><altitudeMode>clampToGround</altitudeMode><extrude>0</extrude><tessellate>0</tessellate><coordinates>
0.20597661,48.03420611,0.000
0.20597733,48.03421567,0.000
0.20597229,48.03421908,0.000
0.20596676,48.03421602,0.000
0.20596623,48.03420649,0.000
</coordinates></LineString></Placemark></Folder></Folder></Document></kml>
pas difficile.
Salut à tous !
Toujours pas disponible dans mon compte autodesk avec une licence sous abonnement ...
Quelqu'un à des news ?
AutoCAD Map 3D 2023 (26.0.37.2 base T.53.0.0)
Covadis 18.0 + AutoPiste
Windows 11 Famille v.21H2 - 64 bits
Mais c "lecrabe" qui decide si on a le droit (en France) de telecharger ou pas AutoCAD MAP 2019 French
Cela fait partie de mes Privileges de Vieux Dinosaure French EE
Plus Serieusement : la Version FINALE n'est pas encore DISPO !
ACAD MAP 2019 doit apparaitre (en principe) sur vos Comptes en fin fin de semaine ...
Haha !
Merci Lecrabe pour l'information ! Et merci d'avoir décidé de sortir tout ça d'ici fin de semaine :(rires forts):
Hello du Samedi Soir
Vu "certains" problemes d'Autodesk "la semaine passee", je crains que la Dispo des versions 2019 de AutoCAD MAP, ACAD Archi, ACAD MEP, etc, soit RETARDEE !
Par contre, AutoCAD Mechanical 2019 est DISPO = INCOMPREHENSIBLE pour moi !
Navisworks et 3DSMax et Recap Pro aussi ...
Bon WE, Bye, lecrabe
Je croyais que justement PI était un ratio... Donc rationnel ? Non ? ;)
Victime de leur succès, tant PI pour eux... Et à ce prix...
Libre à toi, mais AutoDesk ne sort maintenant plus qu'une nouveauté tous les 3 ans... Leur format... :mellow: Il me semble que ses jours pourraient être comptés...
Personnellement, ma version préférée était la 2006...
Ce sera peut-être la seul réelle nouveauté (si import ET export)... A moins que l'IDE AutoLisp soit revu comme dans la dernière version de BrisCAD...?
Peut-être dans une version 2020 ? Ce n'est pourtant pas compliqué... Des tonnes de logiciels libres le font déjà...
Bon, il est 21h et ma fille réclame des frites... Oui, j'ai des origines belges, et alors ?
Bon week-end à vous tous et ne boire qu'avec Modération... Si vous le trouvez... ;)
Denis...
Windows 11 / AutoCAD 2024
Je pense que vous avez reçu l'information comme moi mais dans le cas contraire :
Covadis 16 n'est pas compatible avec AutoCAD 2019, il faudra attendre la version 17 (juin 2018) pour avoir Covadis sur AutoCAD 2019.
GRRR !! J'ai ete oblige de passer par AVA : https://ava.autodesk.com/
pour obtenir un lien de telechargement VALIDE de AutoCAD MAP 2019 French x64
Impossible de telecharger MAP 2019 depuis la console de gestion : ca m'enerve !
De plus je vois aussi AutoCAD Archi 2019 : impossible de le telecharger !
IDEM pour AutoCAD Mechanical 2019 ... IDEM pour ...
J'ai droit aussi a AutoCAD MEP 2019 : je ne le vois pas !!
Salut !
AutoCAD Map 2019 est dispo sur la console de gestion de mon compte !
Installation en cours :(rires forts):
Comme j'ai signale le 05 Avril 2018 >>>
Ayant recupere par AVA le Master de AutoCAD MAP 2019 x64 et aussi de AutoCAD Architecture 2019 x64,
j'ai installe (sur un PC sous Win Seven) ce matin et autorise AutoCAD MAP 2019 x64 ...
Rien de particulier a signaler !? ... Idem par rapport a une version 2018 ...
Sauf que j'ai installe AVANT le KB4019990 (Win 7 x64) de Microsoft
qui est imperatif pour les versions 2019 !!
( Attention: ce n'est pas la meme version de KB4019990 pour Win 7 et pour Win 8 )
En effet mes PCs sous Win Seven ont le Windows Update BLOQUE DEPUIS LONGTEMPS
et cela ne m'a jamais pose un quelconque probleme !
Good Luck avec la 2019, Bye, lecrabe
  • 1 an après...
